biggest prius disappointments?
Discussion in 'Gen 2 Prius Main Forum' started by Garsen, Aug 8, 2005.
  1. maggieddd
    maggieddd Senior Member
    2,090
    Boston
    did you re-upholster it yourself or did you have a pro do it?
  2. Marlin
    Marlin New Member
    1,407
    Bucks County, PA
    I'm seriously considering doing it. The underside of the console lid has four screws that look like they hold on the fabric covered part. Maybe this weekend I will try removing the screws to see what happens.
  3. maggieddd
    2,090
    Boston
    let us kknow
  4. momsum
    momsum New Member
    73
    Hudson Valley, NY
    I just ordered a tan leather cover from prius hoods on ebay. The reports from her customers on that site were all glowing and raved about the fabric and fit. She also makes them in black. Haven't gotten mine yet so I can't say any more...but try there and see what you think
  5. maggieddd
    2,090
    Boston
    what's the name of the seller?????
  6. maggieddd
    2,090
    Boston
    found it, thanks
  7. ryogajyc
    ryogajyc Active Member
    985
    165
    Reseda, CA
    Glad to be of help!
    Hm, I interpreted your post to mean you are considering re-upholstering the center console, but I think others interpreted it as you already had... If you haven't yet...
    http://wakeup.to/priusdisplayhood
    One of PriusChat's sponsers makes a center console cover as well as other accessories. I have not tried any of those accessories, but others seem to be happy with and and I think you should try center console out.
  8. blippo
    blippo New Member
    255
    VA
    Yes, some kind of padding for both your elbows would have been nice.
  9. DocX
    DocX New Member
    Portland Ore
    I found if you keep the hatch open for a long time, something will sort of dry up the hatch becomes hard to close. Spraying some silicone on the moving part of the two supports fixes it.
  10. sorka
    sorka Active Member
    1,034
    199
    Merced, CA
    2019 Prius
    Bluetooth comes out of the tweater and woofer on my '09 and sounds perfect. By far the best of the dozen or so car bluetooths I've used.
    Did they change it at some point?
  11. nascrlvr
    nascrlvr nascrlvr
    1,200
    25
    Pacific Northwest
    I bought the tan leather console cover from Prius Hoods. They were a quick ship and I really like it. Also bought the MFD hood and SK leather case on another order. Highly recommend....
  12. Ceres
    Ceres Junior Member
    35
    2011 Nissan LEAF
    The things that bother me the most are the large blind spots and the way the car shakes at a stop when the ICE shuts down. The first can be quite dangerous, and the second is just embarrassing when you have passengers.
  13. blippo
    blippo New Member
    255
    VA
    Excellent, I just ordered one
  14. ETP
    ETP 2026/2021 Prime/24 Venza Limit/B52-D,G,F,H
    2,806
    1,170
    Auburdale FL
    Mine sounds better than my phone. Excellent blue tooth!
  15. ETP
    2,806
    1,170
    Auburdale FL
    However, I would like to strangle the navigation and seats.
  16. Aegison
    Aegison Member
    404
    32
    36
    Southeast MI
    I have a 2009 Touring with the gray interior. My first "complaint" is the absurdly low quality of the interior for the price point of the vehicle, even given the extra costs a hybrid system adds. For example, there are several different shades of gray in the interior. Getting diverse materials to all look the same color isn't a new issue for car mfgrs ... it's been there forever, and established brands have long-since built color consistency into the design / mfg process. Toyota has demonstrated its ability to do this in those of its other, less-expensive models I've looked into. But on the Prius, it cries out "cheap...cheap". I'm going to eventually do two things at minimum. First, recover the seats and armrests ... not sure which one, but I'll use a kit to do it. Katzkiin is one of the more costly but hi-quality options I've looked at. Then, second, I'm going to paint a few of the gray or interior surfaces to match the seat color, or, one of the other shades of gray in the interior. (I've gone through this in detail with an auto paint shop, and it's very much possible and can be long-lasting with proper prep for the paint.
    My second disappointment is the (from the factory) inability to run only on the battery for a time after start-up -- efficient for the drive to the bank or a near-by restaurant. These two frequent short trips, and other similar ones, shouldn't require the ICE to run unless the battery gets too low from prior useage. Yes, there's a work-around which we can purchase, but with a new car with only 2k miles on it, I'm very afraid of making that modification for fear that it will be used as an excuse to void warranty if something serious comes up ... maybe in ten or twenty thousand miles ... but not now.
    Lastly, and a big issue with me, is that the spare tire well will not hold a full-size spare, at least not for the Touring. I've been stranded before on a holiday weekend with a no-repair flat, and only the donut spare to use. That, plus the relative scarcity of our matching tires, is criminal. I'm probably going to tie-down a full size spare in the luggage area for any long trips I take, even though that makes it hard to use the extra storeage space below the floor to the trunk area.
    Still, I'm glad I bought it and am working at learning how to drive it most efficiently.
  17. ETP
    2,806
    1,170
    Auburdale FL
    The package 6 is much better but still not as good as the Camry or Civic with leather. I almost bought the Camry hybrid but my wife said no. It was perfect!
    Have you pumped up those tires yet? I am at 44PSI and on smooth roads it is fine. Not for rough roads.
  18. Aegison
    Aegison Member
    404
    32
    36
    Southeast MI
    I did consider pkg 6, but that of course requires getting the navigation system. I'm going to get a nav system which I can switch back and forth between my two cars, so I hated to pay for the factory pkg. In truth, getting just one system will make it easier to operate vs having to learn commands etc for two systems and not get them confused. And, I can choose whatever system I think will work best for me out of the many available.
    Ahh..... Tire pressure. At this point, I'm establishing my base line by leaving psi at factory settings and tracking mpg on a spreadsheet. A little while down the road, I'll raise the psi a bit and find out what that does to mpg over a period of time, then push it up yet again ... I do have the Touring model, so it's possible I may suffer harshness on the roads more quickly than the std model does, and could therefore find I'll have to settle for a lower boost in psi. In any case, I'll post results when available. Of course, with the mpg the Prius gets, it takes forever to do this process :)
    Have you pumped up those tires yet? I am at 44PSI and on smooth roads it is fine. Not for rough roads.<<
  19. sas0611
    sas0611 Member
    230
    Fog Lamps do Nothing
  20. freo-1
    freo-1 New Member
    180
    22
    Mass.
    I wonder if there is a QC issue. My package #6 looks great! After application of Meguires leather conditioner, it looks stellar. My sister in law has the Camry with leather, and the Prius looks just as good.
    Actually, the best leather I saw in a reasonably priced car was the Ford Fusion Hybrid (very sturdy looking).
