bigger wheels on gen III prius II
Discussion in 'Gen 3 Prius Accessories and Modifications' started by ridegsxr714, Jul 18, 2009.
  1. sleeka
    sleeka Member
    249
    Brisbane. Australia.
    Wheels are Silver BSA AU334 17"x7".
  2. ridegsxr714
    ridegsxr714 New Member
    63
    bellingham
    looks great!
  3. 32kcolors
    32kcolors Senior Member
    5,683
    954
    124
    Redondo Beach, CA
    What tire size? Am I correct that they have no rim protector?
  4. santaclaraguy
    santaclaraguy New Member
    Oregon
    Those rims look great!
    SCG
  5. ridegsxr714
    63
    bellingham
    here's some photos of some 2010 Prius's with larger wheels.:cool:
  6. Bambam650
    Bambam650 New Member
    28
    Cincinnati, OH
    Ridegsxr............thanks for the photos. I really like the 10-spoke wheels on the white prius, far right second row. Does anyone happen to know what wheels these are?
  7. Bambam650
    28
    Cincinnati, OH
    What do you all think of these wheels. The price sure seems right and the salesperson told me they're around 17 pounds. I like the clean look. It is the Motegi SP10, $106 at Elites-Wholesale.
  8. Dakine50
    Dakine50 Member
    148
    22
    Nor-Cal
    I think they look great! After weeks of trying to find the "right wheels" for my car, I chose the 18 x 8 SP10's in hyperblack.
    The only issue I had with these wheels were the "dual-drill/pick-a-pattern" lug holes. I would have much preferred a dedicated wheel. That said, for the price you can't go wrong especially with a wheel weight of 18.3 lbs (18" wheel) vs 24.2 lbs (17" factory wheel). :)
  9. madoue
    madoue New Member
    53
    Hi there. I have found some 17" rims I want for my Prius III. Can anyone tell me if these are OK specs?
    [​IMG]1926-873517x7Chrome5 on 100mm+38 mm5 7/163087-06
    1400 lbs.
    21 lbs
  10. jsharpe
    jsharpe Member
    111
    26
    I've read on other threads here that the OEM 17" rims is have an offset of 50mm and the 15's have an offset of 45mm (same as Gen2) so the 38mm of these will cause them to stick out a bit.
  11. moner
    moner New Member
    302
    59
    Vancouver, BC
    I am also considering these same wheels, but in Hyper Black. 17 pounds for 17 inches, not bad! Now I just need to try to find them at a good price here in Canada...
  12. 32kcolors
    5,683
    954
    124
    Redondo Beach, CA
    Looks too busy to me. I much prefer sleeka's rims.
  13. jonnybonz
    jonnybonz Junior Member
    23
    New Jersey
    Hi Dakine50,
    Can you post some pics of your new wheels?
  14. madoue
    madoue New Member
    53
    I have looked all over the web and can't find 17" rims with an offset more than 42mm. Does anyone know where I can get an offset of 50mm on an after market rim?
    Thanks
  15. Dakine50
    Dakine50 Member
    148
    22
    Nor-Cal
    madoue, try "Tirerack" and search for rims made by 57 Motorsport. And bring plenty money @ $345.00 a wheel..........
  16. Dakine50
    Dakine50 Member
    148
    22
    Nor-Cal
    jonnybonz, I will try try post pics later in the week. :) I wanted to post pics of my car with lowering springs but at the moment none are confirmed for USDM Prius.
  17. jsharpe
    jsharpe Member
    111
    26
    They do seem to be a bit rare. I did find some others at TireRack with the correct offset for $199 (and a bit cheaper other places). They are the Enkei SC05 and although not terribly light they are less than the OEM rims at 20.5
    They also have some lighter models, but they cost quite a bit more and I just want these for some dedicated snows so, in addition to cost, the fact that they are painted also matters (mag chloride eats bare metal).
    p.s. Yes I know that narrower higher profile tires will have better snow traction, but I'm willing to make that sacrifice for all the dry road winter miles as well as the appearance of the lower profile tires. I've always done just fine with all seasons but having a bit of extra stick will make my wife more comfortable since we traded an awd vehicle for this one.
  18. wvgasguy
    wvgasguy New Member
    1,255
    185
    a
    If you are just using them for snow tires then a heavier wheel may not have much overall impact since it will be a short duration and you'll lose FE with the snow tires anyway. Consider the Scion Tc wheels. You can get them pretty cheap on eBay and they look similar to what's in the picture.
  19. jsharpe
    jsharpe Member
    111
    26
    I did think about the Scion Tc option and certainly like the price better, but unfortunately it appears that they have a 45mm offset and I really want to stick with the 50mm offset of the package V rims.
  20. Dakine50
    Dakine50 Member
    148
    22
    Nor-Cal
    Here you go....
