Better Handling? Corolla vs Touring Prius
Discussion in 'Gen 2 Prius Main Forum' started by ibmindless, May 30, 2008.
  1. patsparks
    10,664
    569
    Adelaide South Australia
    Cool, but your on a Prius forum now? :confused:
  2. sorka
    sorka Active Member
    1,034
    199
    Merced, CA
    2019 Prius
    Alignment being within spec says nothing. You could have positive camber on one or wheels and still be within spec but it would feel like it was going to lose control in the slightest turn.
    If the alignment shop you took it to doesn't know what optimal is for the Prius, you need to take it to someone who does. Your run of the mill place is not going to know how to set up the alignment on the Prius specifically.
    Also, since it was pulling early one with so few miles, makes me suspect that you had a loose or damaged suspension component.
  3. MagneticGrayIndy
    MagneticGrayIndy 06Prius;94M Miata;65Rambler770
    208
    Indianapolis
    Personally.. I think alot of this is like color or model.. personal taste. I've driven the last model Corolla because I liked the design and was wonderfully unimpressed. It felt very bland to me.. The Prius may not be much better, but I guess I just wasn't looking for handling in the Prius; I'm far more obsessed with the MPGs. Having said that, I certainly don't feel it's any worse than the Corolla. Toyota isn't known for excitement behind the wheel after all. It's known for quality and value.
  4. JamesWyatt
    JamesWyatt Señior Member
    348
    Allen, TX
    Would the Prius' longer wheelbase and wider track having to run on skinnier tires make a difference? I looked up the tire sizes for standard 15" 2008 Corolla tires vs. 16" 2008 Prius Touring. Overall the tires are the same height but the Corolla's are a half inch wider.
  5. Lexus_Prius
    Lexus_Prius New Member
    38
    Midwest USA
