Big black block!
Discussion in 'Prime Plug-in Charging' started by MommysPrius, Jun 30, 2019.
  1. alexatie
    alexatie New Member
    Boston
    Why not the heavy duty one? it's the same price as the medium duty one.
    https://www.lowes.com/pd/Utilitech-Pro-15-Ft-12-3-SJTW-Yellow-Extension-Cord-w-Indicator/1003051800
  2. m8547
    m8547 Senior Member
    951
    631
    Colorado
    2018 Prius Prime
  3. m8547
    m8547 Senior Member
    951
    631
    Colorado
    2018 Prius Prime
  4. m8547
    m8547 Senior Member
    951
    631
    Colorado
    2018 Prius Prime
  5. m8547
    m8547 Senior Member
    951
    631
    Colorado
    2018 Prius Prime
  6. LigiaOzimek
    LigiaOzimek New Member
    Los Angeles
    2012 Nissan LEAF
    I can do anything else to support the block. The outlet is pretty high. Chest level.
  7. Old Bear
    Old Bear Senior Member
    712
    1,050
    Boston, Massachusetts USA
    A similar 10-ft 12/3 cord with a lighted end (which indicates that the power is on) is available from Amazon:
    There is also a shorter 6-foot version available:
    12-guage wire is the same size as is used for most 20-amp 120-volt circuits and therefore the cord should have no problem handling the 12 amperes which the Prime's OEM charger draws.
    I keep three of these cords in a bag in my Prime. They have been invaluable on many occasions when there was an outlet available but it was not adjacent to where I could park.
    Although this is an old discussion thread, I figured that I'd offer the information anyway.
  8. Old Bear
    712
    1,050
  9. Salamander_King
    Salamander_King Senior Member
    11,024
    8,980
    New England
    Not sure if you are asking how to support the brick. At least, Toyota OEM EVSE comes with two eyelets on the brick that you can use to hook it on the wall. The hook and hanger wire loop do not come with the EVSE, but it can be an easy DIY.
    #29 Salamander_King, Sep 29, 2021
    alexatie, Prodigyplace and pghyndman like this.
