Biggest tires you can put on a stock Prius?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Higgins909, Sep 9, 2020.
  1. Higgins909
    Higgins909 Member
    257
    58
    2010 Gen 3 III trim. This has recently crossed my mind. I've seen examples of people putting bigger tires on the stock 15" rims but they also have a Tema 4x4 lift. It looks like there is quite a bit of room. The main worry would be the front when turning. Using tiresize's calculator 205/65R15 sounds like it would fit and wouldn't mess the speedo up too much. I've recently realized the Prius V actually has bigger tires/rims than the regular Prius. Probably half a year ago I saw one at the bank and was checking out it's tires and thought they looked kind of big.
    Not sure I will go this route, if I actually ever buy tires, but does anyone know the biggest you can fit on a stock Gen 3 Prius?
  2. w84me
    w84me Active Member
    144
    224
    16
    Sacramento
    Give priusoffroad a follow on social media. They are fitting a 215/70/15 with their lift on a gen 3. All other info can be found on their page
    PriusOffroad likes this.
  3. Grit
    Grit Senior Member
    6,146
    4,057
    Wilkes Land
    Someone post the gen 2 prius with the monster wheels on please.
    TheLastMojojomo and Mendel Leisk like this.
  4. RRxing
    RRxing Senior Member
    2,519
    1,790
    NEPA
  5. Higgins909
    Higgins909 Member
    257
    58
    I could not find them with "priusoffroad" searched in google.
    I've needed new tires for a very long time and keep putting it off. At the rate I'm going, the car could be done before I put new tires on it. If the car passes my oil test, I will put some money into the car. Some of the roads I drive on are kind of shoddy and I want more comfort and newer tires that are not the cheapest tires you can get, must have better handling as well. (I'm looking at a bigger tire for comfort and a better tire for handling)
    Feeling around I think I could safely put 215/XXR15 on, but others input before I spend $400~ on tires would be good. (After my oil test that may start in a week or so, user error) Local shop apparently has a tire I like in 205/65R15 92H, which is the biggest size in a 15 rim that they have, but I'm still looking around and may have found other problems with the car, related to crappy roads.
    ukiltmybrutha likes this.
  6. w84me
    w84me Active Member
    144
    224
    16
    Sacramento
    Priusoffroad - Prius Offroad, Lift Kits
  7. PriusOffroad
    PriusOffroad Active Member
    108
    168
    Chico, CA
    We've gone down this rabbit hole a time or two and have several different answers for you depending on how much rubbing you are okay with. TECHNICALLY speaking a 215/70R15 (27") tire WILL fit in stock form, but it will rub when you bottom out or in hard turns with bumps. With our 1.5" lift we have yet to get any rubbing under any circumstances with a 215/70R15. If you wanted to get rid of the rubbing in stock form you should shoot for an overall diameter of 26". Speaking from experience, 27.4" is the absolutely maximum you can run (regardless of how big of a lift you run, without the tire rubbing on the bottom coil mount of the front struts. 27.6" will just barely rub. Keep in mind if you plan on going through mud, running snow chains, or even small rocks getting caught in the tread you will want some clearance.
  8. Priusjames
    Priusjames Member
    92
    67
    Irvine, CA
    :ROFLMAO::ROFLMAO:
  9. Eddytheemu
    Eddytheemu New Member
    Raleigh NC
    27.5 work very well!
  10. james nancy
    james nancy Member
    110
    24
    suva,fiji
    For the 215 45/17 I used in 2011, I saw someone install 215 55/17 tires. It looks very big. I didn’t meet the owner and I don’t know the effect. 215 45/17 has a diameter of 625mm and 215 55/17 has a diameter of 668mm, which means that the car has to be elevated (668-625)/2=21.5mm/.
    If feasible, I would prefer to replace tires with higher aspect ratio, because low aspect ratio tires are easy to puncture, and the comfort performance is also average. If the tire width is not changed, changing the height and aspect ratio tires will definitely increase the diameter and affect acceleration. It is as accurate as the speedometer, but my speedometer seems to be about 5km/h away from the gps speed.
    [COLOR=rgba(0, 0, 0, 0.87)]
    [/COLOR]
    #10 james nancy, Aug 19, 2021
  11. Mendel Leisk
    38,681
    I think you’re missing a “2”, at the very end of above quote. In other words, the car is lifted 10.75, relative to the 215/45R17. Theoretically. And worth note: the 215/45R17 has slightly smaller OD than 195/65R15.
    speedometer vagaries aside, you will be throwing the odometer off, oversizing tires. And changing things like cornering stability. Hard to say how much, but it is a factor.
