BEWARE! Gen 3 catalytic converters are as easy to steal and Gen 2's.
Discussion in 'Gen 3 Prius Main Forum' started by Georgina Rudkus, May 2, 2021.
  1. Mendel Leisk
    41,462
    Finally had a good drive, today, and no rattles. Will get the front back up and apply Permatex Red ThreadLock to the bolts at the outside of the chain wrap, 3 of them.
    DogDaze and Grit like this.
  2. Mike Bezuyevskiy
    Mike Bezuyevskiy Junior Member
    25
    Chicago, IL
    Did you have success with the aftermarket cat?
    Is it for a 3rd gen?
    I was advised to avoid the $100-200 eBay/amazon cats as they will constantly throw codes but I'm tempted to do the same thing. Just having a hard time finding one that is highly reviewed for a 3rd gen.
  3. VIP_de_Big
    VIP_de_Big New Member
    NY
    So this is the chain method I read about but actually see the application 1st time.
    This seems to be the cheapest yet quite effective method.
    Can the whole thing be unwound by cutting a single link ?
  4. Mendel Leisk
    41,462
    No, there's multiple bolt-and-nut between pairs of links on the way in. Two on the outside layer have permanent loctite on them. With concerted effort and an angle grinder you could get it off, but I'd speculate it'd slow them down about 15 minutes, and be protracted noisiness.
    DogDaze, xliderider and Grit like this.
  5. VIP_de_Big
    NY
    Now this gives me an idea...I'm thinking of barb wires...flexible type of course.
    ccna101, bisco, DogDaze and 2 others like this.
  6. fuzzy1
    10,452
    Do use stronger barbed wire than anything I've seen on the ranch. All those are easily clipped.
    And longer sharper barbs too. Ordinary leather gloves are adequate for protection from common wire, and cows love them for scratching their many itches.
  7. wr69
    wr69 Member
    143
    79
    portland, or
    Just a comment on the chainmail wrap. While I think its a good start, what actual deters thieves with bike lock chains is a nice floppy chain. that way, as the sawzall is attempting to take a first bite, the chain is flopping all over the place. Hence, the thief can never get in a good first cut. With a nice tightly wrapped chain, suspect said thief will plow through those links pretty quickly. In fact, those links could be cut with bolt cutters quickly. bike chain links are much thicker to deter such activity. Lastly, if chain is wrapped and you only need one link cut to start unravelling - well - the rest is history.
    So my input would be to modify the design - maybe weld a circular or square tube-type thick-gauge collar around that weak point. it would be more work though, as you would have to bend in place. when it comes to sawzalls, and cuts, anything with a square edge on it - as opposed to round - it more of a deterrent. square is hard to cut.
    DogDaze, mikey_t and Mendel Leisk like this.
  8. wr69
    wr69 Member
    143
    79
    portland, or
    Just in case would-be thief finds this link, here is a deterrent - LOL!
    Man crushed by a Prius while trying to steal catalytic converter, deputies say (wafb.com)
    https://www.wafb.com/2021/12/14/man-crushed-by-prius-while-trying-steal-catalytic-converter-deputies-say/
    And supposedly G2 Prii have more valuable metal than G3 - not sure about G4, but think its probably less desirable too.
    Here in Oregon, the real solution was to discourage the metal recyclers via legal changes. they basically cannot accept any more non-certified CC, or ones without some sort of auto registration. I suspect if we hold tight another year or two, this problem probably will go away or drastically drop off. If you live in a state with backwards legislatures, maybe it will take longer. Lobby your state government - nevertheless!
    Bill Norton, CR94 and mikey_t like this.
  9. Stu Wood
    Stu Wood Junior Member
    Bellevue, NE
    Did mine today just like your picture. Rather easy.
  10. bisco
    51,942
    even a tight chain is likely to move enough to prevent the blade from cutting. thieves move on pretty quickly when things do go as planned.
    there are plenty other prius in the sea
  11. Taxi/Limo
    Taxi/Limo Active Member
    524
    107
  12. Mendel Leisk
    41,462
    I think it was around 6’ of chain (had it), inside dim of link opening about 3/8”, secured with 1/4” (or 5/16”?) bolts/nuts. I put on a bolt every wrap, and the two outermost have permanent thread lock on the threads (can be removed with some effort and a heat gun).
    mikey_t likes this.
  13. Taxi/Limo
    524
    107
    There is a local muffler shop that will weld rebar around the cat converter for 100 dollars
    I think I will go with that
    CR94 likes this.
  14. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,465
    2,429
    Taylors, SC
  15. wirelessjava
    wirelessjava Member
    104
    23
    Union City, CA
    Has anyone used the Toyota OEM Shield ? Is it garbage?
  16. DPri
    DPri Junior Member
    40
    Earth
    Are you serious?, have you been sleeping under a rock for the past couple of years?.. lol :)
    Prius Gen3 was one of the primary target around here for as long as I can remember since mid of 2020. We have tons of mid class and luxurious cars parked 24/7 on the streets but they targeting Priuses 95% most of the times while turning blind eye on the rest.
    10 day ago cops catch another few individuals in my area (see Pictures below)
    Note: there 5 Prius Gen3 cats and one from looks like new Toyota\Honda Suv or pickup.
    #56 DPri, May 29, 2023
  17. Georgina Rudkus
    3,465
    2,429
    Taylors, SC
    Not asleep under a rock, dude! The thread was started in two years, ago in May 2021.
    It would be helpful if you gave us an idea of where on earth you reside.
  18. Mendel Leisk
    41,462
    Is there such a thing? Dealerships have been installing shields, but they're aftermarket as far as I know.
    xliderider and Georgina Rudkus like this.
  19. Mendel Leisk
    41,462
    No kidding.
    Off-topic: I can picture a discussion between a couple of semi-intelligent entities from different planets, different solar systems:
    "What do you call your planet?"
    "Dirt."
    "Huh; we have pretty much the same name."
    Kromis and Georgina Rudkus like this.
  20. Grit
    Grit Senior Member
    6,573
    4,226
    Wilkes Land
    Yes, works great. Don’t do aftermarket no matter price
