Blacklion Cilerro tires
Discussion in 'Gen 3 Prius Fuel Economy' started by crazyyella, Jun 8, 2015.
  1. crazyyella
    crazyyella Hybrid Neophyte
    Williamsburg, VA
    Last week, after 4 years and 4 months (42,000 miles) on the stock Yokohama Avid tires, I had to replace them. I went with a set of Black Lion Cilerro tires in the matching size for $320 installed.
    I'm not sure if this is normal, but the first tank I used on the new tires netted 47.7mpg vs. 53.7mpg (actual calculations not computer calculations). I'm curious to see if this continues to happen. The gas, temperature, weather, roads, etc. were pretty much all constants. I've estimated that if this persists, I would spend about $20 more per year on gasoline, which more than makes up the difference for another set of the stock tires by about 2x over the estimated life of the tires.
    Any thoughts?
  2. alekska
    alekska Active Member
    435
    138
    Atl
    I have never heard of this brand. I only can assume they are low quality Chinese tires. At $70 a piece you could have bought very nice Continental or Yokohama tires with Low Rolling Resistance.
    Alex
    52,880
    my thoughts are, you should have checked the tyre threads here before pulling the trigger.
    52,880
    but hey, if the ride, handling, smoothness, quietness, rain and snow traction, and longevity are all good, whats 20 bucks a year?(y)
  5. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    "Based out of China, Blacklion tires are made by Jinyu, part of the Sailun Corporation."
  6. bisco
    52,880
    quality company, good rep, so no problem there.
  7. crazyyella
    Williamsburg, VA
    Well, it's been a couple of weeks, and although I haven't burned a tank of gas it looks like the mileage numbers are similar. The upside is that the tires are quieter and more comfortable than the previous tires. This is good for me since many of the regular streets around me have all been chipped and tarred vs. paved in recent years. I'll miss seeing the 52-57mpg tanks, but it is what it is. Thanks for the replies.
  8. JC91006
    16,937
    8,647
    New tires will always have a little lower mpg than your old tires. But if you figure all you're missing out on is $20 a year..........I guess I wouldn't even worry about it. A flat tire repair will cost you that much
