Biodiesel
Discussion in 'Newbie Forum' started by WaterOx, Oct 10, 2009.
  1. Prius 06
    Prius 06 Member
    283
    29
    Ontario, Canada
    Ok, and what do you do with the oil from the engine???
  2. WaterOx
    WaterOx New Member
    16
    CA
    I keep getting asked the same questions. Please see previous posts. Thanks!
  3. MJFrog
    MJFrog Active Member
    780
    267
    NE Oklahoma
    2018 Nissan LEAF
    His answer was:
    @WaterOx
    So, you use recycled Dino-juice to lube your engine. Great! It uses ~85% (according to the web site) less energy to produce than using crude oil.
    Kinda like how using scrap metal uses ~85% less energy than using the raw ore.
    Also, kinda like how a hybrid uses significantly less petroleum than a standard gasoline or diesel vehicle.
    Looks like we're all on the same wavelength here. It's all just a matter of degree...we're all moving in the same direction.
  4. WaterOx
    WaterOx New Member
    16
    CA
    Exactly MJ Frog! I find it funny that in some previous posts, the Prius owners were somewhat hostile to me. We're all trying to be more eco-aware and all I'm doing is giving another point of view.
  5. qbee42
    qbee42 My other car is a boat
    18,058
    3,081
    Northern Michigan
    Don't take it personally. We get a number of TDI wienies that come in here an spray about how great diesels are and how stupid and useless the Prius is, and how can anybody be so stupid to buy into all of this useless hybrid tripe. It makes some of us a little hyper sensitive, and sometimes we overreact to an honest post. Keep posting: we now understand that you are for real.
    Tom
  6. Prius 06
    Prius 06 Member
    283
    29
    Ontario, Canada
    I keep asking you because you haven't answered what I asked.
    You told me what kind of oil you use, but unless you've only put that oil in and never plan on changing it (or don't have to) you haven't told me what you do with the old oil/filter when you change it.
    Hope this is clearer.
  7. seftonm
    seftonm Member
    408
    78
    Winnipeg, MB
    Waste veggie oil, or anyother sort of non-transesterified vegetable oil, is not biodiesel. I really dislike it when people perpetuate this misunderstanding, it makes others think that vehicles need to be converted to run on biodiesel.
    Anyone looking to run veggie oil in a high pressure direct injected diesel (Powerstroke, TDI, and others) needs to be very careful with their procedures and research to ensure things are done properly.
  8. WaterOx
    WaterOx New Member
    16
    CA
    Yes it is biodiesel. 100%.
  9. seftonm
    seftonm Member
    408
    78
    Winnipeg, MB
    Biodiesel, by definition, is made from transesterified biological based oil. Vegetable oil may be biologically based and combustible in a diesel engine, but is not biodiesel.
  10. dbcassidy
    dbcassidy Toyota Hybrid Nation, 8 Million Strong
    1,581
    290
    Middlesex County, MA
    Waterox,
    How do you test for acid content before using in your car. I am concerned that the acid level could be bad for the pump and injectors.
    Dbcassidy
  11. WaterOx
    WaterOx New Member
    16
    CA
    Acid content? That's a new one.
    By the way, oil prices are on the rise again. As the dollar gets weaker, oil prices go up.
    Oh yeah, I don't need to worry about that...
  12. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    Like any other niche market, and like Tom I remember pellet stoves when they first came out, it's only "free" if a minuscule proportion of the population are aware of it and use it
    If suddenly you had hordes of folks looking to run a diesel powered car or pickup on used cooking oil, restaurants would need security cameras over their deep fryers, and the cost would skyrocket
    Again using pellet stoves as an example: when they first came out, to heat your home was practically free. Not anymore, the pellet fuel has climbed in price to where there is little to no advantage over using natural gas
  13. Prius 06
    Prius 06 Member
    283
    29
    Ontario, Canada
    You still haven't answered my question.
  14. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    This is the basic argument against biodiesel or veggie mobiles that I often use. It is great for a few to run such systems but it cannot be scaled to work for the entire nation. I still believe that a diversity of fuels/power sources is the way to go so I wouldn't knock anyone using vegetable oil or biodiesel but I do feel it is important to put them in their place when they get all uppity and act like this is something everyone should be doing.
  15. tochatihu
    tochatihu Senior Member
    9,936
    3,843
    Kunming Yunnan China
    2001 Prius
    The wikis on this subject explain acids in waste vegetable oil, if you are not put off by the organic chemistry. Waste VO can have acids, and you find out how much by titration. If you trans esterify to make biodiesel (in the strict sense of the term) you are adding excess base so all acid gets neutralized.
    A wide range of organics can be used as fuel in compression ignition engines. Many require at least some degree of treatment before use, if you want the engine to have a long service life.
  16. dbcassidy
    1,581
    290
    Thank you,
    Dbcassidy
  17. WaterOx
    WaterOx New Member
    16
    CA
    Interesting.
