BG Products fixed his Prius oil-burning problem - comments?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by NewHybridOwner, Oct 18, 2019.
  1. NewHybridOwner
    NewHybridOwner Active Member
    607
    283
    W. Michigan
    OK. I did that -- oil change at 38K+ miles. I took a sample of oil before giving it the EPR treatment, then took a sample after using EPR and put drops of each on a paper coffee filter. No difference that I could see: nothing like the "melted chocolate" appearance of the EPR-treated oil I drained from the Vibe with 166K miles (which might have run on "dino oil" before I acquired it; could that make a difference? Does synthetic oil leave less residue?).
    I don't see any reason to try the EPR again before 100K miles -- if then.
    #21 NewHybridOwner, Oct 14, 2020
    Meg&Bear, mikey_t and Grit like this.
  2. NewHybridOwner
    607
    283
    W. Michigan
    I forgot to mention that the old oil filter looked really black, but I don't recall the color of the previous one I took out. But if they were different filters they could have looked different anyway, I suppose, even without having used EPR.
    Grit likes this.
  3. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Great test, been wanting someone to do a test like that thanks.
  4. k1ngn0thing
    k1ngn0thing Member
    205
    51
    MA
    2016 Prius c
    how do you keep the car running at 1200 RPM for the 10 mins required for EPR?
    Meg&Bear likes this.
  5. SFO
    SFO Senior Member
    5,302
    4,252
    Northern California
    Meg&Bear, mikey_t and k1ngn0thing like this.
