Better to change oil with engine (oil) hot or cold?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by NavyLCDR, Dec 18, 2016.
  1. Mendel Leisk
    41,474
    I've found the leading underbody panel very susceptible to damage when going too far over curbs: it's not so bad going in, but catches and tears as you back off it. I noticed ours was badly chewed, at the circled zone:
    Before:
    Repair:
    That part, to replace, is currently threatening $400 on Amazon Canada :(:
    Meanwhile, $132.80 on the US site:
    Raytheeagle likes this.
  2. Kenny94945
    Kenny94945 Active Member
    850
    426
    Sausalito
    2016 Prius v wagon
    Nice repair in the above post.
    Cut some screen for support and epoxy the break it seems.
    FWIW Noting the orientation of the pan's drain plug, I prefer hot with an extending drain time.
    Additionally, going to a 1970 Ferrari Daytona I recall the service manual directions to change the oil twice.
    Drain, then refill.
    Run engine to temp and drain again.
    Next replace oil filter and do final refill.
    I always termed that an Italian oil change procedure.
    #22 Kenny94945, Dec 21, 2016
  3. Montgomery
    Montgomery Senior Member
    2,254
    2,241
    Orange County, CA
    Which is why you are in the service! Order is everything! I appreciate you and your service!!
  4. Montgomery
    2,254
    2,241
    Orange County, CA
    I use JB weld for things like this also. Works as well and stays put forever.
  5. Mendel Leisk
    41,474
    Yeah I've read good things about it. Was using Gorilla 2-part epoxy. Strong like gorilla??
    Hmm, on jb weld site, just the plastic specific glues mind you, a mere 8 choices:
    Plastic/Composite/PVC | J-B Weld
    They need some sort of chart, showing pros and cons of the various products, best application.
  6. Eastside
    Eastside Member
    129
    82
    NorthVirginia
    I've had good luck using ShoeGoo on the plastic parts . It stays a bit flexible, or maybe one of the JB blends stays flexy too.
    ShoeGoo air dries and does better with multiple layers, I use three. Maybe JB is quicker and easier since it's a mix of product and a catalyst.
  7. Bham_prius
    Bham_prius Junior Member
    35
    bellingham
    Mendel, bummer you need a friend south of the line to have stuff shipped to.
  8. Mendel Leisk
    41,474
    Yeah I tried checking shipping for Amazon US site, but they won't ship out of country. In this case a repair is the best route regardless, but maybe I should look into one of those mail box places.
  9. Bham_prius
    35
    bellingham
    I would totally go the repair route. If you have a big order let me know, I am 20 miles south of the boarder, you can even load up on milk and gas from Costco;)
  10. Raytheeagle
    Raytheeagle Senior Member
    11,265
    15,520
    Bay Area, California
    2019 Prius Prime
    They need some sort of chart, showing pros and cons of the various products, best application. [/QUOTE]
    Sounds like a great idea. Looking to volunteer your services with some of your free time(y)?
  11. Mendel Leisk
    41,474
    Maybe when the Gorilla 2-part is done, lol.
  12. Sam Spade
    Sam Spade Senior Member
    2,036
    1,023
    2017 Prius c
    Can't help but have a big grin at this whole discussion.:D
    I learned a LONG time ago that replacing OR fixing that part was an exercise in futility, at least for me, because both new parts and repairs lasted all of two weeks, if I was lucky.:(
    These days I just let it GO; unless it gets bad enough to hang down so it's obvious.
    That has only happened to me once in about 30 years.
  13. Neohippy
    Neohippy Active Member
    220
    201
    Clearwater,Fl
    2013 Prius Plug-in
    I have to agree with you. I actually cut the door off the access panel to the oil pan to make oil changes easier. It serves no purpose but to make oil changes more difficult.
  14. Sam Spade
    2,036
    1,023
    2017 Prius c
    I doubt that is true. Many things like that are there to direct air flow.....to improve cooling or lessen drag.
  15. Neohippy
    220
    201
    Clearwater,Fl
    2013 Prius Plug-in
    The only purpose it serves along with the rest of the panels are to lessen drag. Having a 6inch opening has not changed my mpg at all. It also makes the oil changes a breeze. Well worth it
    Rebound likes this.
  16. Mendel Leisk
    41,474
    Those underpanels both improve air flow and keep the engine bay warmer. It is frustrating, dealing with finicky fasteners and brittle plastic. But doing DIY oil changes, I've kept on top of it. For example, with every oil change, I pull off the entire engine underpanel. I used the "oil change flap" once, the first time, and decided that's not happening: way too brittle. The whole panel is flexing in concert when you try to bend that flap the first time: poor design.
    Taking off the whole engine underpanel takes all of 5 minutes, and affords a better view of problem areas, the drive shaft boots, potential leak zones, etecetera. And before reinstall I wash the grit out of all the fasteners, coat the bolts in a little oil.
    The repair I did on the at front underpanel is sound, and I think a stitch in time to save nine. Couple that with just avoiding driving too far over curbs, to protect Toyota's problematic design.
    #36 Mendel Leisk, Dec 22, 2016
  17. eliteconcept
    eliteconcept 700 mile club, top tank mpg 69.5
    449
    186
    Indiana
    2022 Prius Prime
    i change mine warm. If i do it first thing in morning I'll drive it a couple miles down the road and come back and get it on ramps and drain it. I'll let it drain while i take care of some other things... check air filter, check levels of other fluids, vacuum interior, get my tools for getting the oil filter off... etc.. usually about 20-25 mins of draining before i put plug back on
  18. NavyLCDR
    NavyLCDR Active Member
    202
    127
    Lebanon, OR
    2024 Prius
    XLE AWD-e
    The front bumper spoiler is completely gone on my car. The bottom radiator support is bent backwards on the passenger side causing a swelling curve in the front of the underbody shield panel. It will take me through February to pay off Christmas and then time to start more restoration on the underside of the car.
  19. Rebound
    Rebound Senior Member
    3,996
    2,644
    Portland, OR
    Just get the stuff you need from a boneyard. It'll be dirt cheap and just as good
