Super-Commuter & high mile thread
Discussion in 'Gen 4 Prius Main Forum' started by soldierguy, Oct 1, 2017.
  1. soldierguy
    soldierguy Active Member
    108
    245
    Maryland
    I was thinking...it might make sense to have a super-commuter / high mileage thread. A lot of people use these cars for commuting, and I'm surprised at how many people I've run across have long-distance commutes. Before I bought my Prius, knowing I had a long commute, I was all over these forums looking for info about potential problem areas as the miles rack up. So, I figured I'd start a thread where anyone who is racking up lots of miles can post, or anyone who has questions about racking up lots of miles can post. Might make for a decent repository of information for people who rack up high miles.
    So I'll start. I'm a super-commuter. There's no agreed-upon definition of super-commuter, but I'm pretty sure I fall into that category. Five days per week, I drive to and from work, just like most people do. But I happen to have to drive 220-230 miles round-trip every day to get to and from work. The range of 220-230...that depends on whether it is a gas day (gotta fill up every other day), where I fill up, whether or not I stop to run errands on the way home, which route I take at the tail end of my drive home (depends on traffic).
    I bought my Prius Two Eco on Sunday, 1 May 2016, and started driving it to and from work the next day. As of yesterday (30 Sep 2017), I've got right about 77,100 miles on it, for a monthly average of 4535 miles, and a daily average of 208 miles...a little less than my stated commute distance, but I do take days off from work now and then, which knocks my daily average down a bit from what I actually drive. The commute is all highway, except for the first few and last few miles. My house is at about 150 ft elevation, and my work is around 1500 feet, and there are no major hills in between. I typically get on the highway and set the cruise control for somewhere between 68 and 75 mph, depending on time of day, weather, traffic, etc. I typically don't run into much traffic, but I do have the occasional moments of having to stab the brakes then nail the gas, usually in response to farm trucks. The prevailing weather patterns hurt my highway fuel economy...I can run to the bay area and get mid to upper 50's running the same speeds I do on my commute, but I'm currently averaging a little below 50 mpg, with a lifetime average of 50. Every day, I have no wind or a minor headwind going to work (usually no more than 5 mph), and a strong headwind (15-30 mph) going home. That headwind definitely hurts my fuel economy. Temperatures...I get some wild daily swings. It's pretty mild where I live, but where I work often sees a 50+ degree daily temperature swing. Typical summer day: 50-55 degrees when I leave for work in the morning, 105+ in the afternoon when I leave work, 65 degrees when I get home. Winter: 48 degrees when I leave for work in the morning, 30 degrees when I arrive at work, 60 when I leave for home, and 60 when I get home.
    Fuel economy: I've already talked about it, but for the thread skimmers, it's sitting at 50 lifetime, with the recent average being a little lower due to the tires I put on 32,000 miles ago.
    What's gone wrong with the car? Nothing. No check engine lights, no unexpected stops at the dealership, no burned out lights, nothing at all. I've replaced the wiper blades once, and I'm on my second set of tires (which reduced my fuel economy, but also reduced noise). I've not had to add any oil, although I go through a lot of windshield washer fluid. Seats are still in good condition...no tears, no fading, no strange wear on them. No new rattles...any rattles arrived before I hit 5000 miles, and no new ones have appeared.
    Impressions of using the car as a long-distance commuter:
    - Seats are comfortable (for me), and if you're tall, they go back farther than on many other cars.
    - Wind noise is reasonable, as is road noise, and road noise is better since replacing the stock tires.
    - I despise the climate controls....WAY too fussy. It takes far too many buttons / switches to push to get the system to do what I want, and causes me to look away from the road FAR too much because sometimes the system decides to do something different than what I'm telling it to do. Three knobs and a two or three buttons could do a much better job than the 8 buttons and 3 switches of the ergonomic mess Toyota vomited onto the dash of the Prius. If I trade it in unexpectedly, I'd bet a paycheck that it'll be because I despise the climate controls. It really is that bad, because it takes my eyes off the road for way too much time. It irks me so much that if Toyota still has this needlessly complex hot mess on the dashboard when I'm ready to get another car, I'll pass on getting another Prius.
    - I'm not a fan of touch screen infotainment systems. Toyota needs to ditch their proprietary system and start offering Apple Car Play / Android Auto. They need to do this yesterday.
    So other than the climate controls and the infotainment, I like the Prius, and it works well as a super-commuter. If anything goes wrong with the car, I'll be sure to post about it, but so far, it just keeps going...
  2. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    I'm not a Super Commuter by any stretch - a retiree enjoying my PRIUS.
    I don't really mind the Climate Control - I generally let it do it's own thing, sometimes adjusting the temperature up/down, but most days don't touch it.
    BUT - I wholeheartedly agree "... I'm not a fan of touch screen infotainment systems. ...". I'd also say the phone interface which won't work when you're moving - so even your passenger can't use it either is just plain DUMB!!!! Meaning you have to pull up on the side of the motorway momentarily while you select someone from your phone list - then drive off again. If I knew how bad it was before I bought the PRIUS, I probably would have gone for something else.
    douglasjre, soldierguy and RCO like this.
