Best options for adding Bluetooth audio?
Discussion in 'Gen 3 Prius Audio and Electronics' started by justice sommer, Mar 22, 2018.
  1. justice sommer
    justice sommer Junior Member
    Los Angeles
    I
    I'm planning on buying a 2010 Prus this weekend (my first Prius). It's the base model so no screen/backup camera and no Bluetooth audio.
    Bluetooth audio is a must-have for me. So, I'm wondering what the best way to go about adding Bluetooth integration is. I've seen a number of third-party products that integrate Bluetooth into the existing head unit by emulating a CD changer (I think). That seems pretty slick.
    But I'm wondering if I should look at swapping to a different factory head unit instead. Or if there are any aftermarket head units that the Prus community especially likes.
    Thanks
  2. Grit
    Grit Senior Member
    6,454
    4,188
    Wilkes Land
    Buy a Bluetooth transceiver or receiver, and hook it up to the 3.5" jack in the arm rear console so it's hidden. Audiophiles will want Bluetooth 4.1 or higher when audio source is lossless. I connect my audio that way from my phone.
    douglasjre likes this.
  3. justice sommer
    Los Angeles
    I
    Thanks for your input, but I'm looking for more advanced options. A dongle will "work", but they require charging or a power cable from the power port. Also, you cant use the steering wheel controls (pause/play and track skip) with a dongle.
  4. FrankB
    FrankB Member
    117
    53
    The best option in my opinion is to put a 57031 head unit in (assuming you are do not have JBL). The color does not match but it gives you bluetooth, iPod/USB and a nice display. One downside is that unless you add a microphone, bluetooth phone calls do not work.
    You'll need an antenna adapter and move one wire from a harness to the antenna adapter.
  5. justice sommer
    Los Angeles
    I
    Really? You suggest the OEM head unit vs an aftermarket head unit? The Android head units seem pretty cool
  6. FrankB
    FrankB Member
    117
    53
    The Android head units are of questionable quality in my opinion. The OEM should last for the life of the car. I would trade features for reliability since the OEM has enough to satisfy me.
  7. justice sommer
    Los Angeles
    I
    Are you sure the 57031 will fit/function in a 2010 prius?
  8. Erik Owens
    Erik Owens Member
    162
    59
    Research BLU Logic. They use to sell the bluetooth telephone accessory back in the day. Ive never seen one but cant hurt to see if they still sell them. Instructions are pretty good most the time with our accessories.
  9. Grit
    Grit Senior Member
    6,454
    4,188
    Wilkes Land
    I see. That wasn't something I knew before hand.
  10. Erik Owens
    Erik Owens Member
    162
    59
    Whoops wrong reply
  11. Grit
    Grit Senior Member
    6,454
    4,188
    Wilkes Land
    Search results returned with e-cigarettes and water filters :whistle:
  12. Erik Owens
    Erik Owens Member
    162
    59
  13. Grit
    Grit Senior Member
    6,454
    4,188
    Wilkes Land
    The part you posted doesn't have prius listed on compatible list.
  14. Erik Owens
    Erik Owens Member
    162
    59
    Ok then. I guess you are out of luck and you are welcome.
  15. FrankB
    FrankB Member
    117
    53
    I have a 2010 Prius 2 without JBL and I have a 57031 installed in my Prius.
    See this and this.
  16. scona
    scona Active Member
    225
    206
    Courtenay, BC, Canada
    2013 Prius v wagon
    If Bluetooth is a must have perhaps consider buying a vehicle that has it?
    taxibuddy and Erik Owens like this.
  17. Erik Owens
    Erik Owens Member
    162
    59
    I love it. My thoughts too but people get sensitive now these days, lol.
    scona likes this.
  18. justice sommer
    Los Angeles
    I
    Good thinking. I want one of those massaging shower heads in my shower too. Guess it's time to buy a whole new house that has one. Ha ha
  19. Erik Owens
    Erik Owens Member
    162
    59
    Because it is exactly the same genius. :ROFLMAO:
    scona likes this.
  20. justice sommer
    Los Angeles
    I
    Good info. Thanks a lot for that
