Best ND 11 alternative for AC compressor oil?
Discussion in 'Gen 2 Prius Technical Discussion' started by Banksy, Apr 23, 2020.
  1. Banksy
    Banksy Active Member
    415
    133
    Lancaster Pennsylvania
    So I've searched the threads on here about this and am curious what is the current best option.
    I'm replacing my compressor this week and the last thing I need is oil.
    I called toyota and they wanted like 250 dollars for a qt of it. That's not going to happen.
    Ideally I'd like something I can put into the compressor before it's in the car. I have a full set of manifold gauges and a vacuum pump to pull a vacuum too. However I don't think I can add oil into the compressor without buying something else for my gauges and I really don't wanna do that.
  2. Mendel Leisk
    42,376
    I got a purge and fill at dealership for $150 plus sales tax (CDN). Maybe just install the compressor and let them do the charging?
  3. Banksy
    415
    133
    I spent 50 bucks on the compressor. I don't want to spend triple that on a charge.
    Plus I just spent like 100 bucks on this vacuum kit and I want to use my cool new tool :sneaky:
  4. Leadfoot J. McCoalroller
    8,293
    7,809
    Pennsylvania
    2018 Prius c
    What about the gauges?
    You should never use a gauge set that has previously been exposed to PAG oil on a Prius. One gauge set for cars with electric compressors, another for cars with belt-drive.
    That said I don't think you're going to find a substitute for ND-11, but you can probably find a cheaper source without a Toyota part number.
    jerrymildred likes this.
  5. Banksy
    415
    133
    Gauges are literally brand new
    Haven't even been removed from the plastic yet haha
  6. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,099
    Columbia, SC
    I may have missed this in an earlier post, but why are you replacing the AC compressor?
  7. Banksy
    415
    133
    Ac won't get cold
    Tested the system and it holds pressure so I'm thinking it's the compressor
  8. ChapmanF
    19,058
    If you tell Techstream to run the compressor various speeds, what speeds does it run? What pressures are you seeing when the system operates? What does Techstream say about the pressure switch status, etc?
    Leadfoot J. McCoalroller and SFO like this.
  9. Mendel Leisk
    42,376
  10. Banksy
    415
    133
    I keep forgetting techstream can do stuff like this :cry::cry:
  11. TMR-JWAP
    6,404
    6,099
    Columbia, SC
    One thing you may want to check is whether the inverter is sending power to the compressor.
  12. ChapmanF
    19,058
    In Gen 2 the inverter contains the variable-frequency drive for the compressor, so it will only be sending power when it has been instructed to run the compressor, and the power will be AC, at a variable frequency.
  13. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    Good luck with that.
    Guessing at the cause of a problem often turns out bad.
    Finding the necessary oil might turn out to be the least of your worries.
    Have you removed the old compressor yet ?
  14. Banksy
    415
    133
    Nope
    Plan to run techstream on it tomorrow
    Will keep this post updated
  15. Banksy
    415
    133
    So I hooked up techstream
    Apparently the compressor is working
    It's only reaching about 6200 rpms
    Apparently techstream says it should be 7200-8400 or something like that?
  16. Leadfoot J. McCoalroller
    8,293
    7,809
    Pennsylvania
    2018 Prius c
    It's capable of a wide range of speeds. You need to make sure it has been asked to run faster than 6200 before condemning it for not running faster than 6200.
  17. Banksy
    415
    133
    Ok... Well if it's not the compressor... And the system is holding pressure... What is it then
  18. Leadfoot J. McCoalroller
    8,293
    7,809
    Pennsylvania
    2018 Prius c
    "pressure" is pretty vague. These systems are ultra-precise. If your charge level is off (high or low) by a half ounce you could lose 20% of your capability.
    By far the best way is to zero it out, vacuum it hard, and then fill it with the supply vessel on a very accurate scale so you can count off exactly how much has been added.
    Yes this does assume a good compressor, and I don't think yours is fully proven in or out yet.
  19. Banksy
    415
    133
    I tested the compressor
    Got it up to around 7500 rpm
    I don't feel any cold air still
    Checked the psi before hand and it was holding at like 45-50
    Here are some photos of my manifold gauges if thatbhelps
  20. 05PreeUs
    05PreeUs Senior Member
    1,097
    565
    MSP
    AC on a Hybrid or EV is NOT something to be trifled with! The oils used in them are specifically non-conductive, those in wider use do nt meet that standard.
    The oil needed is WIDELY available in the marketplace, but unless you know what you are doing, adding or removing AC oil from the system generally leads to more problems than were initially present.
    Do some get lucky? Yup, but it is a BIG risk.
