Best Spark Plug Replacement for Gen4?
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by Mavi, Feb 20, 2018.
  1. Mavi
    Mavi Active Member
    484
    285
    San Diego,ca
    2020 Prius Prime
    #1 Mavi, Feb 20, 2018
  2. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    #2 JimboPalmer, Feb 20, 2018
  3. Mendel Leisk
    41,925
    #3 Mendel Leisk, Feb 20, 2018
    m.wynn and RCO like this.
  4. booke02
    booke02 Active Member
    391
    415
    Israel
    Handbook says to use only iridium plugs.
  5. Mavi
    Mavi Active Member
    484
    285
    San Diego,ca
    2020 Prius Prime
    Awesome, thanks for the part number... much cheaper to get them via that method. I was looking up by the Denso number and they cost 18 a piece plus tax and shipping. If anyone uses different iridium plugs with good results post them below but other then that! Problem solved!
    #5 Mavi, Feb 20, 2018
  6. milkman44
    milkman44 Active Member
    591
    386
    Ky
    #6 milkman44, Feb 20, 2018
  7. Mavi
    Mavi Active Member
    484
    285
    San Diego,ca
    2020 Prius Prime
    Are the autolite or the denso 3499 performance and mpg wise more or less the same? Thanks for the tip.
  8. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    I suspect nobody knows (or wants to experiment!!) - I doubt if any Gen 4 have got to 200,000km (as mentioned by JimboPalmer).
    I'd consider putting genuine in if the price is reasonable - I'd assume TOYOTA tested something like that carefully as they wouldn't want them to fail before the 200,000km.
  9. Prodigyplace
    12,683
    11,833
    Central Virginia
    They may be purchasing soldierguy's old car. I doubt many 2016 Prius in California have over 90K miles already.
    krmcg likes this.
  10. Prodigyplace
    12,683
    11,833
    Central Virginia
    I just verified the 2017 uses those same plugs so the 2016 should use them too.
  11. Prodigyplace
    12,683
    11,833
    Central Virginia
  12. Mendel Leisk
    41,925
    Genuine is the aforementioned Denso. Toyota does assign it a Toyo part number, but it's a Denso plug, just like tires.
    m.wynn and Prodigyplace like this.
  13. Mavi
    Mavi Active Member
    484
    285
    San Diego,ca
    2020 Prius Prime
    I just picked up one for my dad over in San Diego , 96k miles 2016. Which is why I'm asking.. I'll be postponing purchase of the plugs till 120k as it doesn't seem to be needed as of yet :) Will check again then.
    amos and Prodigyplace like this.
  14. Prodigyplace
    12,683
    11,833
    Central Virginia
    I was referring to the user here who started this thread. He traded in his Prius with over 90K miles for a VW Diesel.
    Super-Commuter & high mile thread | PriusChat
  15. Kenny94945
    Kenny94945 Active Member
    858
    433
    Sausalito
    2016 Prius v wagon
    Yes appears Iridium plugs.
    Many brand choices, yet staying with OEM insures correct reach and heat range.
    Iridium is good for 100K mileage, wear would show with a gap measurement.
    Your plan to change at 100K is perfect IMO.
    FWIW copper conducts electricity better than exotic metals.
    But then you need to change plugs ever 25K mileage.
    I would replace with OEM plugs and call it a day.
    Good luck with your decision.
    RCO likes this.
  16. milkman44
    591
    386
    Ky
    I replaced my original plugs at 140,000 with Denso Iridium. At 180,000 I started getting a missfire at idle, after checking, I found that the plugs had fifty to fifty five thousandth gap and there was no iridium tip on the ground electrode. I didn't have a way to the parts store, so I reinstalled the original plugs and still working fine. The gap on the original plugs is still good so I'll get around to replacing the originals if they start missing.
    RCO, krmcg and Lucifer like this.
  17. alanclarkeau
    7,045
    7,593
    It says somewhere not to adjust the gap - which is contrary to anything we've done over the past 100+ years, but they seem to work fine that way. Which is a good reason to buy OEM, as you'll be guaranteed (hopefully) they're to specification in the first place.
    RCO likes this.
  18. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    Yes, a fair amount of the necessary advice on Prius chat is 'Don't do it like it was 1968, do it like it is 2018"
    Iridium must not be very malleable.
    Wikipedia says "Iridium is a chemical element with symbol Ir and atomic number 77. A very hard, brittle, silvery-white transition metal of the platinum group, iridium is the second densest element (after osmium). It is also the most corrosion-resistant metal, even at temperatures as high as 2000 °C.
    Resisting corrosion sounds good but brittle is going to rule out gapping the plugs.
    RCO and alanclarkeau like this.
  19. padroo
    padroo Senior Member
    2,763
    2,252
    I don't have facts but I think just the very tip has the iridium on it, the part you always bent is the same.
    RCO, milkman44 and Mendel Leisk like this.
  20. alanclarkeau
    7,045
    7,593
    Bosch's website says "Iridium spark plugs can reduce voltage demands by 24%, leading to a longer spark plug life." I can't see where they first started being used, with Platinum preceding them, but it seems aviation were the first users.
