Best way to fix this?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by whataboutbob, Apr 21, 2023.
  1. whataboutbob
    whataboutbob Junior Member
    74
    16
    2010 Prius. I am troubleshooting water in the spare tire compartment and based on some videos, I peeled this tape(?) (see pic) on the roof back to see if there are cracks underneath but now it won't stay put, can I just superglue it or is there some other glue I should use?
    #1 whataboutbob, Apr 21, 2023
  2. jerrymildred
    jerrymildred Senior Member
    11,517
    14,164
    Tampa, FL
    If there are cracks, you might not be able to see them. While you have those rubber strips off, it's best to mask off the roof, doors, hatch, etc. and give it several coats with spray sealant.
    Then jam that rubber strip back in place. You have to have the end in the right spot for it to snap into place. I like to snap in one end and press maybe a foot or two of the strip into the slot. Then do the other end. Then you can push the rest of it into the slot. That way the strip won't creep.
    CR94 and whataboutbob like this.
  3. whataboutbob
    74
    16
    I see, there is a a groove for most of the strip to snap into but not the entire strip, the part that curves up is probably because it's old and once I bent it, it will stay that way, not sure if there is anything that can be done other to replace the strip.
  4. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,558
    2,598
    Taylors, SC
    3M Plastic and Emblem Adhesive, 08061, 5 oz Tube
    prius16 and whataboutbob like this.
  5. whataboutbob
    74
    16
    Thanks but now I am not sure that part is supposed to be glued
  6. prius16
    prius16 Active Member
    462
    246
    New England
    2022 Prius Prime
    Listen to the other MechE, or buy new weatherstripping. It is that simple. (y)
    #6 prius16, Apr 22, 2023
  7. jerrymildred
    11,517
    14,164
    Tampa, FL
    You might need new weatherstripping. But I think it likely that the end of your strip is just not quite in the wrong place. It should all snap down. If it's in the right place and won't snap down, then it's shot and needs to be replaced.
    Also, I failed to mention that you'll want to let that sealant dry for several hours before putting the weather strip back.
    Also #2, when you spray the sealant, go all the way to the tail light.
    whataboutbob likes this.
  8. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    Inspect the end of the strip AND what is in the channel under the end.
    Both ends have a different "clip" that is harder to engage.....and disengage.
    If the rest of that strip comes loose, then the suggested cement should work but not the entire length of the strip.
    I have had those rubber strips come loose on 3 different Prii's.
    Twice it was while washing the car. Once in a drive through.
    I don't remember EVER seeing a report of that being the source of a trunk leak.
  9. sam spade 2
    7,035
    2,804
    2017 Prius c
    It isn't. Because it is intended to be removed to mount a car top carrier.
    Except for that intended use, gluing it down should NOT be a problem.
    But some spaces need to be left open to drain the channel.
  10. whataboutbob
    74
    16
    So I decided to pull the entire strip off and cleaned out a bunch of dirt under it and discovered it is possible to bend the end part back in alignment because it's kinda stiff and will stay in place whichever way I bend it, now it works just like before. Thanks for all your suggestions though. Hopefully, this will help another Prius owner in the future.
    jerrymildred likes this.
  11. sam spade 2
    7,035
    2,804
    2017 Prius c
    Take note, however, that once it comes all the way off.......
    It is likely to be loose enough now to come off on it's own.
    Were you able to "snap" the ends into the clips ?
  12. Mendel Leisk
    42,240
    I did that maybe 2 years back (on advice here). Ours was barely grungy, but worth wiping out with a damp rag, and then I waxed it. These grunge traps...
  13. whataboutbob
    74
    16
    After reseating, it feels as solidly in place as the one on the other side of the car, nothing is corroded underneath, just full of dirt. There is no clip per se at the end but there is a groove that the end snaps into once it's adjusted to bend the right way.
  14. sam spade 2
    7,035
    2,804
    2017 Prius c
    Clip, groove.....whatever.....the ends fit much tighter than the rest of the strip.
    On 3 of my 4 C's, once they got to be about 6 years old, the rubber strip shrunk a bit so that it wasn't tight anymore.......
    except at the ends. I used emblem glue in a few spots to keep it from flapping in the wind.
    A few years ago, replacement strips were available.
    Seems like I remember something like $60 each. Probably more now.
  15. Mendel Leisk
    42,240
    jerrymildred and whataboutbob like this.
  16. whataboutbob
    74
    16
  17. Mendel Leisk
    42,240
    Yeah. Yours are probably fine.
