Best online store for OEM supplies - and navigation map update
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by PriusRos, May 21, 2021.
  1. krmcg
    2,592
    2,392
    Whittier, CA
    I tried it, the SD slot opens from the left side. slid my fingernail from left to right and the cover opened.
    Adam1a and PriusRos like this.
  2. PriusRos
    PriusRos A Fairly Senior Member - 2016 Prius Owner
    1,973
    218
    Rockville, MD
    Thanks.
    After writing that plea for help I actually found a YouTube video that showed the whole process. If you press in on the right side, the left side pops out. This was the only place I found complete instructions - it was great.
  3. jerrymildred
    jerrymildred Senior Member
    11,517
    14,149
    Tampa, FL
    Well, I give up. 3 miles into that 40+ mile trip the map thought I'd stopped. And no amount of button pushing would wake it up. Neither would rebooting the display. I just printed the return shipping label.
    As I was reading along I thought, "Why is he wasting all that time trying to get someone else to do a two-minute job?" Then I came to the last sentence. :ROFLMAO::ROFLMAO::ROFLMAO:
    Mine was an equal pain and then some because on the 11.6" display, it's on the bottom of the display forcing you to put your head on the Qi charger and try to peer up at it with one eye. After 3-4 times of swapping out what finally proved to be a junk card, I got so I could do it by feel.
    PriusRos likes this.
  4. PriusRos
    1,973
    218
    Rockville, MD
    I only use the Garmin when I have to rent a car. I find the built-in navigation so much more convenient.
  5. PriusRos
    1,973
    218
    Rockville, MD
    Sorry it's not working for you and hope you get a replacement that works.
    After watching the YouTube video, it was really easy. unlike yours, the slot on my 2016 Prius Four is right in the front beneath the navigation screen and I opened the door by pressing on the right side of it. No need to contort myself to reach it. I tried all the functions and it seems to be working but I haven't driven with it yet.
    jerrymildred likes this.
  6. PriusRos
    1,973
    218
    Rockville, MD
    You're right, I don't know why I was wasting that much time when I knew I could do it myself (it would take me a little longer than 2 minutes though because I'm short and it's hard to reach). But there was NOBODY in line in front of me so didn't know I'd have to wait that long! Oh, and I'm a she. :p:p:p
    jerrymildred and bisco like this.
  7. Valiant V
    Valiant V Member
    239
    161
    Winnsboro, TX
    I ordered and installed the Amazon navigation update for ~$35.00.
    Came in an original Toyota package (or a really good fake) and looks original.
    Hardest part of installation is getting dang little door open. The left side pops out with a fingernail, but the right side is tethered - I guess so you won't lose that little door. I had to stick a piece of paper behind it to pull it straight out so I wouldn't accidentally crack it.
    The Micro SD card removes and installs like a typical SD card - push it in to unlatch, then pull out. Push in the new one and it latches into place. (Do this with the hybrid system off!)
    Start the hybrid system and it says "new software detected - turn off the hybrid system to install". So basically you power-cycle the hybrid system and it starts updating. Took about 10 minutes to update, then kicks right into gear. The old destination I was going to was still in the system and it started giving directions without a hitch. Smooth!
    I checked the map data and it shows April of 2020. This being May/June of 2021 - I don;t know if it takes Toyota a year to get the SD cards out - OR (my guess) is that this is LAST year's SD card, and that's why it's a fraction of the cost of one from a dealer. Even the online dealers are getting ~$150 for these.
    Then again, no guarantee that you're gonna get a "fresh" one from the dealer.
    As for what places are actually on the database - YMMV. We used the new database to navigate to a place wee KNOW moved over two tears ago - but the year-old database still took us to the old location. I also see that it says a local gas station is in a given place - and there hasn't been one there for as long as I've lived here. (Over ten years) So - don't put a lot of faith in the locations. If the roads that change overnight here in Texas are remotely correct - I'd be surprised.
    At any rate, even if I got a year-old database - it's gotta be better than the 5 year old one I replaced!
    krmcg likes this.
  8. krmcg
    2,592
    2,392
    Whittier, CA
    I received and installed my map update today. Purchased mine through eBay. It installed without incident, but is not current by any means. Map Version is 05-39-50 dated 2019-04-0. It also shows an audio update of 0101A0, dated today...
    So probably not "current", but definitely an update from the OEM maps from 2016. For $30.00 I'm not complaining.
    Valiant V likes this.
