Best MPG segments - Picture Thread
Discussion in 'Prius c Fuel Economy' started by ufourya, Jun 5, 2012.
  1. Mik1
    Mik1 Member
    333
    Houston, TX
    My best tank so far. The pump showed 8.719 gallons. This brings me to around 58.4 mpg when my MID showed 61.3 mpg. So that is about 3 mpg difference. I guess pumps have their own accuracy as well as my C. Anyway… It says that I’ve covered 48% or 242.1 miles on EV. Was just curious, in that case if to presume that I don’t have an electric motor and battery in my C, I would probably covered about 267.1 miles with the same amount of gas. Which means my “theoretical” mpg would be around 30.7 mpg which is = to Yaris.
    brucepmiller likes this.
  2. jsfabb
    jsfabb Active Member
    617
    156
    Medford, NY
    Even though it's easier to figure out the difference in mpg (~3), you should really calculate the % difference. Which in your case is 4.96%. Because, as your mileage varies especially in the colder months, percentage is a better indicator. The normal percent difference is about 5%, so you are right there. I just looked at my last 10 fill-ups and mine was 5.3%.
  3. Mik1
    Mik1 Member
    333
    Houston, TX
    Thanks! Never had a chance to look from % difference point of view. How did you figured out that 5% is normal? Did I miss some discussion in PC?
  4. jsfabb
    617
    156
    Medford, NY
    It was just from reading PC. I'm sure there are threads on this I must have read.
  5. JesC
    JesC Junior Member
    My average on the way back from work
    RocMills and brucepmiller like this.
  6. RocMills
    RocMills Active Member
    789
    276
    Las Vegas, Nevada
    Trip home from work, just a couple of days ago.
    ufourya, brucepmiller and F8L like this.
  7. 08PriusXSJ
    08PriusXSJ Junior Member
    42
    Connecticut
    This is a used 2012 Prius C2 I just bought with only 20,000 mile on it.
    Today I had the first 140 mile's trip (40% HW and 60% of local). The recorded mpg on the board is 65.7 with average trip speed of 41 mph. first MPG  record of My 12 Prius C2.jpg
  8. ztanos
    ztanos All-around Geek!
    3,339
    1,149
    40
    Cumming, Georgia
    4th revived thread, well done. That's almost a record. :D
