Best temporary fix for a dead rear wiper blade?
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by pilotgrrl, Mar 1, 2018.
  1. pilotgrrl
    pilotgrrl Senior Member
    891
    1,797
    Chicagoan in TX
    My rear wiper blade has partially separated from the part that goes on the arm. It's raining test again this morning, and I use it a couple times on my way to work.
    Took her in for my penultimate oil Toyota Care service yesterday, but they were out.
    I'm thinking about Loctite Go 2 Glue, which is a non cyanoacrylate. Anyone have better ideas'
  2. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    What about an Automotive Parts store?
    kenoarto and jerrymildred like this.
  3. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    Not being facetious, but consider not using the rear wiper. If you can get up to ~50mph the rear window clears itself with the slipstream. Outside of Toyota, there's not much in the compatible market over here.
  4. FuelMiser
    FuelMiser Senior Member
    1,349
    929
    Monument, CO
    I say this without having done it on Gen 4, but what I would try (and have done with past Prius) is take the wiper arm off the car and carry it into a parts store and find a match
    kenoarto likes this.
  5. first_superior_prius
    76
    115
    Michigan
    Just go to Autozone or equivalent and tell them what you want. They'll look it up. If you ask, lots of times they will even install it for you
    But I also echo the "just don't use it" comment.... there's really no need for a rear wiper on a sedan. Some models don't even have one. Mine doesn't. It never even gets bad enough that I'd ever use one, even if I had one to use
    kenoarto and RCO like this.
  6. Prodigyplace
    12,712
    11,848
    Central Virginia
    RCO and bbald123 like this.
  7. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    You could put some Rain-X or similar water repellent on the rear screen.
  8. Isezno
    Isezno Junior Member
    16
    Wagontown, PA
    Four Touring
    Amazon also has them. Because of the issue I had with getting replacements for the front, I bought a spare rear one. I believe it's Bosch and it matches perfectly.
    Bosch Rear Wiper Blade H409 /3397011431 Original Equipment Replacement- 16" (Pack of 1)
    #8 Isezno, Mar 3, 2018
  9. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    Not Amazon.co.uk though, sadly!