    #11 Mendel Leisk, Aug 19, 2021
  12. james nancy
    james nancy Member
    110
    24
    suva,fiji
    The difference in diameter has been divided by 2. A low aspect ratio tire may have advantages in extreme cornering and braking, but it is too easy to be punctured. The shock absorption performance of the rubber also weakens as the thickness decreases. I basically It’s just driving smoothly, so I think replacing it with a tire with a high aspect ratio and increasing the diameter a bit can make up for the error of the speedometer (the table shows 45km/h, the gps shows 40km/h, I believe the gps is more accurate), maybe change to 205 50 The impact of /17 tires will be less, and the friction of the tires will be smaller when the tires become narrower.
    In addition, I am also willing to improve the body a little bit, so that the passing performance will be better, try to avoid things like scratching the chassis, maybe by adding a shock-absorbing spring cushion rubber pad to achieve the goal
    [/COLOR]
    #12 james nancy, Aug 19, 2021
  13. Higgins909
    Higgins909 Member
    257
    58
    So I've put about 2-4k on it since doing both of these things. For a little while I tried out tires only. I only had the fronts rub on some bumps/dips in the road for the most part. Not really sure where it was rubbing. But I was still scraping stuff. Then I got the Prius Offroad 1.5" lift. I did at one point notice a shield in the driver side wheel well coming off. It was more towards the front and inbetween the wheel and engine. Had 1 of 3 push pins left. (Something like that) Fixed it.
    When I first put tires on I thought it was reading 3-4mph lower but I think it's gone back up a little bit. It turns out that this made my fuel mpg trip meter almost dead accurate. I don't remember much about pre lift but I pretty much went from 38mpg to 28mpg from tires. I sure can get my trip meter to say 35mpg on my way to work but it's slower then it was without the bigger tires and I don't have time for that or the people around me.
    Lift wasn't too bad to install. The only difficulty was the front right drive shaft and trying to line the struts back up with the scribe lines we made. I had to take my tires to another shop to install because the first one which I think was a Fire Stone refused. Which was where I had them shipped from tire rack.
    I bought Yokohama Geolandar A/T G015 215/70R15 for my stock 15" rims. I think I settled on 33PSI F/R. 32/30 is more comfortable but you do feel the drag. Took a little getting used to. They put 35 F/R and it felt really floaty/drifty on the highway home. It will go 110mph+ setup like this. These tires are the best I've ever had and am sticking with Name brand tires. My other car had crappy Kumho and cheap brand tires. RIP Honda. My Prius had Douglas all seasons 195/65R15 and they were alright in the dry but really sucked in the rain. There were at least 2+ instances where I'm trying to stop/slow down and it's just not doing it. Pressing the pedal more and more until abs is kicking in. ...Yeah, screw cheap tires.
    I towed a trailer with it, 2040lbs 300-400 tongue, underinflated tires for everything, primarily trailer. Towed it up to 75mph I think it was. Liked 65mph better. Oversized AT tires did not help towing at all. Got about 17mpg towing. Which is pretty much what the smaller pickups get empty. May have drastically increased oil consumption. Random burning smell from AC that I could not trace/figure out trying different settings. I have yet to tow again. At the time I was wanting a boat, still do, but being financially responsible sucks.
    Stock
    AT Tires
    Tires and Lift
    Tires at least unsure if lift
    Towing trailer 2040lbs 300-400lbs
  14. tony_2018
    tony_2018 Member
    204
    61
    You're asked your Prius to do too much.
    Yes buying the right tires for certain conditions is a must, not just go by pricing. Never cheap out on tires.
  15. Plaman
    Plaman Member
    46
    34
    Denver, CO
    Is this a function of the 15" rim design or the actual tire sidewall is what rubs on the strut?
    Is that the oem strut or the excel-g KYB struts?
    Edit: Is it safe to run a spacer to adjust for a bigger tire?
    #15 Plaman, Mar 7, 2022
  16. black_jmyntrn
    black_jmyntrn Senior Member
    1,289
    336
    2013 Prius Plug-in
    it would be the tire.
    they are the same dimensions
    safe in terms of? why not get a different offset versus a spacer?
