Best way to drive PIP?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Au-Toe, Jan 13, 2014.
  1. nman84
    nman84 Junior Member
    2014 Prius Plug-in
    Thanks for the
    Thanks for the explanation. So my last two days driving to work, when I entered the highway and switched to HV, I noticed I was still losing about 1 mile of EV range (very rapidly) before the HV system became primary. Is this the penalty???
  2. ny_rob
    ny_rob Senior Member
    1,968
    814
    L.I.- NY
    Yes, that's the warm up penalty in action...
    But in the case where you keep driving for several miles after entering HV mode and the engine has warmed up completely- the PIP will try to get back most of the EV lost during ICE warm up. Of course if you're on a short trip where you turn the PIP off right after ICE warm up -you'll lose the EV burn off miles.
    nman84 likes this.
  3. nman84
    2014 Prius Plug-in
    Ahhh yes, I noticed this as well! My commute is long enough to get most of those miles back on EV. Thank you for the response and explanations.
  4. ny_rob
    1,968
    814
    L.I.- NY
    You're welcome!
    Don't know where you're located- but if you're in a four season location... you can expect seriously better mpg during the spring and summer months, even longer EV range too.
    For December I got 81mpg for the month, in comparison- I got 113mpg for last August!
  5. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    Actually, EV-Boosted warm up can get at least 50 mpg at 45 mph. Sure, it'll consume 1 EV mile but the MPG will remain high. In that case, the penalty is hit with EV mile.
    If you let the gas engine return that borrowed EV mile, MPG under "HV mile" will take a hit.
    Whenever the engine is cold and you need to bring it up to the operating temp (130 deg F), you'll use gasoline amount of two jumbo eggs. During the warm up stage, ICE will generate 3-6 hp. It can propel the car or charge the battery. It is not like you are wasting the gas. You get heat, plus propulsion power.
    Over time, as you use ICE more, there will be excessive heat. The car won't let the temp hit more than 198 deg F or else waste it through the radiator. This is the window of opportunity use your EV miles (if any extra). Let the coolant drop down to 130 deg F and repeat the cycle.
    Heat management by switching between EV and HV mode is fun. You don't have to do it and leave it in EV mode and PiP does it automatically. However, I like to believe I can do a better job than HSD. :)
    giora likes this.
  6. Fore
    Fore Don't look back!
    494
    107
  7. Au-Toe
    Au-Toe Matrixowner
    86
    Chino, CA
    2014 Prius Plug-in
    this is what i wonder sometimes. would it just be better, albeit, lazier to just leave it in EV mode, and let the computer switch it over when it needs to because i'm either driving to fast or too hard on the accelerator?
  8. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    HSD does a good job, I was impressed when I tried it. It operates the ICE in the temp between 90 degF? and 130 degF. I think the low end depends on the cabin temp you set.
  9. Au-Toe
    Au-Toe Matrixowner
    86
    Chino, CA
    2014 Prius Plug-in
  10. Fore
    494
    107
    lol, if kate upton was my wife... i wouldn't be posting up her picture on here. i'm a pretty private with my family stuff.
    i am married though.
    Yea, I kinda figured that! Amazing tho what an air brush can do and most likely implants!
  11. markabele
    5,084
    1,782
    Nebraska
    Here is a great video and thread about Pulse and Glide (and other things). It is for the 2010 regular Prius. But in HV mode the PiP acts just like a regular Prius.
    The Pulse and Glide is one of the most important ideas for someone trying to save gas in HV to know. Check it out:
    Max MPG Driving Techniques Youtube Video | PriusChat
    nman84 likes this.
  12. Agent J
    Agent J Hypoliterian
    294
    111
    Sydney, Australia
    Ahh.. I wish I had a PiP... When will it ever be available over here... I EnVy you guys! :rolleyes:
  13. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    With PiP, you can accelerate to 62 mph and glide in EV mode. You can also creast smaller hills with more powerful battery. It comes handy when you know you can glide further and don't want to bother ICE from starting.
