Best new/refurb battery option - and where are these mythical $2000 OEM batteries?
Discussion in 'Gen 2 Prius Main Forum' started by pmelc1, Mar 15, 2025.
  1. rjparker
    rjparker Tu Humilde Sirviente
    10,859
    6,822
    Texas Hill Country
    Prius Hybrid Battery Reconditioning "How To Properly Repair A High Voltage Nickel Metal Hydride (NiMH) Battery Pack For Hybrid Vehicles"
    the hybrid guy
    MAX2 likes this.
  2. dolj
    dolj Senior Member
    8,631
    4,385
    Wellington, New Zealand
    Of all the options, If I was going to go secondhand, I would buy a NiMH battery from the newest wrecked car I could find. Batteries are hard to find as most wreckers will remove the battery (supposedly to make the car safe) and separately pass them on to one of the big battery "reconditioning" outfits.
    For you though, I would try leaving your 2006 battery undisturbed and try charging at a very low current (no more than 325 mA) with a grid charger. I wouldn't care about the low voltages as long as your battery was in good health.
    After that I'd do 3 reconditioning cycles with the charger and a home made discharger made with incandescent light bulbs – 240 V rated bulbs, if you can get them, make that an easier proposition. You can use 110-120 V rated bulbs as well, but you need to serially connect two together to make a 240 V unit, which you can then parallel to vary the current. You can also make a charger for under $100 (search that term) or buy a ready made charger from Maxx Volts or Hybrid Automotive.
    After that, I'd install it in a car if you had even voltage (+/- 0.3 V per block, with the voltage the 210 to 235 V range) and run a capacity test using Dr. Prius.
    I'd hazard a guess that you can restore your 2006 battery to near 80% - 90% capacity, if it was healthy before its furlough.
    YMMV.
    pmelc1 and MAX2 like this.
  3. pmelc1
    pmelc1 Junior Member
    58
    16
    NJ USA
    Thanks appreciate this and I'm sure others will benefit before I do. What I ended up doing is buying a 6-month-old GreenTec battery for $500. Guy totaled his car recently and was asking $700. He paid $1200 for it and it has another 6 months of transferable warranty. The aforementioned $599 guys only have a 6-month warranty as it is. I have a friend who can install it for around or less than $100.
    I plan on keeping the car for a minimum of 8-10 more years so I figure if/when I wear the GreenTec out, I can use the two batteries I have to create a good battery and/or swap out some of those modules to keep the GreenTec going. I may work on reconditioning them soon to extend their life, and then top them up again if I ever need to actually install them.
  4. dolj
    dolj Senior Member
    8,631
    4,385
    When I said, " I would buy a NiMH battery from the newest wrecked car," I mean the newest virgin OEM, not a secondhand battery. Nevertheless, you are where you are now.
    I wouldn't hold my breath hoping that Greentec will go the distance, but at least it buys you some time to work on your 2006 battery.
    Good luck in your endeavors.
  5. pmelc1
    58
    16
    NJ USA
    Yes I understood and appreciated your advice, I just didn't really have the time for that right now (paying to go on Copart, going to junkyards and picking parts, etc). I'm sure others will consider/benefit from it. Just needed to get fully back on the road ASAP, felt this was an acceptable cost, and hopefully will be good for the next year or two, and hopefully it'll take me well past that even if I have to swap a module or two. I have Dr Prius app and will keep close eye on the GreenTec battery.
    Then hopefully later than sooner per your protocol I can make another reconditioned battery with the many good modules I have. If I end up spending say $700 between this and a future module swap and get say 5 years out of that, and then I put another reconditioned battery in and spend another say $400 on that and another swap later and get another 3-5 years, that's preferable to me to spending $2-4k now and not having to worry about it for another 10 years. I don't mind the brief downtime / being in suboptimal battery state for periods of time. Everybody's got their own car style my style is to spend the absolute minimum I can, roll the dice at times, and limp along at times to preserve my capital for other purposes.
    The car also has 260k on it (and spare motor has 120k) so I don't know how much past a decade I'm going to want to take it or will be able to take it, 30 years is a damn good run and who knows what the fuel/battery tech situation etc will be in ten years. I could also get into a bad accident and not have full coverage, and decide to scrap it, or develop rust issue, etc. I got 19 years and 260k out of the original battery pack and I don't know if I want to take it anywhere near another 19 years or even necessarily sign on for a full 10.
    #25 pmelc1, Mar 16, 2025
  6. dolj
    dolj Senior Member
    8,631
    4,385
    It sounds like a good game plan.
