Bleed needed when changing coolant valve?
Discussion in 'Gen 2 Prius Main Forum' started by cbird02, Oct 26, 2020.
  1. cbird02
    cbird02 Junior Member
    23
    Tucson, AZ
    Getting ready to change my coolant control valve on my 2009. I am ordering hose clamps to close off all three coolant hoses before R&R. Do I need to bleed the coolant loop if I use the clamps?
  2. Frontporch
    Frontporch Active Member
    552
    128
    Nj
    i just did mine this past weekend. I also attempted to use two clamps and a vice grip. would have worked out fine except the vice grip (the easiest of clamps was not tight enough. I lost a lot of fluid in the process. Even so, I captured it in a drain pan and after I was done, I slowly added a similar amount of fresh coolant directly to the radiator and topped off the expansion tank. Went for a drive, heat on. Later topped off the radiator and expansion tank. I think all is good now. During the first drive I heard a rush of bubbles inside the dash, but nothing since right after startup.
  3. Prius717
    Prius717 Junior Member
    51
    Lancaster County PA
    Curious on this, have to replace my valve as well.
  4. cbird02
    23
    Tucson, AZ
    I was going to buy these at Harbor Freight. I will get two of them if needed just in case the smaller ones won't work. I am thinking I can use the 1 3/4" and the 1" but the others will be too small. What size are the hoses?
    Fluid Line Clamp Set, 4 Pc.
  5. Aegean
    Aegean Active Member
    464
    209
    Alexandria VA
    I tried clamps but they were leaking. So I emptied as much coolant as needed and after replacement of the valve I used the tool below to fill up the coolant system and bleed it.
  6. cbird02
    23
    Tucson, AZ
    Pretty cool toy. I am curious - what clamps did you use?
  7. Aegean
    464
    209
    Alexandria VA
    The clamps were plastic with screws and they stopped 90% of flow but not completely. I wouldn’t mind but the problem was when I was under the car coolant was leaking everywhere. Much better to let it drain in a bucket before you work on the valve.
  8. cbird02
    23
    Tucson, AZ
    I am going to opt for the repair from the top, loosening and propping up the inverter. Hopefully, the metal clamps will stop 100%. I will report back next weekend after repair.
  9. Aegean
    464
    209
    Alexandria VA
    I did the same and took out the two hoses from the top but then took out the third from the bottom. I had the car on ramps just in case. Since I was under and nothing was holding the valve I lowered it from under the car. It could be done from the top as many have done. Good luck!
