Best spark plugs for 05 Prius
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by shepdawg, May 14, 2014.
  1. douglasjre
    douglasjre Senior Member
    2,250
    751
    Null, NL
    Chinese fakes from Amazon will grenade your engine
    Metrolens likes this.
  2. T1 Terry
    T1 Terry Senior Member
    976
    552
    I very recently replaced both the plugs and coils on my V10 6.8 ltr Ford chassis motorhome. Near fell off my rocking chair at the cost, the plugs were more than the coils :eek: ...... but chalk and cheese on the first hill, and even on start up. The old ones had done 176,600 kms (roughly 110,000 mile).
    Remember to put some thread lubricant on the plugs befor you install them, they will be there for the next 100,000 miles so you don't want the thread coming out with the plug .....
    The gen 2 1500 goes for ever, if you look after it, my ex taxi Prius had 750,000kms on it, it wasn't the motor that took it off the road, needed parts for my other Prius on a holiday weekend where no one had front pads and rotors .... then the new NiMh battery got transferred to the other Prius ..... and that was about the end of it going back on the road ....
    T1 Terry
  3. Mendel Leisk
    42,389
    Not knowing for sure if they’ve ever been changed, yeah change them. Instead of gambling to save a few bucks, get them from dealership or reputable, local auto supply place. Stick to the stock plug (spec’d in owner’s manual, and attached).
    Repair Manual makes no mention of lube, and it complicates things, specifically torque.
    You can check the gap, but the plug manufacturers recommend to not adjust. If it’s off they might have been dropped or something.
    In particular when installing the new plugs, if you’ve got an especially grippy spark plug socket, it’s prudent to tape the extension to socket, otherwise the socket may stay on the plug when try to pull it off.
    #23 Mendel Leisk, Aug 14, 2025
    douglasjre and Metrolens like this.
  4. T1 Terry
    976
    552
    Non lubricated threads can affect torque reading, but not lubricated threads, the torque for tightening anything is based on clean lubricated threads ...... that includes wheel nuts/studs, lubricated threads or the taper being lubricated has nothing to do with the nut/stud remaining tight, it is the applied clamping effort and that can only occur with clean lubricated threads
    T1 Terry
  5. dolj
    dolj Senior Member
    8,657
    4,408
    Wellington, New Zealand
    The threads on spark plugs (Denso and NGK, at least) are lubricated at the factory, so there should be no need to add more.
  6. T1 Terry
    976
    552
    I just fitted 10 NGK Iridium plugs in my V10 6.8 ltr motorhome, and I can assure you, they were not lubricated from the factory ..... in fact, I don't think I've ever seen a pre lubricated spark plug, and I have fitted thousands, I had a dyno tune business for 12 yrs, 10 to 12 car a day through the dyno, 6 days a week, 4, 6, 8 cyl ..... that's a lot of spark plugs .....
    T1 Terry
  7. dolj
    dolj Senior Member
    8,657
    4,408
    The lubrication is not noticeable, but the threads, for sure, are not dry.
  8. Mendel Leisk
    42,389
    Maybe just terminology tripping us up. If I google:
    do denso or ngk recommend to lube spark plug threads
    the AI summary commences with “No” and cites various reasons.
  9. Hayslayer
    Hayslayer Active Member
    541
    331
    You're a bit behind the times with spark plugs. Absolutely DO NOT lubricate the threads of a spark plug when installing. The coating on the threads is specialized and no lube is required. here's an example from NGK. Other brands are similar.
    1. Anti-seize
    NGK spark plugs feature trivalent plating. This silver or chrome-colored finish on the threads is designed to provide corrosion resistance against moisture and chemicals. The coating also acts as a release agent during spark plug removal. NGK spark plugs are installed at the factory dry, without lubrication or anti-seize.
    Anti-seize can act as a lubricant, altering torque values up to 20 percent, increasing the risk of spark plug thread breakage and/or metal shell stretch. Thread breakage can sometimes involve removing the cylinder head for repair. Metal shell stretch changes the heat rating of the spark plug and can result in serious engine damage caused by pre-ignition. Do not use anti-seize or lubricant on NGK spark plugs. It is completely unnecessary and can be detrimental.
