Best strategy for a long cruise down hill
Discussion in 'Gen 4 Prius Main Forum' started by mudworm, Sep 7, 2018.
  1. kevinwhite
    kevinwhite Active Member
    333
    200
    Los Gatos Ca
    I'm not sure what you mean.
    When there is no car to follow the car will go to the set maximum speed (adjusted with the stalk).
    Along i5 the speed of the traffic when there was any was reasonable - if I wanted to overtake a truck or slow car I just changed to the fast lane, the car would then accelerate to the set speed until I went back to the other lanes.
    kevin
    krmcg likes this.
  2. kevinwhite
    333
    200
    Los Gatos Ca
    I usually set the following distance to the largest setting - that's far enough that I don't think it is perceived as "tailgating".
    Agreed the radar loses sight of the followed car on sharp bends, most of I5 is not too bad - you can disable the following mode if you wish to revert to constant speed.
    kevin
    krmcg likes this.
  3. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    He later said that he's got something like 176 bends and a bit tighter than I envisioned - so ignore my suggestion.
    The scenario I was thinking was more open sweepers, but some corners tightened up, so following another car, my PRIUS just followed along.
  4. mudworm
    mudworm Member
    84
    99
    SF Bay Area
    2018 Prius
  5. alanclarkeau
    7,045
    7,593
    Woops - sorry.
    As I said:
  6. mudworm
    mudworm Member
    84
    99
    SF Bay Area
    2018 Prius
    No worries. You had no good way to tell. What's obvious to me is not always obvious to others.
    #26 mudworm, Sep 9, 2018
  7. Rangerdavid
    Rangerdavid Senior Member
    1,362
    52
    Boone, North Carolina
    Three Touring
    I have a steep descent to work and a reverse steep climb to get home. Usually on the way down, I use "B". My battery is as full as it gets when I get to work, but Prius has so many protections to prevent overcharging, I don't worry. Even if I don't use "B", when full, the engine will increase revs to prevent overcharging. I just use "B" so I don't over use the brakes.
  8. Smaug1
    Smaug1 Member
    135
    95
    Chicago suburbs
    2018 Prius
    There's no danger of overcharging. This is something Toyota would have designed into the charge circuitry.
    Once the battery is charged and if you need to touch the brakes, you're better off using 'B' for engine braking. It can slow you down surprisingly quickly and is adaptive, unlike on a manual trans car. You won't use ANY gas while engine braking. Just a bit of electricity, which is easy enough to re-generate.
  9. Smaug1
    Smaug1 Member
    135
    95
    Chicago suburbs
    2018 Prius
    The engine RPM increasing is a byproduct of what the car is really doing: reducing the gear ratio. (engine braking)
  10. tucatz
    tucatz Active Member
    501
    417
    Manzanita, Oregon
    Four Touring
    Hey mudworm, don’t keep us in suspense - which mountain pass in the Bay Area are you talking about? I use B mode going down highway 24 and any of the hills from skyline blvd down into Oakland. I rarely touch the brakes, end up with a full battery charge, and usually average 52 mpg for the trip (up and down the mountain). I did this religiously on my 2010 prius and sold it at 90K miles with 70% of the brake pads left.
  11. mudworm
    mudworm Member
    84
    99
    SF Bay Area
    2018 Prius
    Is your cat that curious? It's not a pass. It's just Hwy 84 / La Honda Rd that goes over Rte 35 / Skyline Blvd. I didn't know Skyline Blvd goes all the way into Oakland.
  12. tucatz
    501
    417
    Manzanita, Oregon
    Four Touring
    I used cycle the Old La Honda Road - Skyline - Portola Valley loop when I lived in Palo Alto.
    Oakland has its very own Skyline Blvd.
  13. A440SPS
    A440SPS Junior Member
    Albuquerque NM
    It seems sensible to use "B" mode when going down a moderately steep hill, say with a 30 mph speed limit.
    But "B" mode revs the engine fairly high. Once the battery is fully charged, is it better to shift to "D", and lightly ride the brake to slow down with regeneration rather than friction, and not wear the engine at all?
  14. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    NO. "Once the battery is fully charged", the regen energy goes into spinning the engine and not to the battery........regardless of the position of the "shifter".
  15. fuzzy1
    10,722
    But it doesn't redline. In fact, at least in my Liftback, it doesn't rev significantly higher than it needs when climbing the hill. It is just more noticeable.
    When the battery is fully charged, there is no more regeneration possible. So you must slow down with either friction brakes, or engine braking. Or both.
    For short hills, it is your choice of brake pad wear vs engine wear. For long hills that might overheat the brakes, the engine compression braking becomes essential.
  16. alanclarkeau
    7,045
    7,593
    Isn't that what "B" is for - I think I read that the ICE will spin to almost 5000rpm max in "B" - which is short of redline - and I suspect with no fuel being used. Brakes cost money to replace.
  17. A440SPS
    Albuquerque NM
    That's helpful, thanks. I didn't realize that the regeneration braking relies on the electrical load of the battery.
    Still, if I have to choose between wearing out brake pads, and wearing out piston rings, wouldn't I choose brake pads? Surely engine braking causes wear on many engine components.
    --Cy--
  18. alanclarkeau
    7,045
    7,593
    TOYOTA's instruction:
    The engine will almost certainly last the life of your car - don't forget that it has a rest when in EV Mode so it's only running 75-80% of the distance travelling.
    Brakes will wear quickly if used on downhill stretches - and could even overheat if the stretch is too long, as they're designed to be used in conjunction with Regeneration braking and "B" mode.
  19. fuzzy1
    10,722
    For short hills, your choice, depending on your own vehicle experience. As some people point out, brake pads are cheap. As others point out, the engine normally lasts the life of the car, or at least doesn't often fail from this wear mechanism.
    I drive on numerous long hills, so safety dictates not overheating the brakes.
    Pike's Peak Road descent, mandatory brake check at Glen Cove, where a pickup truck a bit behind me and smelling to high heaven was ordered into the 30 minute cooling off zone (sorry for less-than-idea Google view): Pikes_Peak_Glen_Cove_brake_check.JPG
    #39 fuzzy1, Dec 30, 2018
    alanclarkeau likes this.
  20. Mendel Leisk
    42,373
    Would engine braking be a time of high vacuum in the cylinders? This tends to pull oil up most effectively, lubing the highest zones of the cylinder walls that the piston rings contact.
    Again, I would reserve B for long downhill stretches, where the hybrid battery is full to the top bar and still a lot of downhill ahead.