  3. Raytheeagle
    Raytheeagle Senior Member
    11,267
    15,526
    Bay Area, California
    2019 Prius Prime
    That's a long commute. Where in the great state of CA do you do this commute?
    We own a 2010 Prius II with 163 k miles on it and going strong. In the Gen4 they changed the location for the egr return to after the catalytic converter where on the Gen3 it is before. This leads to clogging up the cooler and small intake ports:(.
    I cleaned out egr cooler and intake system out at 120 k miles and it was coated in carbon deposits. My curiosity lies in what this change in design might look like after 120 k miles or so. Sounds like you might be one who gets there soon:).
    Good to hear these have been trouble free miles so far(y).
    amos and m.wynn like this.
  4. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    I agree with you both. Toyota certainly engineered some design faults into the infotainment and HVAC controls but I love this car despite its nagging faults.
  5. soldierguy
    108
    245
    Maryland
    Congrats on your retirement! I'm retired from the Army, but now work for them as a civilian...less hassle and more money!
    I can't leave the climate control alone. My days usually start with the defroster, then I switch to slightly warmed air aimed at me, or I shut it off entirely. Then the ride home starts with AC, but by the time I get close to home and pull off the highway, I like to shut the AC off, let outside air flow through the system on a low fan setting (helps avoid a moldy / smelly AC system), and ride with the windows down.
    @Raytheeagle, I live on the Monterey Peninsula, and work near Paso Robles...I drive up and down the Salinas Valley every day.
    RCO and Raytheeagle like this.
  6. soldierguy
    108
    245
    Maryland
    Funny you should mention the location of the EGR return pipe...I was kinda wondering whether it was pre- or post- cat. That has more of an impact on diesels and direct-injected engines, because the exhaust particles for both end up being larger than port-injected engines. I'd heard of Hyundai having an issue with EGR and intake pipes getting gummed up on their direct-injected engines. But it's good to know that it's post-cat...with any luck, the cat will clean up most everything, so less of a chance for things getting gummed up.
  7. Raytheeagle
    11,267
    15,526
    2019 Prius Prime
    On the Gen3s this is a significant issue (or some will say design flaw):(.
    Not sure where the egr cooler is located on the Gen4 , but to get the egr cooler off of a Gen3 you need to remove the windshield wiper cowling to access the back bolts.
    But this would be a good data point if you're willing:). Since you're kinda in the Bay Area, you might have some willing to participate :whistle:.
    I know the info would be useful for me on our next purchase(y).
    amos, m.wynn, SFO and 1 other person like this.
  8. alanclarkeau
    7,045
    7,593
    Oh no - doesn't it mess your hair? :) ;) :( :mad:
    soldierguy likes this.
  9. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    If he's a gal, yes! But if she's a man. Not so much.
    The jury's still out at my terminal. (n). Doesn't keep me awake at night, but it's kinda exciting for me. I lead such a quiet life these days!
  10. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    I'm no super commuter, I've only clocked 5,000 miles in 18 months, maybe I should get out more. :oops:
    pilotgrrl, soldierguy and RCO like this.
  11. Tideland Prius
    16,678
    @Mendel Leisk might know. He posted in a Gen 3 thread on cleaning the EGR.
    amos and Raytheeagle like this.
  12. Raytheeagle
    11,267
    15,526
    2019 Prius Prime
    I've done the cleaning of the egr system 3 times on different Prii;).
    Would like to see if this improves on a Gen 4(y).
    amos, m.wynn, Mendel Leisk and 2 others like this.
  13. Tideland Prius
    16,678
    I was referring to the Gen 4 location. You were asking about it. I recall him mentioning something. I know I posted a picture but i have no idea where it is lol.
    Raytheeagle likes this.
  14. Raytheeagle
    11,267
    15,526
    2019 Prius Prime
    Pretty sure it is in the same location on the drivers side of the block. But the intricacies of removal are of interest to me;).
    And I'm willing to contribute my labor to find out:).
    Knowledge is power(y).
    m.wynn, Mendel Leisk, SFO and 2 others like this.
  15. Tideland Prius
    16,678
    Ahh ok. Ignore me then lol.
    Prodigyplace and Raytheeagle like this.
  16. Raytheeagle
    11,267
    15,526
    2019 Prius Prime
    You're hard to "ignore";).
    I "like" your input and knowledge(y).
    If you could only help the Admin more so the site doesn't go wonky:whistle:.
    Prodigyplace, SFO, RCO and 1 other person like this.
  17. Mendel Leisk
    42,323
    There must be a few gen 4 approaching 100k miles? Time to have a look? I'm betting it's a bit cleaner.
    m.wynn and Raytheeagle like this.
  18. Raytheeagle
    11,267
    15,526
    2019 Prius Prime
    I'm hoping to get some data as when I usually bet, I roll snake eyes:sick:.
    RCO and Mendel Leisk like this.
  19. Mendel Leisk
    42,323
    About 1/3 of the way down this page:
    2016 Toyota Prius Review – Video
    There's decent view of 4th gen EGR, and click on it for much better res version, suitable for downloading.
    Here's a screen grab:
  20. Raytheeagle
    11,267
    15,526
    2019 Prius Prime
    Thanks for the link and snip:).
    I bet the new coolant hose orientation makes removal a bit more fiddly :(.
