Best ignition lock cylinder lubricant?
Discussion in 'Generation 1 Prius Discussion' started by primuspaul, Jun 16, 2017.
  1. primuspaul
    primuspaul Member
    244
    NYC Area
    2002 Prius
    I
    I have some graphite poweder, WD-40 branded Silicone Lubricant, and PTFE lubricant. Which is recommended for applying to the inside of a ignition cylinder lock?
    52,891
    graphite. you don't want anything wet that dirt can stick to.
    WilDavis likes this.
  3. KennyGS
    KennyGS Senior Member
    1,243
    1,046
    Keystone State
    I would use the graphite.
  4. primuspaul
    primuspaul Member
    244
    NYC Area
    2002 Prius
    I
    I have graphite powder, but I read it gunks up when exposed to moisture, which can happen in a stationary car due to temperature change.
  5. bisco
    52,891
    then i would use the silicon.
  6. bisco
    52,891
    btw, i've never had to lube an ignition lock in 45 years. door locks, yes.
  7. primuspaul
    primuspaul Member
    244
    NYC Area
    2002 Prius
    I
    I don't "have" to lube it. By the time you have to lube it, it's probably too late. I recently had a lock break that I had to drill out. This is an old one from a salvaged ignition cylinder. I thought I'd put some lube in the keyhole to maybe make it last a bit longer.
    After doing some reading, I was leaning towards Silicone, too, but wanted to hear some input from the people on here before applying it.
    It's this stuff, by the way: WD-40 Specialist Water-Resistant Silicone Lubricant, 11 oz - Walmart.com
  8. dolj
    dolj Senior Member
    8,655
    4,406
    Wellington, New Zealand
    If you have the cylinder lock out, I'd be leaning toward the PTFE as it is supposed to leave a dry lubricating film once the solvent carrier evaporates off. I use it all the time around the house – door locks, door hinges, window stays and window catches, to name a few. I use it also on the window tracks on the car and have used it on door locks when I feel them getting sticky.
  9. Brian in Tucson
    Brian in Tucson Active Member
    981
    453
    Tucson AZ
    2003 Prius
    Gun oil. Or Tri Flow. WD40 is fairly inferior, but it will lube a little if that's what you need. Do you have a bunch of keys on your keyring? Too much weight on the lock mechanism will cause wear and sloppiness.
    Love Tri Flow, btw. Smells like gun oil.
  10. WilDavis
    WilDavis Senior Member
    2,493
    2,155
    49
    Here you are - I think I got this from HomeBoy Despot, or some such place! Good luck! Graphite1.jpg Graphite1.jpg
  11. jzchen
    jzchen Newbie!
    3,316
    1,022
    Arcadia, CA
    My vote is with graphite. I think the reason was it is electrically conductive as opposed to the other two choices. I think old security systems measured the resistance in the keys, but I think that was GM, and I'm just getting old....
  12. KennyGS
    1,243
    1,046
    Keystone State
    You too?! :eek:
    jzchen likes this.
