Best way to replace bumper turn signal?
Discussion in 'Prius v Technical Discussion' started by PreusV, Aug 7, 2017.
  1. PreusV
    PreusV Junior Member
    16
    Chicago
    2013 Prius v wagon
    Just bought a 2013 Prius V 5 with 96,xxx miles with a cracked front passenger turn signal. The dealer gave me the light but refused to install it. What is the best way to install the new turn signal? The three methods I see are:
    1. Lift car and go through button of front bumper
    2. Remove bumper cover
    3. Remove passenger front wheel and splash guard
    Which is correct option?
  2. Mendel Leisk
    41,884
    Don't have the v, but would think option #1 is simplest. Typo: "button" should read "bottom" I assume.
    On ours, best bet actually involves both the black plastic directly under the front bumper corner, and removing a few of the clips on the the wheel well liner, partially pulling it down. There are bolts connecting the two plastic under pieces, but they are rusted solid crap.
  3. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
    1 and 2. Raise the front end, remove lower splash guard bolts and fasteners on the front, no need to remove the bolts and fasteners on the rear of the splash guard, and release clips near the front fenders on the bumper cover. Remove the fasteners on the two corner undercarriage covers below the turn signal assemblies on each side. No need to remove the top fasteners on the bumper cover near the radiator. You can then go through the bottom and swing the bottom of the bumper cover away from the bumper for more room and easier access to the mounting bolts, etc holding the turn signal assembly on the vehicle.
    #3 xliderider, Aug 7, 2017
