better MPG with seats up?
Discussion in 'Prius c Fuel Economy' started by GeoZoo, Dec 15, 2014.
  1. GeoZoo
    GeoZoo Junior Member
    40
    17
    Generally I always have the rear seats folded flat in my little 2013 C3.
    maybe it is just me and I don't have numbers to quote yet, just a gut thing, it seems I better fuel economy when the seats are not folded.flat.
    Is it possible that they would make that much of a difference?
  2. Tony D
    Tony D Active Member
    469
    132
    Dublin, Ireland
    I assume that you're having a laugh, right?
    PLSPUSH and OldNo7 like this.
  3. Yakoma
    Yakoma Active Member
    470
    125
    sss
    You're talking about your convertible Prius, right? :rolleyes:
    JohnToy, OldNo7, minkus and 2 others like this.
  4. Epiphany2000
    Epiphany2000 Member
    126
    San Francisco Bay Area, CA
    I'm no physicist, but I don't see how the position of the seats would make any difference in terms of weight or air resistance. Seems like superstition to me.
  5. xpcman
    xpcman Senior Member
    1,302
    295
    California - SF Bay area
    You don't have 500 pounds of cargo in the back when the seats are down do you?
    OldNo7, irrational and ftl like this.
  6. fuzzy1
    10,707
    Yes, it is quite possible, through what is known as the 'placebo effect'.
    OldNo7, Ashlem, F8L and 1 other person like this.
  7. robertmaria
    robertmaria Member
    202
    please DELETE this account
    2014 Prius c
    maybe because the batteries are under the rear seats it affects how cool or warm the batteries are and thus the batteries' performance, especially in the Prius c.
  8. mahout
    mahout Active Member
    655
    116
    NC
    [QUOthheoretcallyTE="GeoZoo, post: 2113640, member: 120379"]Generally I always have the rear seats folded flat in my little 2013 C3.
    Is it possible that they would make that much of a difference?[/QUOTE]
    theoretically you should get better mpgith seats down because the lower CG would enable
    theoretically you should get better mpg with seats down because the lower CGenables cornering at higher speeds soless accelreration isneeded after the corner but you'd need a very delicate means of measuring the difference. In truth it makes absolutely no differnce. period.
  9. edteach
    edteach Junior Member
    37
    sarasota florida
    2014 Prius c
    I also get better MPG when I am going down hill. I am not sure about this nor can I explain it but it seems like it does.
    I al
    JohnToy and OldNo7 like this.
  10. ufourya
    ufourya We the People
    1,258
    336
    42
    Can we PLEASE have a 'hate' button next to the 'like' button? There are threads and comments that just beg for it. Thank you, Prius Chat, for your consideration of this suggestion.
    Mendel Leisk and Epiphany2000 like this.
  11. frodoz737
    frodoz737 Top Wrench
    4,805
    2,561
    33
    The seat trick only works if you hang your tongue out the left side of your mouth. If you hang it out the right side...it uses more. :rolleyes:
    ITgem679, OldNo7 and xpcman like this.
  12. GeoZoo
    40
    17
    Just want to say that I'm serious.
    I figured seats down would be better because of centre of gravity.
    But, while not much, it seems better with the seats up.
    I guess I see this post seems silly but figured I'd ask. Don't know any other Prius C owners offline to ask.
  13. cmllr
    cmllr Junior Member
    This totally works - drastically alters the aerodynamics of the internal air trajectories while simultaneously adjusting the micro-weight distribution of the internal vehicular positive macro....you know what I don't have time to go into all of the details, take my word - it isn't rocket surgery. o_O
    Andyprius1, OldNo7 and GeoZoo like this.
  14. KennyGS
    KennyGS Senior Member
    1,243
    1,046
    Keystone State
    My wife is always harassing me about leaving the toilet seat up in the bathroom. I hope she doesn't read this thread.
  15. orenji
    orenji Senior Member
    5,887
    3,488
    You don't state if you are driving with the windows down? The air flow within the cabin could create a less or more resistance which would impact your MPG's. It could be just coincidence that you are assuming its the position of the back seats.
  16. fuzzy1
    10,707
    I'd have guessed that with windows open, seats folded flat would have produced better mpg, due to reduced drag against the incoming wind.
  17. frodoz737
    4,805
    2,561
    33
    Depends on whether your listening to the radio or a CD. Government studies have proven a wide range of received radio frequencies are known to cause additional drag and thus avoided religiously by all serious hyper-milers.
    Sorry...couldn't resist. :notworthy:
    Andyprius1 and OldNo7 like this.
  18. orenji
    5,887
    3,488
    You are almost correct, but it actually has to do with if the radio is on or not as the signal creates a drag on the antenna, like an anchor!
  19. frodoz737
    4,805
    2,561
    33
  20. Gabriel Rockman
    Gabriel Rockman Junior Member
    23
    Montgomery Village, MD
    2014 Prius c
    If your driving style is different when the rear seats are folded flat, then it does in fact make a noticeable difference, although it is an indirect cause, and not a direct cause.