    I'll add a few considerations.
    As you have time, I would look at making (or buying, if you prefer) the charging and discharging gear now, and use it on your Greentec regularly to help it last as long as possible. Then, when you're not using the gear for your daily driver, I'd look to doing the regime I mentioned in post #22 on your unmolested 2006 OEM pack. You might find it is all it needs to get it back into usable condition. Whatever you do, if it has low voltage (i. e. less than 203 V) or is unbalanced (i. e. wildly varying voltage and/or capacity between modules/blocks), do not put it in a vehicle and try to start the car. That is sure to damage it. Another way to damage it is to use high current (i. e. above 325 mV) when the pack is not in the 210 to 230 V range. Within that range, you can probably use up to 50 A without a problem.
    You will need to make a cooling system for your bench rig so you can recondition any batteries on the bench.
    I hope it works out for you, good luck.
    pmelc1 likes this.
  7. douglasjre
    douglasjre Senior Member
    2,236
    745
    Null, NL
    #27 douglasjre, Mar 17, 2025
    pmelc1 likes this.
  8. Tombukt2
    Tombukt2 Senior Member
    13,752
    2,489
    Durham NC
    So you're having no trouble using the newer round cell conversions from China seems to be working well I know the earlier ones were a real flop with these newer ones no problems and their nickel metal hydride?
  9. douglasjre
    2,236
    745
    Null, NL
    Define "older ones" and define "newer ones"
    Please explain "real flop"
    Please fix Grammer "these newer ones no problems and their nickel metal hydride" so I understand what you are trying to say.
    Please use technical specs and years of mfg to define which batteries you speak of.
    Please tell me where the wisdom is from, ie, collective wisdom from forum, person experience, etc
    How would one identify said "flop" batteries?
    #29 douglasjre, Mar 18, 2025
  10. Tombukt2
    13,752
    2,489
    Durham NC
    Over the years here on Prius chat where these post reside It looks like in the early years of Prius chat whatever you'd consider that to be when people tried to use the round cell conversions I don't know what year it was they didn't seem to do very well The people that physically tried them and bolted them into their mess they didn't last very long I don't know what that was 3 years something whatever it was nothing like the original Panasonic prismatic modules racked up properly from Panasonic then a few years later coming up into the now all of a sudden these around cell conversions are somewhat the thing so I you know don't know still the longevity of these newer round cell conversion with several places now sell. How long they will last so you've had yours in for 4 years now five something? What I saw a few years ago say four or five years ago was people were getting a few months or a year something and then back to red triangles and battery codes and other failures was this necessarily only a battery issue Good question as you well know from internet forums things can get very gray very quickly people's processes and methodology very greatly so it gets even more difficult to determine but anyway I want to see it all work to be honest about it I don't see any big deal you have X amount of volts racked up with X amount of AH you should have X amount of energy where you put the positive and negative terminals to or something but it seems way more complicated than that apparently so there you go. I'm only reading basically what's in the archives here and other places where I've read about the prismatic to round type conversions specifically for the Prius and at the time that was the generation 2 Prius as the three wasn't here yet so this is quite some time ago when this started. And then there was a swedish guy or I believe he was swedish that made the plug-in conversion that the guy in Maryland has I'm sure he'll be along in a minute so apparently with a little thinking things can happen with the batteries in these cars so there's always that I was looking to just have twice the MAH on the same voltage platform like a battery with twice the rear end behind it versus the 85 pounder that came with it and everybody looks at me funny. In this day and age all the modern battery technologies since 2008 I would think we should be able to come up with a battery that's slightly bigger quite a bit more powerful than all that but apparently not.
  11. Prodigyplace
    12,708
    11,847
    Central Virginia
    That would be some Gen 4 trims. I know the 2016 & 2017 Prius Two & Prius One (NOT Two Eco) had NiMH batteries. I had a 2017 Prius Two until it was wrecked.
    They changed the model trims later in Gen 4 and I did not follow them.
  12. pasadena_commut
    pasadena_commut Senior Member
    2,975
    915
    Southern California
    It is apparently always cheaper to order parts online from a Toyota dealer than to call in or just show up at the desk. By a lot. Even for things like fluids or oil filters. The only time you might want to call in is to get some information for why a part is out of stock on their web site.
    Before Toyota broke their parts site it was stupid easy to look up a part on the main site and then click on the dealer links to get their online prices. That is, to comparison shop. Now the main site will only link to a small subset of the dealers. Why just those dealers? Who knows. In my area one dealer is usually the lowest of the closest half dozen or so, but for an expensive part like a pack I will definitely check them all. When we replaced the pack it was another dealer which was the least expensive at that time, if I remember right, by $200.
