Best way to drive PIP?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Au-Toe, Jan 13, 2014.
  1. Au-Toe
    Au-Toe Matrixowner
    86
    Chino, CA
    2014 Prius Plug-in
    Not sure if it's been asked before. But what is the ideal way of driving the pip on a normal work day?
    I've had the car for about 2 weeks now. Only have done 1 fill up and got about 62mpg. I'm due for more gas soon.
    This avg is not from the computer but from doing the total trip and dividing the gallons to fill up.
    So now on to my own situation. I plug the car in over night and leave to go to work in the morning. I do drop my son off to a babysitter before I head to work.
    One way trip from home to babysitter to work is about 40 miles. And repeat but in reverse order going home. So about 80 miles a day.
    When I leave in the morning, should I just drive all electric until it runs out?
    So far I've kind of done half and half. EV on 4 mile trip to freeway and then switch to HV mode on the freeway. When I exit on to normal streets I would go back to EV mode.
    Is that the ideal way to do it? It is there something else suggested?
    I don't have the option of charging at work. I know that would help. But it's not possible right now.
    Hope someone can enlighten me. Thanks
    Turn off signatures in Tapatalk Tapatalk
  2. -1-
    -1- Don
    1,254
    439
    Chester, Virginia
    2024 Prius Prime
    :confused:I've had my Prius Plug In one year this month. I'm still experimenting. For me, using EV at every opportunity until depleted. I hate arriving at my destination with anything more than .1 EV remaining. My situation is almost ideal with a 9.8 mile (one way) commute and charging at home and work.
  3. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    I like the way you use it, city EV and highway HV.
    I don't like ICE shutdown and restart in city stop and go traffic so I prefer EV.
    One key point is to minimize ICE warm up penalty - don't leave a long gap between using ICE. You will have 2 for sure so don't make it 3 switching into EV and back to HV.
    I may change the strategy if I need cabin heat or not.
    retired4999 likes this.
  4. vskid3
    vskid3 Active Member
    773
    228
    How much of that 40 miles is freeway? How fast do you go on the freeway? If most of the drive is freeway, then your speed is going to make a big impact on your mileage.
  5. bisco
    52,692
    i agree with usb. once you start the ice, don't let it cool down by going back to ev. of course, you'll have to warm up again after work, that can't be helped. when i'm doing a short trip, but longer than ev range, i don't use the ice until the ev runs out. that way, it never cools off and has to go thru warm up again. another thing is to practice pulse and glide. the best way to do this is to use up your ev, then you can practice getting the best mpg's out of the standard hybrid.
  6. markabele
    5,084
    1,782
    Nebraska
    Great advice so far in this thread.
    We could probably even give you a few more ideas and extra details if you gave us a little more information about your commute. Tell us about speed limits, traffic jams, stoplights...anything that might give us more insight.
  7. ny_rob
    ny_rob Senior Member
    1,968
    813
    L.I.- NY
    I also use EV for the first 5.5 miles of my commute which is on local roads- then use the ICE for the next 18 miles which is freeway miles, then EV again 5 miles of local roads to my job.
    I recharge at the free ChargePoint station in the adjacent parking lot to my work.
    Of course all bets are off when it's 3F outside :mad:
  8. grayprius
    grayprius Junior Member
    I might be looking at this completely wrong, but wouldn't it make more sense to use EV on the highway and HV on local roads? I just switched to a PIP from a Gen II and by far my mileage was the best while driving locally versus on the highway with the Gen II. Taking that logic, would I not want to compensate the worst mileage on the highway with some EV and take advantage of the good mileage that the HV is giving me already? I know I must be missing something given most here are saying they use EV locally...
  9. ny_rob
    1,968
    813
    L.I.- NY
    EV can't give me the 65mph speeds we need (plus even more power for uphill climbs) for our freeways (specifically the Long Island Expressway) here.... so EV isn't really an option for highway use on my daily commute.
    EV is super efficient at low speeds on local roadswhere's there almost no wind resistance too.
  10. CharlesH
    2,798
    1,166
    Roseville, CA
    Yes, the mpg figures with hybrids tends to be inverted from conventional ICE cars, due to the fact that start/stop city driving is helped by regeneration, whereas energy lost to wind resistance at higher speeds is just lost. But on the question of ICE vs. electric with respect to higher speed driving, with the PiP the ICE is more efficient than the electric motor when more power is needed at higher speeds. In particular, at speeds above about 62mph, the ICE has to kick in anyway due to mechanical considerations with the power split device. This is a distinguishing factor between an enhanced hybrid like the PiP vs. a range-extended EV like the Volt: the PiP tries to use the ICE when it is the optimal power source, and the electric motor when it is optimal, whereas the range-extended EVs really try to avoid using the ICE unless the battery is depleted.
  11. bisco
    52,692
    this isn't a bad theory, it all depends on your driving style, commute and etc. if you have enough ev for your highway driving, it may be possible to get better mpg's off of the highway. but the question becomes, what's the overall efficiency of the whole trip?
