Best Source for NEW Brake Actuator
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by sas0611, May 23, 2022.
  1. sas0611
    sas0611 Member
    230
    Hi. I will probably be needing to replace my brake actuator soon (44500-47141). My local dealer gave me a price for part of $1819.19 - I think that included tax. Where can I find the best price on new one. Has anyone purchased this part new lately and/or can recommend where the best pricing could be obtained.
    Thanks in advance folks-
  2. dolj
    dolj Senior Member
    7,741
    3,919
    Wellington, New Zealand
  3. alftoy
    alftoy Senior Member
    1,132
    510
    Saskatchewan, Canada
    Lots of ABS actuators available used 44510-47050 if you decide to go used, is 44500-47141 the part number on your actuator or is it the number from the dealer or parts.toyota.com for your vehicle.
    My 2008 listed part is 44500-47141, but looking at my ABS actuator the part number label is 44510-47050, you can see the number by looking behind the inverter cover. Area to look circled in red, barely see the white label circled.
    A discussion on the different part numbers.
    2007 Prius - Brake, Brake warning (!) ABS and VSC lights ON | Page 2 | PriusChat
    #3 alftoy, May 23, 2022
  4. dolj
    dolj Senior Member
    7,741
    3,919
    44500-47141 replaces 44500-47140 and is the correct part for a 2008.
    Personally, I would not buy a secondhand one, especially the 44500-47140 variant. Secondhand they are not cheap enough to make the risk worthwhile and like a box of chocolates, you don't know what you might get.
  5. alftoy
    1,132
    510
    Tampaprius.com installs used for $800, 6 month warranty according to the link above and below. Maybe jerrymildred can chime in seeing as he works for Tampaprius.
    Price in Canada for 4450047141 is $2000, I can get an ABS actuator used for $200, think I'll try the $200 part for now. Considering I only paid $1100 for the Prius, don't think I'll spend $2000 for the part.
    4450047141 - Toyota Modulator. VALVE. ABS. ACTUATOR. BRAKE | Scarborough Toyota of Canada, Scarborough Ontario
    #5 alftoy, May 23, 2022
  6. dolj
    dolj Senior Member
    7,741
    3,919
    The best price currently in the US is $1134.
    I'd imagine the new part number will have been updated with the learnings from the recall, so I'd be wanting that part (new or secondhand) if I had to replace it.
