Best result with gasoline brand
Discussion in 'Gen 3 Prius Fuel Economy' started by garylow, Feb 25, 2012.
  1. El Dobro
    El Dobro A Member
    7,106
    3,282
    I believe that was the Westville Sunoco refinery.
  2. firecracker_rc
    firecracker_rc New Member
    65
    San Diego
    My first car was a long-time pass-around hand-me-down 1975 Pontiac Ventura, brown. I didn't mind it's age or lack of luster because it was Free. :) Anyway, point is, that car taught me something about fuel. It ran fine on any fuel except Arco. If I used Arco the valves would rattle loudly and it would lose power upon acceleration and driving up hills. When I got a new used car, I decided that even though it didn't have the same effect, I wouldn't use it in case it might cause undo ware or damage over time, knowing how it affected my more sensitive older former car.
  3. SuperchargedMR2
    SuperchargedMR2 Diehard Rams Fan
    674
    179
    Vancouver, WA
    True....but there is more then just the mileage reason concerning fuel. Just because the OP didn't ask for it doesn't mean it's not a good reason to discuss it. :D
  4. garylow
    garylow Junior Member
    16
    new jersey
    Thank you for the feedback. I decided with my 96 camry that had 220700 miles on it before i traded it for the Prius that the few cents saved with cheap gas didn't pay. It did get better mpg with brand gas. i also think the additives help keep the engine clean. I did once get poor mpg with BP and think it has a batch of bad gas. To save 3 cents a gallon might be saving me 30 cents doesn't pay. I seem to be getting at least 51 mpg in NJ in the fairly mild weather we have been having lately. Last fillup up was calculated at 52.9 or 57 on the computer.
  5. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    Not exclusively because the OP also asked " Does it pay to use the cheap stuff or stick with big brand names?"...
    I took that to mean is there any benefit to using "Top Tier" vs. Cheap Stuff...
    Which opens the whole can of worms and everyones personal gasoline buying beliefs and rituals....which usually means everything eventual de-evolves into .....do what you want...
