Best way to increase MPG (not including driving habits)
Discussion in 'Prius c Fuel Economy' started by HasuPK, Jul 10, 2018.
  1. HasuPK
    HasuPK New Member
    16
    Hawthorne
    2014 Prius c
    Wondering if anyone had any results modifying anything on their prius C to get more MPG? I know tires can make a difference, anything else?
  2. PriusCamper
    PriusCamper Senior Member
    12,525
    5,078
    Pacific Northwest, USA
    They've already done almost everything possible in your car's design to boost MPG... You could reduce as much weight in the vehicle as possible...
    I also noticed a very slight improvement in MPG in my Gen2 Prius by switching to 0W-20 synthetic motor oil, not good for Winter in real cold climates...
    Also a Prolong hybrid battery conditioning routine ProlongĀ® Battery Systems FAQ – Hybrid Automotive will ensure your hybrid battery is maxing your MPG, especially every 3 months after a full charge and balancing between cells.
    But far and away the best way to boost mileage is Low Rolling Resistance tires with as high of tire pressure as feels safe. The way I did it was kept adding 2-3psi in each tire until I noticed a slight decline in traction under normal driving conditions. In Summer I feel comfortable with 46 psi in the rears and 48 psi in the fronts. In winter driving conditions I lower the pressure by about 5 psi.
    Finally the last option for a major MPG boost is alloy racing wheels that are 4 pounds lighter than standard wheels... Catch is those wheels cost $2K to $3K each, which makes for a really bad day if you hit a curb.
    JimboPalmer and roadrunner like this.
  3. HasuPK
    HasuPK New Member
    16
    Hawthorne
    2014 Prius c
    Great write up
    Thank you!
    PriusCamper likes this.
  4. Mendel Leisk
    41,118
    Try some fuel injector cleaner, one with PEA (PolyEtherAmine), the kind you add to a tank of gas.
  5. PriusCamper
    12,525
    5,078
    privilege likes this.
  6. wjtracy
    wjtracy Senior Member
    11,365
    3,608
    Northern VA (NoVA)
    There is a hack known as the "thermistor hack" used on Gen2 and a few Gen3's basic idea is to elecronically fake out the warm-up cycle to get out of the lower-MPG warm-up cycles faster. I know one PiP owner from West Virginny had done it, but the idea lost popularity....guess Prius lost the hobby interest it once had. I do not know if it works on a Prius c. If in Ca. that could be legal issue, as the long, low MPG warm up cycle is CARB's idea to minimize emissions.
    Another idea get out of Hawthorne and get some real gasoline, assuming that is Ca.
    ztanos likes this.
  7. pdforever
    pdforever Member
    37
    73
    Pakistan
    2015 Aqua
    I'm sorry, I know that the thread is a bit old, but it came up in my "similar threads" line, so I had to ask...
    Isn't that a bit high? The pressure, I mean. Wouldn't having a tire pressure that high damage the tires? I'd always heard that it should be 30, though I seem to recall reading somewhere that the pressure of the rear tires should be 28 because there's less weight there.
  8. Mendel Leisk
    41,118
    There's a recommended pressure on the placard in the driver's door opening. I figure it's ok to go a few pounds over but not too much.
    One thing I suspect: extreme pressures will accelerate wear on wheel bearings, shocks and suspension.
    douglasjre, iceman13 and frodoz737 like this.
  9. ztanos
    ztanos All-around Geek!
    3,339
    1,150
    40
    Cumming, Georgia
    I would never go 48 psi on a tire that states MAX pressure of 45... I do run 41/42 all around, however.
    Palmoyas, lablancjc and iceman13 like this.
  10. roadrunner
    roadrunner His (blue) and hers (black).
    61
    36
    Perkasie, Pennsylvania
    2015 Prius c
    I would suggest the purchase of
    ethanol-free gasoline!
    privilege and KK6PD like this.
  11. wjtracy
    11,365
    3,608
    Northern VA (NoVA)
    Sure that could help...years ago Prius owners had contests about how many miles they could squeak out of a tankful. Yes E0 would be one possible strategy, for those with access to E0. In those days E0 was probably more common.
  12. mpg_numbers_guy
    116
    64
    VA
    I've read that tires at sidewall max wear the best - underinflated tires (<40 PSI) and overinflated tires (>50 PSI) have uneven treadwear.
    I run 60 PSI on my Insight and 68 PSI on the Civic. Prius is at 50 PSI for ride comfort (mom's car). Wear hasn't been abnormal at all. There's a guy who runs over 100 PSI in his tires and is fine, albeit vastly increased road noise and suspension wear. Can't recommend that. ;) But sidewall max or just over - definitely recommend.
    roadrunner likes this.
  13. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    946
    118
    Los Angeles Foothills
    Live in a MC Escher reality, always drive downhill.....
  14. ztanos
    3,339
    1,150
    40
    Cumming, Georgia
    That's a good way to prematurely stretch the beads and wires...
    Palmoyas, douglasjre and michael.sfo like this.
  15. mpg_numbers_guy
    116
    64
    VA
    100 PSI? Yes, that an also a vastly increased amount of wear on bearings and suspension components. 60 PSI? Maybe a little, but I consider it worth it for the MPG gain. Sidewall max? Perfect if you're paranoid about your tires. ;)
    Palmoyas, skayaks and Mendel Leisk like this.
  16. Mendel Leisk
    41,118
    I'd rather change tires once in a while, and preserve wheel bearings and suspension.
  17. wjtracy
    11,365
    3,608
    Northern VA (NoVA)
    I believe MPG guru Wayne Gerdes uses really high tire pressure
    mpg_numbers_guy likes this.
  18. mpg_numbers_guy
    116
    64
    VA
    It depends. Inflating the new winter tires on the '08 Prius from 36 PSI to 50 PSI brought highway fuel economy from 43.8 MPG to 47.6 MPG. This is 30 F wintry weather on new tires that haven't broken in yet, so still hurt fuel economy.
    Let's say you only get 50k miles on a set of tires, and gas is $2.50/gal:
    50k mi / 43.8 MPG * $2.50/gal = $2,853.88
    50k mi / 47.6 MPG * $2.50/gal = $2,626.05
    Savings: $227.83 - over half the price of new tires over the life of the tires. Plus better wear at the sidewall max (Michelin X-ICE 185/65R15s are rated at 51 PSI).
    roadrunner and pdforever like this.
  19. DOHCtor
    DOHCtor Member
    162
    93
    Levis (Quebec city's south shore)
    2024 Prius Prime
    SE
    Sorry, old thread revival.. To people using really high pressure to ''balloon up'' the tires and decrease rolling resistance. Why do that when you could do the same by switching your 195\65R15 Tires to a 175\70R15 or something like that? It would be doing the same...? Running 40Psi i understand, 50+ i don't..
    douglasjre likes this.
  20. PriusCamper
    12,525
    5,078
    Half way between 40 and 50 works for me as well as many others on here... Among Prius experts this seems to be the consensus... And the notion that a tire with multiple layers of steel inside of them can magically go round and inflate like a balloon and increase tire wear in the middle of the tire is an urban legend. I've gone through multiple sets of tires for 70K miles even though they were only rated for 60K and despite much higher tire pressure there's never been more tread wear in the middle than on the sides. Always even tread wear...