  13. pasadena_commut
    2,975
    915
    Southern California
    I'll play. We had a 2003 Honda Civic Hybrid I with an IMA pack built with Chinese NIMH sticks similar to the ones you linked. If I remember correctly it even used the "larger capacity" ones, don't recall the value, more than 6500 though. On paper anyway. This would have been 2017 or so. It lasted about 2 years. This was the car's 3rd battery pack. Admittedly that was a different car, but the layout of the sticks in that IMA pack was very similar to the one in the picture in your link. This was before Honda went over to the bizarre "conjoined sticks" battery module format.
    So coming up on 10 years ago. Maybe the sticks are better now. Given that this market seems to consist mostly of a bunch of "never heard of that company before, bet it's gone in a year" manufacturers, betting on improved quality would be a suckers bet. Also I had a long conversation at one point with a guy who researched NiMH battery chemistry who said straight up that the prismatic cells were superior to the cylindrical ones.
  14. pmelc1
    58
    16
    NJ USA
    Thanks a lot. Will use your protocol to try to resurrect the '07 pack, maybe in full or with a couple module swaps; have plenty of modules both to keep the GreenTec going if need be, and to replace it altogether at a later time if need be.
    Did the install today and it's working well so far, getting about 49mpg which is about as good as my car gets most days.
    'Don't try this at home' but it's pretty much a DIY install in my book and can be done with 3-4 socket sizes (I believe 8, 10, 12, and 14mm) and philips & flat screwdrivers. As far as the battery itself goes the whole job is really just disconnecting the orange plug and detaching and reconnecting two battery leads. I paid a mechanic friend $100 total to install the coolant control valve and help with the actual battery swap, but with next to no mechanical and little electrical know-how, I could definitely do it all myself if I had to (did pretty much everything myself except swapping the leads).
    Solo with no real knowhow no experience no power tools and taking your time it's probably a 2-3 hour job. And there are some guys with ideal tools racing online to get it done in 15 minutes.
    95% of the job is the pain of dismantling trunk area, fan, removing the seat backs (not necessary to remove seat bottoms as some videos say), the side shields on battery, etc. We used rubber gloves and disconnected the pos&neg on 12v battery as an extra precaution, etc, but didn't seem as hazardous as some insinuate.
    Granted anything involving 220v is always a little nerve-wracking, though the service plug supposedly cuts the voltage down to 110 (or in any case lot lower than 220, which I've been shocked with by via an A/C condenser and wasn't a picnic), or so I've read. I have read there are exceptions such as the P0AA6 code where it can get a little hairier and good gloves are a must.
    #34 pmelc1, Mar 21, 2025
  15. Purrius
    Purrius Member
    167
    49
    Northeastern US
    I might have to consider changing mine out soon, and I plan to keep this car until it disintegrates.
    In the past I'd heard good things about GreenBean too, but are they still a preferred source?
  16. douglasjre
    2,236
    745
    Null, NL
    They're reselling the same ones you can get directly from Alibaba without their markup
  17. pmelc1
    58
    16
    NJ USA
    I don't like to endorse any brands here, but I would not call GreenBean the 'preferred' source. Reviews are a bit iffy IMO but do your due diligence. I'd probably sooner go with GreenTec or Professor Joe as linked here. But not endorsing any since I don't really have any direct experience yet other than that the GreenTec one I bought does work at present. In my case I'd probably just roll the dice with one of the guys for $599 installed that Tombukt2 referred to, they seem to be in every market (I ended up getting a lightly used GreenTec for $500 and paid a guy about $50 to help install it). Dolj also had a good idea if you know you want to keep the car for many years more. There are so many ways to skin the cat, all depends on your circumstances.
    The key takeaway I've had from researching / discussing here and doing the job is that whether you go new longer-lasting and more expensive or used shorter-lasting and cheaper, it's cheap enough on an annualized basis that, unless one stubbornly insists on doing the job at the stealership, losing a hybrid battery will probably never be a valid financial reason for getting rid of a Prius anymore. Maybe if battery and motor/trans went at same time, but personally I have a spare motor and trans. So I can only see a bad car accident or some unforeseen life changes that would lead me to get rid of it.
    #37 pmelc1, Mar 24, 2025
  18. Purrius
    Purrius Member
    167
    49
    Northeastern US
    Good points! I think going with a short term, cheaper option, is going to be the plan. At least until my financial situation is more stable, and I can ponder a long term replacement when needed. :D
