Better Ground Loop Isolator than Radio Shack
Discussion in 'Gen 2 Prius Audio and Electronics' started by jonbeck, Aug 21, 2006.
  1. jonbeck
    jonbeck New Member
    43
    Chicago, IL
    After installing the DICE, I had the noise with my XM radio through the Aux input. I ran down to the local radio shack and purchased the Ground loop isolator that is in the manual. I thought everything was fine, but today on the drive to work, I notice a high pitch whine, especially when accelerating or on EV. When gliding, the noise is not there. It's pretty quiet, but noticeable on the talk channels and baseball games. I've got a feeling that, like most Radio Shack products, this one isn't one of the best available.
    Anyone else have this problem? Anyone have any recs on a better quality ground loop isolator?
    thanks
  2. benlenz
    benlenz Junior Member
    31
    I have the Harman/Kardon Drive+Play and had lots of ground loop noise.
    I bought a ground loop isolator from Crutchfield. Abt $25 with shipping. I've only had it about a week, but it seems to be doing the job very well. Nice and quiet.
    It has standard 1/8 inch miniplugs, too, so there's no need for adapters to RCA.
    http://www.crutchfield.com/S-YcfpvR3Ezg5/c...oop&i=127SNI135
  3. jonbeck
    jonbeck New Member
    43
    Chicago, IL
    <div class='quotetop'>QUOTE(garbageman @ Aug 22 2006, 02:53 AM) [snapback]307382[/snapback]</div>
    Thanks, I'll give it a try! I'll be able to clean up about 6 feet of RCA adaptors too.
  4. aaf709
    3,862
    2022 Prius Prime
    I'll be needing another Ground Loop Isolator for the house. Maybe I'll get this one and use it in the Prius and take Radio Shack one I have there out for the house.
    Thanks for posting!
  5. aolm
    aolm Junior Member
    82
    New Jersey
    GLI's kill all your frequency response. You would better off with an FM interface. Check out "This sticky topic is a list of hardware products/mods currently known to work with the Prius " on this site for a fix.
  6. darelldd
    6,057
    389
    Northern CA
    How are you guys buying those things!? Every time I look it is out of stock. I'm on the notification list, and I have it in my cart... been that way for months, and it never seems to come into stock!
  7. DaveSheremata
    DaveSheremata New Member
    249
    Arlington, Virginia
    <div class='quotetop'>QUOTE(aolm @ Aug 24 2006, 09:26 PM) [snapback]309118[/snapback]</div>
    It all depends on whether they're FET based or transformer based. (well, II think most of the FETs need a sink transformer too...). There doesn't have to be signal loss with either design - it's just that vendors like to sell $12 parts for $60.
    Generally you'd do best with an FET based isolator, but requires a power source...
    Dave
  8. dancekat59
    dancekat59 Member
    244
    <div class='quotetop'>QUOTE(darelldd @ Aug 25 2006, 12:08 AM) [snapback]309198[/snapback]</div>
    Huh. The notification system must not work because I ordered and received the crutchfield one about a month ago.
  9. brandon
    brandon Member
    771
    Manhattan, KS
  10. aolm
    aolm Junior Member
    82
    New Jersey
    Sounds like I lucked out on the GLI thing. I have an aux box in for my Sirius receiver. It plays clean. I had to install a GLI in my sienna van for the aux box to aftermarket DVD...sounds very flat and low. DaveSheremata is suggesting that I should try a FET based GLI with a power source?
  11. sluggo42
    sluggo42 New Member
    39
    <div class='quotetop'>QUOTE(dancekat59 @ Aug 25 2006, 11:04 AM) [snapback]309317[/snapback]</div>
    I just ordered mine from eBay, same price. $17.99 + $6>99 shipping.
    I want to know what these guys are talking about with the FEB based GLI???
  12. Tadashi
    Tadashi Member
    796
    Fort Hood, TX
    Crutchfield has them back in stock.
    Quick question: Does only the XM radio cause the feedback or any device plugged into the AUX? I am asking this because I am trying to figure out if I should install it inside my dash or let it hang out of the bottom in case I have to unplug it.
  13. sluggo42
    sluggo42 New Member
    39
    <div class='quotetop'>QUOTE(garbageman @ Aug 22 2006, 04:53 AM) [snapback]307382[/snapback]</div>
    I got this one too, problem solved!
  14. Rangerdavid
    Rangerdavid Senior Member
    1,362
    52
    Boone, North Carolina
    Three Touring
    Does this thing cut out the reproduction of treble and other high-end sounds from your stereo??
  15. hammermill
    hammermill Junior Member
    16
    Imperial Beach, CA
    I am also interested in any first-hand experience regarding the extent to which the Crutchfield and Radio Shack GLIs affect sound quality. I just received a Kensington Ultra Portable Power Inverter and suspect that I would find a small reduction in audio fidelity preferable to the level of hum generated without a GLI. Thanks for any additional input!
  16. Tadashi
    Tadashi Member
    796
    Fort Hood, TX
    The only thing I do not like is that I have to have my volume set at 40 when normally I have it at 20. So I have to remember to lower it before I switch from my aux line to the radio or be blasted out of the car. I am not sure if this is a byproduct of the isolation loop or the DICE unit.
