Best mode for long distance driving?
Discussion in 'Prime Fuel Economy & EV Range' started by Ed From Syracuse, Apr 21, 2017.
  1. Ed From Syracuse
    Ed From Syracuse Junior Member
    28
    35
    Syracuse
    I will be taking a trip down to New York City from Syracuse New York. It's about four and a half hours driving. Will be going up some hills and down others. My question is which mode do I use it when I'm on the highway? My old Prius I just ran it on economy mode. Do I just select the HV normal or economy mode? Or just the normal mode? I was told not to use the EZ Auto when driving long distance. It help is appreciated.
    52,776
    it's really a personal decision. if you're using cc a lot, see if one mode works better than another. i'm always in eco. not sure why you can't use ev auto.(n)
  3. Ed From Syracuse
    28
    35
    Syracuse
    In EV auto if I understanding right It will go in and out depending on the driving condition. Will I get the best gas mileage using that method or should I just drive in a normal mode?
  4. Prius from Dad
    Prius from Dad Senior Member
    724
    1,116
    Toms River, NJ USA
    On a trip that long, start out with a full EV battery. When it runs out you will get ICE warm up. I would use Eco mode. In the Prime, HV will let you use the HV part of the battery any any speed I have driven. The recharge is much faster than previous versions and not limited to the 43 mph. The charge mode uses more gas than you will gain from EV. Just HV should get you 60+ mpg.
    Gravediger and Ed From Syracuse like this.
  5. bisco
    52,776
    ev auto, he computer determines when the plug portion will be used up. assuming you will be exiting the highway from time to time, i suspect that's when it would be used, but don't know for sure. sounds like a fun experiment.
    achieving the best highway mpg's is tedious. i would just set the cc to the speed limit and stay to the right.
    Ed From Syracuse likes this.
  6. Prius from Dad
    724
    1,116
    Toms River, NJ USA
    Just curious, do you have hybrid driving experience?
  7. mr88cet
    mr88cet Senior Member
    2,313
    1,335
    Austin, TX
    I'd say try several possibilities, but I bet economy HV is your best bet. You might want to pop over to EV (eco) below 40ish MPH.
    iPhone ? Pro
  8. Ed From Syracuse
    28
    35
    Syracuse
    Yes I had a 2015 before I up graded. Got 52 in the summer and 47 in the wintet.
  9. Prius from Dad
    724
    1,116
    Toms River, NJ USA
    Then you will do better in using HV (ECO mode) than you did in the 2015. I had a 2012 v and got about the same as you. Now I'm getting about 64 avg, in HV only, and it is not that warm yet. Happy trails.
  10. Ed From Syracuse
    28
    35
    Syracuse
    It is just so many option. I did notice when when I depleted EV charge the ICE turned on. But it the car would go in and out of EV mode. Especially when I got off the highway. Even though I was out of EV charge I noticed I stayed in EV mode longer than ICE off the highway. But when I went to plug it in it gave me a 6 hour to full charge. Strange.
  11. Prius from Dad
    724
    1,116
    Toms River, NJ USA
    Once EV is depleted, Ice will come on for a warm up period, length depends on ambient temp, I've found. But is a little erratic til the ICE is totally warmed up then it is steady. After the EV is depleted you are in HV mode even though the indicator says EV. That means you are using the HV portion of the battery. Full charge for the battery on 120v (L1) is about 5.5 hrs. L2 charge will do it in about 2 hrs.
  12. Ed From Syracuse
    28
    35
    Syracuse
    Why then does it take 6 hours to charge. That's what it reads in the display? On L1 120V?
  13. bwilson4web
    16,512
    • Fill up the night before and fully charge car.
    • Set driving mode to whatever is comfortable.
    • Find a truck highballing your route.
    • Use cruise control to follow truck at a comfortable distance.
    • Take music.
    If the "low gas" comes on, switch to CHARGE mode; find lower speed traffic to follow, and; take first opportunity to refuel.
  14. unicorn
    unicorn Member
    48
    EU
    ... or you can take some inspiration from a gas saving adventure :)
    Winner's choice (64.1 mpg): Eco mode + EV Auto (see 4:15)
    702 miles, 13 hours, 54 mph
    Note (EV Auto vs HV): It seems that the control algorithms in EV Auto are trying to use EV (ICE off) more often as in HV, following, the consumption in EV Auto could be slightly better.
    #14 unicorn, Apr 22, 2017
    Toyota4Life and Ed From Syracuse like this.
  15. I'mJp
    I'mJp Senior Member
    628
    552
    Ma, USA
    Just my preference but ..
    Fully charge before. Use Ev, except on steep uphills, and highway.
  16. bisco
    52,776
    not following you here ed, if your out of plug charge, isn't 6 hours to recharge about normal?
  17. john1701a
    john1701a Prius Guru
    12,840
    5,312
    58
    No, that's a misconception. In most cases, it ends up to be a wash. Used strategically, there can be a gain.
  18. TonyPSchaefer
    14,816
    2,501
    66
    Far-North Chicagoland
    john1701a likes this.
  19. PT Guy
    PT Guy Senior Member
    1,085
    713
    Washington, the state
    Ed, we have two different things we're calling *Mode*
    There is the battery vs. engine operation. EV is all battery. HV is almost all engine. EV Auto lets the car's computer decide when to use the battery (if the battery still has some charge) and when to use the engine. If you have EV switched on and the battery becomes depleted, the car will switch itself to HV. Try EV Auto for your trip--and it'll still switch itself to HV when it needs to do so.
    There is Econ vs. Normal vs. Power modes. This is just the programming of the accelerator pedal. Econ gives little power for a bit of pedal travel. Power gives lots of power for the same pedal travel. Normal splits the difference. There ain't no free lunch. At the end of the pedal travel Econ gives more power for the pedal travel. Power doesn't have it to give--you get little added power. And, Normal splits the difference. Econ will give a bit longer battery life or burn a bit less gas. Power helps safely scoot into gaps in traffic. Set it how you prefer.
    Mark McIntyre likes this.
  20. mr88cet
    2,313
    1,335
    Austin, TX
    I'm still waiting for my P.Prime to arrive, so I can't speak from direct experience, however...
    My impression from discussions here, as well as some videos from Toyota, is that EV Auto mode tries to operate as an EV as much as possible, only switching on the engine when it needs greater acceleration. That, as opposed to, for example, switching to HV operation at high speeds or long times at moderate speed.
    So, it sounds like EV Auto is not so much for optimal efficiency on long trips, but for better acceleration in a pinch. It will tend to drain, rather than sustain, the battery.
    Comments from actual current owners?
    iPhone ? Pro
    #20 mr88cet, Apr 22, 2017
