Blank under power button?
Discussion in 'Gen 3 Prius Main Forum' started by andreyco, Apr 1, 2013.
  1. andreyco
    andreyco Member
    91
    27
    Still learning about my new car here - does anyone know what the purpose of the blank is under the power button? I know the one in the center gap/store hole near the 12V socket is for heated seats, on the left near the illumination brightness are spots for fog lamps and headlight cleaners...but the one under the power button is placed so awkwardly I can't imagine what you could put there and still have it be useful!
  2. css28
    css28 Senior Member
    1,566
    443
    Suburban Detroit
    I believe it was used for a pre-scan feature in the parking assist system. That system was available in 2010 and 2011 in the advanced technology package, I believe.
  3. Rebound
    Rebound Senior Member
    3,996
    2,645
    Portland, OR
    Optional ejector seat package.
    andreyco likes this.
  4. tumbleweed
    tumbleweed Senior Member
    4,067
    692
    Eastern Oregon
    Correct, it is the switch for the, not so popular, parking assist.
  5. Rebound
    3,996
    2,645
    Portland, OR
    I could have used your help getting them to believe the ejector seat story.
  6. parnami
    parnami Member
    227
    48
    .Lancaster, PA (Amish Country) :)
    I have a v, so it might be different, but my "ejector button" in on the left, next to the instrument panel brightness control/headlight washer button. I've not yet used it though. Has anyone used theirs??? I'm curious how high the passenger flies???
    mrstop likes this.
  7. rsgillmd
    rsgillmd Junior Member
    38
    Memphis, TN
    Did you ever watch Knight Rider? It's based on the same technology, but since the Prius can't talk (yet), you have to program the height that you want to be ejected to. You really must read the manual! ;)
  8. Rebound
    3,996
    2,645
    Portland, OR
    It depends on whether you put the car in Eco or Power mode.
    xs650 likes this.
  9. css28
    css28 Senior Member
    1,566
    443
    Suburban Detroit
    ECO mode just dumps you onto the hood.
    FranklinS, xs650 and andreyco like this.
  10. Tideland Prius
    16,678
    As others have said, it's the Pre-Support function for the Intelligent Parking Assist/Advanced Parking Guidance System for the 2010-2011 model years.
  11. BZzap!
    BZzap! Senior Member
    1,607
    878
    (Q) What's this button do? (A) DON'T TOUCH THAAA.......!!!!
  12. parnami
    parnami Member
    227
    48
    That's probably the reason they removed it from the center stack to a location, accessable, only by the driver. My concern, though, remains about how high they fly. I'd hate for someone to hit their heads on a bridge or tree limb when, all I intended was for them to leave my car.
  13. Spaz
    Spaz Junior Member
    82
    25
    New Jersey
    I have a question about this blank too...how to get it out? I would love to integrate a garage door opener and that's the perfect spot next to the start button
  14. SalixIncendium
    SalixIncendium Tree Hugging Environmentalist Wacko
    155
    68
    Dayton, OH
    Mine talks. Reads me text messages...gives me voice command instructions...tells me to prepare to turn...stay left...where to eat...take the garbage out...oh, wait. The last one comes from the passenger seat.
    rsgillmd likes this.
  15. Sparkman 3
    Sparkman 3 New Member
    Fairfield county ct.
    I've used it once, but you have to make sure the passenger side window is open( I don't have a sun roof) the seat actually tips the passenger to the right, and shoots them out the window. I believe the wife was about 18 feet off the ground,and landed 45 feet from the car..
    parnami likes this.
  16. Spaz
    Spaz Junior Member
    82
    25
    New Jersey
    So just in case anyone wants to know how to get that blank out I found out how. You have to take out the shifter, cup holder, radio bezel and power button out, disconnecting the wires helps but I doubt it's necessary. With that done take a look in the hole with a flashlight and you can see the tab you need to push down with a flat head screw driver. If the top doesn't fall out then, use the screw driver to pry out the top and the bottom will follow...pretty easy once it's done, just be careful with the trim pieces because they are thin and seem prone to breakage
  17. BZzap!
    1,607
    878
    To save you a lot of grief getting those blanks out you can simply pop them out from the front. All you have to do is put some electrical tape along side of the switch blank. This is to keep from scratching the surrounding panel. Then with a nylon glass tool (available at any glass shop or on-line) you just insert it and simply pry out the blank. Even a small screw driver will work but you must use caution to avoid scratches.
  18. Spaz
    Spaz Junior Member
    82
    25
    New Jersey
    I always get nervous using metal tools...I scratched the dash on my first car and never really got over it. Keep meaning to get real tools, a plastic panel removing kit but never actually remember to order it...I guess I just gotta man up and get ovr that fear lol
  19. bubbatech
    bubbatech Member
    153
    60
    Alabama
    That's where I have the Red Button. Never ever EVER touch the Red Button!
  20. Sparkman 3
    I'm not sure why you would remove the blank..but I would just drill a hole in the center of it and pull it out with needle nose pliers
