Best way to drive for fuel economy
Discussion in 'Prius v Fuel Economy' started by acr1, Jun 17, 2014.
  1. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    Close, but not quite. If the battery SOC is low then the power demand is a combination of go pedal and battery demands. In general you are right though: ICE power is not set according to maximum ICE efficiency. It just seems that way ;)
    F8L likes this.
  2. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    To this end it is always important to keep an eye on SOC use. If you are draining the SOC down to a point at which the ICE will be forced to recharge it to a large extent then you are not driving in the most efficient manner. Conversion losses suck. :)
  3. SageBrush
    11,627
    2,533
    Southwest Colorado
    Yep. And sometimes you get a double-whammy for your troubles, because the low SOC pushes the ICE to operate in an inefficient band until the battery is happy again.
    F8L likes this.
  4. john1701a
    john1701a Prius Guru
    12,802
    5,286
    57
    But then again, the "inefficient" state does have a by-product of heat. So, it's not a total loss.
