Bike Rack for Rear or otherwise?
Discussion in 'Gen 4 Prius Accessories and Modifications' started by Dan Y, Nov 17, 2021.
  1. Dan Y
    Dan Y Junior Member
    57
    Brooklyn, NY
    2022 Prius
    LE AWD-e
    What recommendations for bicycle racks do people have for Gen 4 Priuses? Mine is actually a 2022, brand new. I had a Thule Passage 2 rear-mounted bike rack lying around but the manual says that it doesn't fit Priuses from 2016-2019 because "Carrier is not recommended because top straps should not be mounted directly to glass or plastic trim covering glass" -- I assume 2022 is the same, not big changes I think in this model. Thanks! Dan
  2. thew
    thew New Member
    Detroit, MI
    2021 Prius
    L Eco
    I had the same question after buying a 2020 this summer. Saris's two-bike racks seem to be the only rear-mounted carriers that work.
    I ended up going with the OEM roof rack since I can use it for canoes/kayaks too. Others recommended a hitch rack--more hassle and $$ to set up but easy once you have it.
  3. Mambo Dave
    Mambo Dave Active Member
    641
    307
    2019 Prius
    L Eco
    I did the OEM roof rack. Many bikes are just too expensive to chance being rear-ended. Considering that some bikes are also back-ordered or sold out through the beginning of 2023, they are too tough to even get to replace one that gets hit.
    Doug McC likes this.
  4. Leadfoot J. McCoalroller
    8,290
    7,806
    Pennsylvania
    2018 Prius c
    If you have a lot of money wrapped up in a really crazy nice bike, put it on the roof.
    If you don't, get a 1upusa bike rack and install a 1-1/4" hitch receiver. Best setup ever for a hitch carry, very high quality and usa-made.
