Best type of gas for Prime?
Discussion in 'Prime Main Forum (2017-2022)' started by Yukyae, Apr 15, 2017.
  1. Yukyae
    Yukyae New Member
    Seattle
    Like the question on the thread tile. What type of gas are you guys using for Prime? 87, 89 or 91..! Which one is good for the engine?
    Thank you.
  2. dalcon95
    dalcon95 Senior Member
    512
    653
    Easley, South Carolina
    I use 87 with no ethanol. It gives better fuel economy and a longer shelf life which is good for those that don't use much gas at all. It is designed for 87 and that is what I use.
    #1 in Easley,SC
  3. Rmay635703
    Rmay635703 Senior Member
    2,688
    1,725
    Somewhere in Wisconsin
    2013 Chevy Volt
    The cheapest, it's rare anything else saves money
    markrivers and douglasjre like this.
  4. Prius from Dad
    Prius from Dad Senior Member
    724
    1,116
    Toms River, NJ USA
    I agree, ethanol is not good for mpg or the seals in engines. Wish they had no ethanol gas in NJ.
    markrivers and dalcon95 like this.
  5. dalcon95
    512
    653
    It can be easily found in South Carolina. Not all stations have it though. It cost about $0.30 more per gallon though. Being that I hardly use gas, the price difference isn't a big deal to me.
    #1 in Easley,SC
    Insirt likes this.
  6. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    I use E10 87 AKI octane from a busy service station.
    Tips and PT Guy like this.
  7. mr88cet
    mr88cet Senior Member
    2,313
    1,335
    Austin, TX
    Generally speaking, higher octane ratings don't work any better on engines designed for 87. That, according to Consumer Reports and others.
    iPhone ? Pro
  8. wjtracy
    wjtracy Senior Member
    11,374
    3,609
    Northern VA (NoVA)
    Owners manual should have octane requirement, but basically all USA Prii take 87 Regular.
    I like to use TopTierGas.com companies.
    Most of us only have E10 10% ethanol available, so that's the Regular intended.
    Ethanol-free E0 might be a plus, if available, especially if your intent is to never use the gaso and just let it sit in the tank.
    vegan, ruby and dalcon95 like this.
  9. ed4271
    ed4271 Member
    107
    64
    US
  10. Samprocat
    Samprocat Active Member
    491
    297
    Lincoln, NE
    I have done various tests and so far 91 octane on Prime will make better MPG and do a lot tighter timing versus 87 octane
    All tests been done with 100% fuel no ethanol
    93 octane have not show any better than 91
    So if your goals are cheap
    You will not save money buying 91 octane fuel vs MPG improvements
    If you looking at how combustion is getting on better side with better catalytic temperatures then 91 octane with so much more to discuss...
    But that will be another thing
    douglasjre likes this.
  11. Mendel Leisk
    42,266
    Regular grade with ethanol (I assume) works fine for me. If I understand correctly, higher grades are warranted only for higher compression engines, are formulated to better resist pre-ignition (harder to ignite), AND: will be noted in the Owner's Manual.
    I'm partial to Chevron, suspect they have decent quality control over their gas, and they have free air still, about the only holdout around here.
  12. Tideland Prius
    16,670
    I wonder how that'll fare in the Prime (and might be one reason the Gen 1 Volt required premium). How would E10 fuel sit for half a year in the tank vs. E0?
    Is there a Coles Note version? I do recall some years ago that @bwilson4web said that 89 (midgrade) works well if you're on a higher stress drive (like mountain driving or on a road trip). I can't remember why now.
    The only reason I'll put 91 is for ethanol-free fuel. I gained 1-2 US mpg out of it so the cost has to be small enough to break even (not trying to save money but rather just have ethanol-free fuel in the system). In Canada, the costs usually doesn't work out but in the States, the math works out for some stations.
  13. wjtracy
    11,374
    3,609
    Northern VA (NoVA)
    We basically ain't got no E0 here, even Volt must accept 10% ethanol in our Premium.
    The vast majority of U.S. Primes and PHEV are being sold in states with EPA RFG (reformulated gasoline) and in those RFG areas, E0 is effectively banned from all gasoline stations. Only when we get out to the less populated U.S. areas is E0 available on a limited basis.
    E10 is a pain for water separation, but for 6-months you are probably OK.
    #13 wjtracy, Apr 16, 2017
    deadmoney33 and Tideland Prius like this.
  14. PT Guy
    PT Guy Senior Member
    1,085
    713
    Washington, the state
    Best answer of the bunch. Top Tier is worth looking for for all your engines. Licensed Brands | Top Tier Gas
    dalcon95 likes this.
  15. dalcon95
    512
    653
    I think the E0 availability is an area thing and not a less populated think. In Greenville SC, which has about 1/2 million people in it, has gas stations with E0 available. Most common is E10 and a few have E85. There are more stations with E0 than E85 in this area.
    #1 in Easley,SC
  16. wjtracy
    11,374
    3,609
    Northern VA (NoVA)
    Basically the "non-attainment" areas with smog issues (Northeast corridior/CA/Chicago area/St Louis/Houston/etc) must use RFG and E0 is not allowed in those areas.
  17. Samprocat
    491
    297
    Lincoln, NE
    That is not true for St Louis you have choice for 100% fuel
  18. HPrimeAdvanced
    HPrimeAdvanced Senior Member
    2,304
    3,519
    Anaheim, CA
    Remember gasoline is refined in a batch process from different stocks according to set specifications within supposed guidelines; there can be some variance. Also, if a station is unable, for whatever reason to get its shipment from the name vendor, they will get it from another different label in order not to run out. So a purchaser who practices brand loyalty might be wasting their time (and money).
    deadmoney33 and Db17 like this.
  19. bwilson4web
    16,512
    Ah yes, E10 had not invaded our area. I only test regular and premium in a maximum throttle hill climb.
    I found a slight improvement of premium because the spark could advance further. Emphasis on slight because it was not proportional to the higher price.
    Tideland Prius likes this.
  20. priuscatprimeguy
    priuscatprimeguy Senior Member
    2,730
    2,640
    Farmington Hills, Michigan
    According to the owners manual you can go a year between fill ups. I would personally would only go 6 months though.:D