  9. Valiant V
    Valiant V Member
    239
    161
    Winnsboro, TX
    I've found Amazon sellers to *generally* be better than eBay. Sounds like you go the "update" that's a year older than the one selling on Amazon.
    In some places - like out on an established interstate - or in downtown Chicago - it probably doesn't make much of a difference. Around where I am - seems that the highways between me and Dallas change every couple of weeks.... Can't really trust any fixed "database" in that case. Google Maps is the way to go.
    jerrymildred and krmcg like this.
  10. PriusRos
    1,973
    218
    Rockville, MD
    The map sd I bought from eBay for $31 is labeled 86271-0E072, which is exactly the same as the ones sold on Amazon for $20 more (which says it's the latest update). The actual map version according to the onscreen map data is April 2019. However, the latest version is actually 86271-0E073, which can be found at online Toyota parts stores for around $150 - $180, as well as on eBay for the same prices. I believe that updates are usually released around September. I feel that it's deceptive of eBay and Amazon to be advertising the 2019 version as the latest when it isn't.
    For the price I don't really mind that it's a year out of date as long as it the genuine program and not a hack - but they should be honest about it.
    #30 PriusRos, Jun 2, 2021
    krmcg likes this.
  11. Valiant V
    Valiant V Member
    239
    161
    Winnsboro, TX
    There are several on Amazon - not sure which one you are referring to. The one I got was $34.99 and is map version is April of 2020 when you look at the "Map Data" screen. Like I said - I don't know if the "latest" version is gonna say April 2020 on the screen, or if it will have a later date. If they come out around September as you're saying - then a map data of April 2020 IS the latest version.
    That being the case - I'm happier than I was before!
    krmcg likes this.
  12. PriusRos
    1,973
    218
    Rockville, MD
    You are lucky to have the 2020 version for that price! Do you have the serial number that's printed on the SD card? It would probably be on the Amazon item description too. The one I saw on Amazon and the one I bought from eBay were both marked 86271-0E072. The Map Data screen showed 2019. I spent a long time searching before I found out that the current version is 86271-0E073, and all the sellers I found were charging $150+ for that version. (They charge $230 at Toyota dealer).
    Valiant V and krmcg like this.
  13. Valiant V
    Valiant V Member
    239
    161
    Winnsboro, TX
    I didn't record the serial number from the SD card, I do still have the packaging kicking around someplace. It DID look to be legitimate OEM - though to be fair - I've seem some pretty convincing knock-offs.
    Pretty sure my dealer quoted about what you're saying - $200-ish, and I did see the online dealers asking ~$150. (Which is why I tend to be suspicious. For all we know these genuine, latest version products for only $35 - "fell off a truck" somewhere....)
    For "software" - I'm very leery of eBay. I bought a copy of MicroSoft Office once - and it turned out to be a counterfeit version. Albeit a very well-done one. Ebay/PayPal were good at getting my money back, and MicroSoft even gave me a deal on a legitimate copy for reporting the fraud.
    Amazon's not perfect of course, but they do have a lot more safeguards in place if you buy things that are "fulfilled by Amazon". That said, I've seen customers game the system by buying a product - then returning it saying it was defective while it wasn't. I've even seen a customer buy a genuine product - and replace it with a knock-off and return it and claim a refund.
  14. PriusRos
    1,973
    218
    Rockville, MD
    I'm very curious about this. Can you look up your order on Amazon and tell me who the seller is? The description should also list the product #. You might have just got lucky!
  15. jerrymildred
    11,517
    14,149
    Tampa, FL
    They are building around our area and to the east faster than even Google Maps can keep up with. It's insane.
  16. PriusRos
    1,973
    218
    Rockville, MD
    My SD card has the same version info as yours.
    krmcg likes this.
  17. Valiant V
    Valiant V Member
    239
    161
    Winnsboro, TX
    Says "IWONA Store"
    Says its an "86271-OEO272"
    I'm thinking the product got updated but not the description.
    Says
    • Release Date: 10/2019 - Map 2019-2020 Update
    which doesn't make a lot of sense to me....
    Here's the listing:
  18. PriusRos
    1,973
    218
    Rockville, MD
    This is so weird. My SD card looks almost identical front and back except I think the QR code looks different (can't quite tell) and there's no number under the EE on mine like there is on yours. You really got lucky if you got the 2020 version instead of the 2019 - for a fifth of the price!
  19. PriusRos
    1,973
    218
    Rockville, MD
    V Valiant thanks for posting the info.