  12. Au-Toe
    Au-Toe Matrixowner
    86
    Chino, CA
    2014 Prius Plug-in
    directly answering your question .
    my best guess would be about 32 miles freeway, 8 miles streets. +/- 1 mile
    i live is socal, los angeles county to narrow down for those who know the area.
    i drive with traffic, so i'm stop and go half the time. i take 4 different freeways, about 50/50 i'm doing 65-75mph, other parts of freeway i'm doing 20-40mph.
    i should've quoted you on the last post i made. but i hope it gives a good enough answer .
    not too many stop lights where i go. once i exit, its usually less than a 5-10 minute drive depending if i hit a stop light.
    los angeles county traffic if that means anything to you.
    i'm not in the heart ot l.a., but we all get affected if you're headed in that direction.
    well i'm wondering do all or most PIP users switch back and forth between EV and HV like i do?
    or is that bad practice?
    I would assume whenever my next trip from los angeles to las vegas, i'd would just be in HV mode all of the way.
    and turn on EV maybe once i exit and get to my destination.
  13. markabele
    5,084
    1,782
    Nebraska
    I think a very good rule of thumb for you would be to use your EV on the 8 miles of streets (16 miles total) and HV on the freeway.
    Switching back and forth can have its benefits to using both fuels to their fullest capabilities. Did you own a regular Prius before? Are you familiar with Pulse and Glide?
    Correct on the long trip idea. (wish I lived that close to Vegas) :)
  14. Au-Toe
    Au-Toe Matrixowner
    86
    Chino, CA
    2014 Prius Plug-in
    Yes. Lease a Prius from 2010-13.
    And moved on to a plug in New Year's Eve.
    Not sure in the exact meaning of the pulse and glide. But I do try to stay in the middle range if the bar when I'm able to slowly cruise without holding up traffic
  15. Michael33
    Michael33 Member
    372
    62
    Upstate NY
    2013 Prius Plug-in
    This commute is ideal for using EV mode on low speed streets and HV on the highway. You can add a little EV range by switching to EV when slowing or going downhill on the highway (regeneration will then add to EV range), then switching back to HV to accelerate.
    CaliforniaBear likes this.
  16. Au-Toe
    Au-Toe Matrixowner
    86
    Chino, CA
    2014 Prius Plug-in
    That is how I seem to drive.
    Depending in the route home I can get some good down hill regeneration going.
    I pretty much figure this is how I should drive it on my own. But I wanted to check with users who've had the car longer than I have, hopefully pick up some tips.
    Btw. Just filled up. 64mpg.
    I'm sure lots of you are getting better numbers. But with my last one at 62mpg. I think this is about the avg I'll be hitting.
    I'm pretty happy with the numbers. Our previous leased Prius my wife and I would avg 47-49mpg. That was just the normal HV model.
  17. Michael33
    Michael33 Member
    372
    62
    Upstate NY
    2013 Prius Plug-in
    My housemate drives our PIP for the most part. She is at 68MPG. The average started at 99MPG on the 23 mile drive home from the dealership in October, and stabilized in the seventies for the Fall, dropping slowly again for the Winter. She does more low and medium speed driving than you, though.
  18. nman84
    nman84 Junior Member
    2014 Prius Plug-in
    Thanks for asking this question OP. I just got a PiP last week and it looks I have almost the same type of commute (I'm in LA too!). I have about 2mi city --> 35mi highway --> 2 mi city each way, about 40 miles each way. I use EV for streets and HV for highway as well except for the last stretch of highway on my way home when I'm trying to burn off the EV miles. I LOVE this car and can't wait for carpool access with the green sticker.
    Can someone explain to me what ICE warm up penalty is?
  19. ny_rob
    1,968
    813
    L.I.- NY
    In it's most basic form- the PIP is double dipping from both power sources.
    While "warming up" it's burning gasoline to warm up the ICE- which is kept pretty much off line as far as adding to the propulsion system (think of just running the ICE in neutral) while depleting EV power the whole time for propulsion as well.
    So you're getting almost no propulsion from the running ICE while burning EV power to move the car at the same time... double dipping.
    If I had to put it into numbers-
    Without ICE warm up penalty, I could drive 1 mile on a flat street in HV mode at 45mph and get 55mpg. My EV miles would remain unchanged.
    Without ICE warm up penalty, I could drive 1 mile on a flat street in EV mode at 45mph I would burn no gasoline, see 999 on the mpg display and only consume 1 EV mile.
    With ICE warm up penalty, I could drive 1 mile on a flat street in HV/EV mode at 45mph and get 35mpg and my EV miles would also drop by 1 EV mile or more.
  20. Au-Toe
    Au-Toe Matrixowner
    86
    Chino, CA
    2014 Prius Plug-in
    same here. i always try to deplete my EV battery before i get home
