Better to get an eBay charger for $175 or OEM GM Volt charger for $250 (craigslist)?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by MilkyWay, Nov 6, 2017.
  1. MilkyWay
    MilkyWay Active Member
    819
    359
    23
    MI
  2. Pluggo
    Pluggo Senior Member
    608
    532
    Folsom, Pennsylvania
    Your Amazon link shows a cord that does not seem to include the actual charger. Make sure you are not paying for a connector and a long cord, that you would still need to connect to your own charger brick. One reviewer pointed this out and gave the product only a single star for not mentioning that detail. At least the eBay item is complete.
    MilkyWay, jerrymildred and SFO like this.
  3. MilkyWay
    819
    359
    23
    MI
    I went with the eBay charger for $175.
    Had no idea if it would work since the 220K-plus mile prius I bought didn't have one in vehicle.
    Well, it worked. Lights up on fuel tank, lights up charging on charger. Displays on dash with time remaining.
    Take roughly 3 hours or so and dash shows about 11 or 12 miles in EV mode. It's a pretty cool feature but I know this will be considered "a classic" in about 1 or 2 years.
    A friend just bought a 2018 Honda Clarity that is 100% electric and goes 90 miles per charge. I'm sure that will double in 5 years.
    bisco and Pluggo like this.
    49,813
    already a classic.:cool:
    Tracksyde and Prodigyplace like this.
  5. Pluggo
    608
    532
    I think your friend may not be clear on the Clarity. Yes, MPGe is in the 100 range, and yes, the propulsion is 100% electric, albeit with a supplemental gasoline generator, but actual EV miles are just 47. Still, that's 4x better than the PIP, and the base price ain't half bad.
  6. MilkyWay
    819
    359
    23
    MI
    Thank you for the........clarification
    Pluggo likes this.
  7. Eodguy
    Eodguy Junior Member
    Seattle
    My 2017 volt charger works fine on my Prius and the volt charger can run level 1 or level 2 all I did was make a 110 to 220v adapter for the plug and it charges level 2. I charge my volt level 2 everyday and my prius on level 1.
