Black Steering Wheel Appliqué
Discussion in 'Gen 4 Prius Accessories and Modifications' started by keymusic, Oct 31, 2016.
  1. UltraJetRefill
    156
    93
    Tucson, AZ
    Quick question since I'm about to install it after doing the shifter applique yesterday. Is it the same 3M tape that Toyota uses? Has anyone who's installed the steering wheel applique had any problems with it coming loose?
  2. bobthejedi
    bobthejedi Active Member
    137
    154
    SF Bay Area
    I don't know if its official or not, but it seems to holding up well for my car and I believe I was one of the first, but I'm not in extreme temperature ranges here in Bay Area, CA
    UltraJetRefill likes this.
  3. steuermann
    steuermann Junior Member
    16
    near Hamburg/Germany
    2018 Prius
    I do not know if it is the same as the Toyota one. I have installed it end January this year outside at around 10°C. Warmed it up a bit with a hair dryer and it is sitting firm and tight. High and dry a sailor would say. Can really recommend it.
    Mike
  4. UltraJetRefill
    156
    93
    Tucson, AZ
    We're already up to 35°C, so maybe I'll be the 'hot' test case. ;)
  5. padroo
    padroo Senior Member
    2,763
    2,253
    I installed mine a while back and forgot about it till now. It is holding up fine.
  6. Hidyho
    Hidyho Senior Member
    2,699
    531
    2018 Prius
    Installed it last week, holding up just fine, gloss looks perfect with the rest of the dash.
    padroo and UltraJetRefill like this.
  7. Luke Warmchops
    Luke Warmchops New Member
    Maine
    I purchased a black plastic cover recently on eBay. The ad said it was only for the Prius Prime, but my local Toyota dealer told me that the original part (the white part being covered) were the same part number on the Prius and the Prius Prime. It fit perfectly. The cost was about $16. This is a much better solution than painting it.
  8. keymusic
    keymusic Active Member
    211
    113
    Southern California
    Do you have pictures or the eBay link?
  9. keymusic
    211
    113
    Southern California
  10. Luke Warmchops
    Maine
    The forum won't let me post the link. You can search ebay with they: Car Steering Wheel Panel Garnish Cover Trim for Toyota Prius Prime 2017 2018
  11. keymusic
    211
    113
    Southern California
  12. thomassster
    thomassster Member
    239
    83
    Colorado, US
    2019 Prius
    XLE AWD-e
    FOr the gearshift panel appliqué, do you transfer over the buttons or does it go right on top? I have a gash that is a sore sight and would like to get a cheaper replacement instead of paying for a full entire part. If it goes on top, wouldn’t the buttons be depressed in?
  13. Trons
    Trons New Member
    Chicago
    This is a great idea! I have the white steering wheel also, and will be trying this option soon! Thanks for the great pics!
    keymusic likes this.
  14. keymusic
    211
    113
    Southern California
    I forgot that this thread was still around. Do you mean the pictures of what I did with the plasti-dip or other pictures?
    Prodigyplace likes this.
  15. Prodigyplace
    12,715
    11,848
    Central Virginia
    How well is that lasting? Like new or peeling?
  16. keymusic
    211
    113
    Southern California
    It’s been almost 4 years and it’s still perfect. When I clean it I wipe it gently though.
  17. Prodigyplace
    12,715
    11,848
    Central Virginia
    I have not found any other matte black solution. I may try that on my 2017.
  18. Peleela
    Peleela Junior Member
    SF Bay Area
    For anyone looking on eBay for this cover (the prior links posted here don't work anymore), try this eBay search:
    Black Car Steering Wheel Panel Decoration Sticker Garnish Cover Trim for Toyota
    krmcg likes this.
