Best strategy for a long cruise down hill
Discussion in 'Gen 4 Prius Main Forum' started by mudworm, Sep 7, 2018.
  1. mudworm
    mudworm Member
    84
    99
    SF Bay Area
    2018 Prius
    I understand that our driving habits can affect fuel economy, life expectancy of the vehicle, and our enjoyment of the experience. The balance might change under difference circumstances. It usually comes to us intuitively. However, there is one situation I am not too sure what the right balance should be after having been driving my Prius for two month.
    On my daily commute is an up and over a ridge. Usually, when I reach the summit, my battery is half full. My question is about my way down. In one direction, the long way down (about 7 miles, or 11km) is a well constructed curvy smooth road. With my old CR-V, I could cruise the entire way down barely touching the brake at all, and it keeps at a good speed and is a very enjoyable ride. However, with my Prius, if I just let it cruise, the battery fills up half way down. That means, in my understanding, that the rest of the way down, the cruising action will try to overcharge the battery. That's not good, right?
    I have tried to tap on the accelerator when I can just to see energy flow from battery to the wheels. That means I speed up my "cruise" down hill. I do it when it's safe and it does delay the full charge a little bit.
    From a previous discussion, I learned that the B mode is for long downhill so that the mechanical brakes (or was it engine braking?) are employed without overcharging the battery from braking. However, because I really do not need to brake much on this cruise down hill, I have a feeling that the B mode does not apply here. Or I wonder if B mode will unnecessarily puts stress on my brake rotor or engine.
    I'm not sure what my best strategy should be to reach a good balance between fuel economy, car longevity, and enjoyment in this situation. Any insights?
  2. GadgetVirtuoso
    Fort Worth, TX
    2018 Prius
    The system is more intelligent than that and will not "overcharge" the battery as you say. That energy just isn't captured and goes to waste. It's a lot like your phone, the circuitry knows when the battery is full and stops charging it, even if it remains plugged in. It doesn't keep charging the phone until it catches fire.
    You could use B (engine braking) if you wanted but it doesn't sound like your drive requires that normally. Using B will allow you to drive more relaxed since as soon as you take your foot off the gas it will start braking for you. There's a section on this in the manual.
    By and large, the whole car is designed so you don't have to change the way you drive to get good gas mileage, but if you do you can really do very well.
    mudworm likes this.
  3. fuzzy1
    10,691
    As GV mentioned, the car's charging system is smarter than that, and for protection, quits charging the battery. Otherwise, the provided battery warranty would be impossible.
    B mode uses engine braking, not the mechanical brakes. Try it, but don't necessarily take your foot off the gas pedal. Instead, apply just enough 'gas' to get the ground speed you want, i.e. use just a portion of the available B-mode drag. It isn't an all-or-nothing thing, you can control the amount, and also control the engine RPM so that it doesn't spin to banshee-screaming level. This will delay filling up the battery.
    (Of course, the engine isn't really burning any 'gas' in this mode when it is doing engine braking.)
    #3 fuzzy1, Sep 7, 2018
    jerrymildred and mudworm like this.
  4. mudworm
    mudworm Member
    84
    99
    SF Bay Area
    2018 Prius
    Ok, good to know that the continued cruise will not overcharge the battery. What throws me off is the Energy Indicator shows the flow going to (already full) battery for as long as the car is cruising.
    Since I have no good reason to slow down, or speed up, on that long down hill, I will not bother with B mode. I'm glad that it means I'll get to enjoy my foot off relaxing cruise again (just like with my CR-V) without worrying about burning up the battery or engine.
  5. fuzzy1
    10,691
    On my Gen3, there is a rounding issue on the battery SOC display. E.g. 7.5 internal bars rounds up to 8 displayed bars, somewhat before the limit is actually reached, so I see so regen still happening for a bit longer after the battery displays as full. But it will stop.
