Best wax/polish for Winter Grey?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by PriusRos, Aug 30, 2009.
  1. PriusRos
    PriusRos A Fairly Senior Member - 2016 Prius Owner
    1,973
    218
    Rockville, MD
    I think I've used both -- at different times. Probably the last time was Z5.
  2. 32kcolors
    32kcolors Senior Member
    5,683
    954
    124
    Redondo Beach, CA
    So no ill effects from applying Z-CS over uncured wax (no smearing, etc.)? Interesting.
    Regardless, applying Z-CS over carnauba wax should increase its longevity as opposed to not topping it.
  3. rstark18
    rstark18 Member
    442
    75
    Los Angeles
    I read that after I posted. I don't know if OOS and Z-CS are similar but here is what Optimum says:
    "If there is any wax on the surface, Opti-Seal will dissolve it and the polymers will go to the surface and the wax will migrate to the top. This is due to the difference in the surface tension of wax and sealant."
  4. 32kcolors
    5,683
    954
    124
    Redondo Beach, CA
    Kind of defeats the purpose of applying polymer sealant over carnauba wax. I don't don't know if Z-CS works that way, but maybe that's why they specifically say to apply Z-CS over wax only after it's cured.
  5. rstark18
    rstark18 Member
    442
    75
    Los Angeles
    As I understand it, it's purpose is as a paint protectant not a wax sealant that's why they both say they can be used without anything else. The reason people use stuff on top of or underneath is for appearance and extra protection.
