Bike rack for Prius v
Discussion in 'Prius v Accessories and Modifications' started by PanthersFan, Apr 25, 2016.
  1. PanthersFan
    PanthersFan Junior Member
    55
    17
    South Florida
    2013 Prius v wagon
    I need a bike rack for our 2013 Prius v Two. I have a U-Haul hitch installed on our Honda Fit and use a 2-bike rack.
    I remember seeing somewhere that hitches are NOT recommended for the Prius v (perhaps by Toyota themselves). Is this true? Is it that towing isn't recommended or hitches in general?
    I'd like to install a U-Haul hitch and use a 2-bike rack. I really hate roof racks (fuel economy hit, inconvenience, appearance). My first choice would be a hitch, provided it isn't bad for the car. My second would be a strap rack to put on the back.
    Advice? Opinions?
  2. rjparker
    rjparker Tu Humilde Sirviente
    11,048
    6,923
    Texas Hill Country
    Yes you can buy bolt on hitches for the v. Not having to do a wiring harness would be a plus. Toyota says no towing in the owner's manual.
  3. PanthersFan
    55
    17
    South Florida
    2013 Prius v wagon
    Thanks. Would a U-Haul one be alright or should I go with something like the EcoHitch? Not sure what the difference is.
    So, to clarify, Toyota says no towing but NOT no hitches? In other words, a hitch with a bike rack is fine for the car?
  4. rjparker
    11,048
    6,923
    Texas Hill Country
    Toyota says nothing about a hitch but says no towing and has a maximum load spec somewhere around 915 pounds I believe. Remember load includes passengers. Here's a couple of videos. There are two sizes of hitches, 1 1/4" and the more common 2".
    If I were doing it, I might evaluate price, bike rack fit to ensure it will clear the bumper, perhaps the racks ability to allow the hatch to open (some swing out of the way), true bolt on (don't cut or weld anything), ground clearance (the v is already low) and maybe degree of rear end visibility.
    and
    and wiring
    #4 rjparker, Apr 25, 2016
  5. lrisius
    lrisius Member
    121
    57
    Illinois
    2015 Prius v wagon
    I've got the 2" Ecohitch on our Prius v. I use it with a Thule 2 platform hitch and they make a wonderful combination for two bikes. Rock solid and convenient
    Occasionally, I will need to carry 3 or 4 bikes and I'm not sure yet what I will do. My concern is that hitch is heavy (50 lbs) and the extension to turn it into a 4 bike rack is another 50 lbs and with the bikes and the leverage, I am concerned about it overloading the mounting points on the frame. I'm leaning toward adding a two bike roof rack for those situations.
    PanthersFan likes this.
  6. ESP Podcast
    ESP Podcast New Member
    Richmond
    Has anyone used trunk mounted racks?
  7. Sooner Al
    Sooner Al Active Member
    385
    340
    Oklahoma, USA
    2016 Prius v wagon
    FWIW I have an older Allen 102N rack I fit tested on our new 2016 Prius v Three.
    icyrius likes this.
  8. Air_Boss
    Air_Boss Senior Member
    4,248
    1,195
    New Yawk
    Saris Bones 3 works fine.
  9. Joe Fisher
    Joe Fisher Junior Member
    44
    Kalispell, Montana
    2015 Prius v wagon
    There isn't any problem with the rack mounting stuff clearing the rear spoiler?
  10. ESP Podcast
    Richmond
    I've mounted the rack and I'll probably mount the lower feet on the bumper and place pads under the straps. They run over the spoiler so I'm expecting some rub.
  11. ESP Podcast
    Richmond
    I'm guessing its the straps rubbing on the spoiler that's the issue. Saris also lists a 2 bike limit for the Prius, whereas other cars, like a VW sportwagen have no such limit.
  12. Air_Boss
    4,248
    1,195
    New Yawk
    No, top arms brace against the rear window and top tension stays latch onto the door structure (flush with spoiler).
  13. lifehouse
    lifehouse Junior Member
    92
    GA
    That looks pretty sturdy enough!
  14. cdnbrit
    cdnbrit Junior Member
    57
    24
    Cambridge, Ontario
    2018 Prius Prime
    Upgrade
    Is that a universal rack? Just checked the Website and it says they don't have anything that fits a PriusV,
  15. Air_Boss
    4,248
    1,195
    New Yawk
    In our experience, the Saris Bones 3 fits anything with a rear deck/bumper from Dodge Grand Caravan to Honda CR-V to Toyota Prius v and carries 3 bikes.
  16. BrandtB
    BrandtB Junior Member
    Raleigh, NC
    2014 Prius v wagon
    I used a Yakima hitch-mount rack when I had my RAV4. I had a hitch installed on the Prius v and have hauled bikes around with no issues.
  17. Joe Fisher
    44
    Kalispell, Montana
    2015 Prius v wagon
    I just put a Curt class 1 hitch on my Prius v today, then ordered a Saris Freedom 2 rack. It's nice and light (only 22 lbs)
    My hybrid bike is a bit too porky to lift onto my roof bike rack. Either that, or I'm getting too old to want to do it. I've used a roof rack for years.
    iDonna likes this.
  18. Bmr4life
    Bmr4life Member
    131
    56
    Atlanta, GA
    2014 Prius v wagon
    For $100 is hard to ignore this one.
  19. Norcal2
    Norcal2 Junior Member
    23
    Sacramento
    2015 Prius v wagon
    Ive been using the Kuat NV for years I have two, here is my 2 bike version I have a 4 also I modified a 1.25 inch hitch and reinforced it to handle the weight I also use a UWS aluminum rear carrier for extra carrying capacity when I need it