    I don't use the Gen3 energy flow screen because it is much less useful than Gen2 version. Gen3 shows the arrow flows even when the amount is negligible but non-zero, making it impossible to balance out to no arrows at some speeds when gliding. The Gen2 version will blank the arrows when 'close enough'. For Gen3, the HSI screen is much more useful. I don't have any experience with Gen4 displays.
    If the slope is shallow enough, D mode engine braking will be sufficient, and far more quiet than the full-on B mode engine braking.
    jerrymildred likes this.
  6. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    There has been a lot of discussion on this over the last 2½ years.
    I sense that Gen 4 actually goes into a form of "B" when the battery is full - as others have suggested, B seems not so necessary until: 1) the battery is full to the last (rarely used) bar; or 2) it it's a quite steep hill, I still have used B at that stage, and I had to use the brake pedal less.
  7. bbald123
    bbald123 Thermodynamics Law Enforcement
    386
    275
    Harrisburg, PA
    I have observed my Gen 4 using engine braking on its own when decelerating down hills with a full battery. My guess is B is only required when the "auto B" isn't enough to control acceleration and you don't want the friction brakes overheating.
    alanclarkeau likes this.
  8. Mendel Leisk
    42,306
    7 downhill miles is quite a stretch; I would experiment with B mode. I use it (with a 3rd gen) coming down our Mount Seymour (ski hill), that's about it. In stretches that are steep enough that I'm braking, I'll shift to B. Where it flattens out enough that I need to give gas, I'll switch back to D. Mostly I stay in B, all the way down. I keep the speed down too: the engine sounds more "alarming", the faster you go.
    The battery displays full by half-way down, but it appears to continue doing some charging all the way down; I've never noticed a precipitous shift over to friction brakes only, at least it's not apparent.
    Anyway to skirt it? I'm guessing no, but just a thought.
  9. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    No. Wrong.
    The "system" will take care of itself nicely.
    So will the cruise control, at least in my experience.
    Set your cruise for a safe speed . Hopefully the brakes won't be needed as that cancels the cruise and complicates matters.
    When "engine braking" kicks in there will be a lot of noise; perfectly OK.
    Manually switching to B mode isn't necessary because the cruise control will invoke it automatically.
    But use it if it makes you feel better somehow. It certainly won't hurt anything.
    Starship16 and krmcg like this.
  10. mudworm
    mudworm Member
    84
    99
    SF Bay Area
    2018 Prius
    Oh, no, no, no. This part in the mountain is my favorite part of the commute. On a beautiful weekend day, there are oftentimes more than a thousand motorcycles and cars (lots of high end sports cars) that come out for a drive on this road. Some of them go at unsafe speed and a few do lose control (and lives), but that's not the main point.
    Sorry I wasn't clear. By "letting it cruise", I meant I just leave my foot off either pedal and let the gravity take the car. This stretch of the road is so well built that it has just the right amount and mix of deep and shallow gradient so it is possible to drive without braking but it is not often that the car can built up insane amount of speed. That's how us commuters like to drive. When sometimes you follow a car and you see that they do not brake whenever a bend comes up, you know they are one of the locals and know how to take the curve safely. Cruise control at whatever speed does not work well on this stretch of the road.
    I wasn't complaining about this drive. And now that I know that cruising on a full battery will not have any negative impact, I will just go back to my day dreaming mode and enjoy my relaxed ride.
  11. FuelMiser
    FuelMiser Senior Member
    1,349
    929
    Monument, CO
    If you want to let the car use all its smarts, just set the cruise control to maintain the speed on the way down
    wgary, Starship16 and alanclarkeau like this.
  12. fuzzy1
    10,691
    As do prior generations.
    B and D use the same tools to limit speed downhill, but with different combinations and limits. D mode uses just mild regeneration until the battery fills, then switches over to mild engine braking. B modes uses regen and moderate engine braking simultaneously, then moves to hard screaming-banshee engine braking once the battery fills.