  10. xw20_driver
    xw20_driver Member
    118
    59
    PNW
    If anti seize has been used previously, how would one clean the threads in the head without taking the head off? Can something like carb cleaning spray be used? Or just let it be and don't add any more AS compound?
  11. Mendel Leisk
    42,389
    Pragmatic first thought: any previous lube has long since baked to bone dry.
    that aside, screw in an appropriately sized bottle brush, apply a couple of short shots of carb cleaner, then screw out the brush.
    #31 Mendel Leisk, Aug 15, 2025
  12. T1 Terry
    976
    552
    The You Tube channels are full of cases where the thread comes out with the spark plug because the aluminium has bound to the plug thread metal. Wurth Industries actually make a plug thread replacement tool for just that sort of problem, I can't imagine a company that big and selling worldwide to the industry, actually designing and developing a toll for a problem that didn't exist.
    In an industrial application where aluminium parts bolting is used, they fit a helicoil thread in at the point of manufacture, to avoid this thread binding occurring.
    If the spark plugs are not going to be removed for 100,000 mile, I certainly wouldn't be taking the risk, no matter how many articles an AI has viewed ..... Keep in mind, my ex taxi Prius had 750,000kms on the clock, it had done a lot more but not recorded with the dreaded blank instrument cluster problem, it had never had the head off, no snapped plugs and never pulled the plug threads ..... when I pulled the plugs after we had put 160,000kms (100,000 mile) on it ourselves, the lubricant darkness on the threads was clear evidence, the taxi company didn't believe the AI stuff either.
    Up to you, I'm guessing very few change their own sparkplugs or keep the vehicle long enough to know if there was a sparkplug thread problem after the second 100,000 mile if they did change their own sparkplugs .....
    T1 Terry
  13. dolj
    dolj Senior Member
    8,657
    4,408
    I don't doubt this problem exists, but I am not convinced it is because people are following the manufacturer's advice to not add lubrication to the spark plug threads.
    Have you considered that it might be the addition of additional lubrication or anti-seize that is the problem? Did you read the post above quoting advice from NGK? Note especially the second paragraph.
    I'm sure you probably will not change your belief, but others reading this post later might.
  14. T1 Terry
    976
    552
    As I said, up to them, I'm going on personal experience with 40 yrs hands on in the trade ..... I've also read the "pre-gapped" advice the plug manufacturers advertise, can't really argue with that, they generally do have a gap between the electrodes, just rarely the correct gap nor consistent through a box of 10 spark plugs ..... one of those basic lessons I taught every apprentice that went through the workshop, pick any box of plugs you like, check the vehicle manufacturers specs for plug gap and see how many plugs in the box are set to that gap, measure the gaps and record what the gaps were across the 10 plugs ..... a wakeup call to each smart arsed apprentice, pay attention to the little things, the big things will look after themselves ......
    T1 Terry
  15. Mendel Leisk
    42,389
    In the last couple of decades I’ve checked new spark plug gaps on maybe 10 cars at most, never encountered any out-of-spec. If they were I’d suspect damage, return it. It is good to check, only takes a minute.
    douglasjre likes this.
  16. Metrolens
    Metrolens Member
    215
    So from all of this, it sounds like I should expect to encounter trouble removing the old spark plugs? Again I believe they are the factory installed plugs (190,000 miles, 2005 Gen 2)?
  17. T1 Terry
    976
    552
    Look at the threads, are they black or silver? Is there any sign of aluminium being picked up in the threads?
    T1 Terry
  18. Metrolens
    Metrolens Member
    215
    Might be a dumb question, but is it even possible to see the threads, and determine whether they're black or silver, while the old plugs are still installed in the car?
  19. T1 Terry
    976
    552
    I'll amend the post .... look at the threads on the old plugs when they are removed, are they black or silver? Is there any sign of aluminium being picked up in the threads?
    T1 Terry
