Blackstone Labs ATF fluid report - 2010 Prius
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by bpollard, Apr 15, 2020.
  1. bpollard
    bpollard Junior Member
    58
    Austin, Texas
    Hello, this is for my 2010 Prius with 159k miles on the engine but 116k miles on the ATF fluid. The fluid that was changed out was also Toyota WS ATF.
    My understanding is that the transmission in our EV vehicles don't operate like a normal transmission. Thus, would you be concerned about the comments that Blackstone made regarding the aluminum in the fluid?
    Thanks in advance!
  2. Aaron Vitolins
    Aaron Vitolins Senior Member
    1,612
    1,144
    Franklin TN
    Definitely high aluminum level. You can tell they are a little surprised to not see other high levels of anything else, that’s because there is no clutch packs or anything else like in a traditional automatic.
    The most important thing is at least changing the fluid once, preferably early on like you did. This fluid probably could be good for a while more, but it’s cheap and easy to replace.
  3. 2012 Prius v wagon 3
    2012 Prius v wagon 3 Active Member
    281
    278
    Redwood City, California
    ... and I wonder what exactly "Universal Averages" is for. If it is for "normal" transmissions that use ATF-WS, I would not expect the numbers to match. Our transaxles are very different.
    And when they say, "If it's shifting okay," it also makes me wonder if the analysis is properly considering such a different type of AT as we have.
    If it were my car, I'd ask them about it.
    Thanks for posting these numbers for others to compare to.
    SFO likes this.
  4. Aaron Vitolins
    1,612
    1,144
    Franklin TN
    Yeah I thought the “shifting okay” comment was pretty funny!
    honestly they probably don’t care what type of vehicle or transaxle this comes from, they are just doing the lab work.
    I’d like to use Blakestone labs some day.
  5. GrGramps
    GrGramps Active Member
    294
    176
    Western North Carolina
    I wonder why they didn't comment on the high reading for zinc? Aluminum and zinc are often alloyed and the excess readings show a similar ratio.
    Perhaps Blackstone could explain this.
  6. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    o_Oo_Oo_Oo_Oo_Oo_Oo_O
  7. The Critic
    The Critic Resident Critic
    3,193
    2,333
    CA
    Zinc is an additive.
    Raytheeagle likes this.
  8. tvpierce
    tvpierce Senior Member
    951
    883
    Maine
    2013 Prius v wagon
    Might be worth a follow-up email to explain that in this application the fluid is essentially used as gear oil vs a traditional automatic transmission where is is essentially used as hydraulic fluid. It would be interesting to get their take on it.
    BTW, they should have some experience in this area. Many Borg Warner manual transmission from the 80s used Dexron ATF instead of traditional gear oil.