    Tests on my Gen3 found that D mode engine braking is limited to about 2000 RPM, fine for shallow descents but not anywhere near strong enough on some of the steeper hills. B mode will push up into the 2500-ish RPM range before the battery fills, then can climb up as high as 4600 RPM after the battery cuts out.
    On some of my highway descents, even B isn't strong enough, so I must manually add some friction braking, though vastly less than if B wasn't used.
    #12 fuzzy1, Sep 8, 2018
    Starship16 likes this.
  13. Mendel Leisk
    42,306
    There is a way to skirt this mountain, isn't there: you're just not letting on...
    Seriously, if there's two routes, and one avoids the climb/descent, I'd go for it. Daily hill climbs/descent do take a toll on the battery, and the engine; there's no free lunch.
    Same here, on my nemesis (Mount Seymour): B mode and braking, most of the time. I find when you use the brakes (in B mode) it sounds like revs go up more so (hey, if the car had a tach...); I'd speculate the computers detect that you're using the brakes, increase the engine braking correspondingly.
  14. kevinwhite
    kevinwhite Active Member
    333
    200
    Los Gatos Ca
    If you are using adaptive cruise control the system will use as much engine braking as necessary to control the speed.
    While recently traveling south on I5 from Oregon to California where there are long hills that drop a a few thousand feet the car I saw up to 4,700RPM used for engine braking while in 'D' with adaptive cruise control.
    The car did not go above my set speed (60-75mph) on any of the hills, even without me using the brakes or changing to B (which would disengage cruise control), I couldn't tell whether it also automatically used friction braking on the steeper sections.
    It worked very well and I didn't have to use accelerator or brakes for very long periods except when traffic or road conditions forced me.
    It may not be as aggressive when not in cruise control.
    kevin
    FuelMiser and Starship16 like this.
  15. mudworm
    mudworm Member
    84
    99
    SF Bay Area
    2018 Prius
    Nope. A ridge is a ridge is a ridge. The two possible detours adding either 13 or 25 miles, which I occasionally had to take during winters when MY road got closed in a storm, both involve going over the ridge with one being even steeper, My free lunch is the daily relaxation going with the flow of the road under beautiful redwood trees.
    That's not the way to drive on the windy mountain roads (not a highway). You either end up taking corners too hot, or annoying the heck out of everyone behind you by going slow on straight ways. And then, there are those people who brake at every corner. It's very easy to tell on this road an out-of-towner from a local by their driving style.
    Mendel Leisk and fuzzy1 like this.
  16. fuzzy1
    10,691
    I don't have an adaptive version of cruise control, but presume that it is still strictly traffic-adaptive, not curve-adaptive. ;) So I'd often end up tripping it out and needing to re-engage it frequently.
    krmcg likes this.
  17. alanclarkeau
    7,045
    7,593
    Yes, as long as you've got a car in front, that works well (as long as you're happy with the speed they're driving).
  18. mudworm
    mudworm Member
    84
    99
    SF Bay Area
    2018 Prius
    Another theory that sounds good, but nope, it's not going to work. Most of the time, you don't have anyone around you. When you do have someone in front of you, you don't tailgate because that's rude. The cruise control sensor will lose the car as soon as it goes around a bend, and there are 176 bends on my up and over stretch in the mountain.
  19. Starship16
    Starship16 Senior Member
    1,348
    1,455
    Beach Christmas
    I just drive it.
    In my mind, the Prius is no different than any other car I drove. When going down a long hill I take my foot off the gas.... and press the brake pedal occasionally and the car starts to slow down.
    Give me some good old fashion "friction brakes" any day! That fancy "regenerative" stuff never slowed me down... it just recharges the battery.
  20. FuelMiser
    1,349
    929
    Monument, CO
    I was talking about your particular drive, where you said in your original post that you used to drive your CR-V comfortably barely touching the brakes. You were asking how to drive the Prius down the same route and I gave my answer.
