Bleeding boards mod help
Discussion in 'Prius PHEV Plug-In Modifications' started by Flying White Dutchman, Jul 2, 2012.
  1. Flying White Dutchman
    4,376
    314
    Its off now test
    -Htc Tapatalk ( sorry for auto spell correct )
  2. Flying White Dutchman
    4,376
    314
    Attached the bleeding board
    It got hot cells was at 3.71 Buth at 3.68 volts already cooled down.
    Almost seems that Its from 3.7 down to 3.68....
    Only a small amount down of bleeding voltages start
  3. Flying White Dutchman
    4,376
    314
    At 3.71 Its really hot and that with the max 300mamps of bleeding
    I think the curve where Its maxing out the 300 m amps is now lowered
    Before it was at 3.8 now it seems to be already at 3.71
  4. jaso
    jaso Junior Member
    You can only compare 100mA before with 100mA after the change or 300mA before with 300mA after. If you have higher bleeding current at the same voltage it means bleeding have started earlier (at lower voltage) - which is what I expected. I can't give you exact calculation and further advise as all resistors as well as U1A regulator are produced with certain accuracy. Change and try is the only way or arrange for a testbench.
    Jacek.
  5. Flying White Dutchman
    4,376
    314
    thats not what i tried to explain
    before the bleeding started at around 3,7 and went up
    this now seems to be steeper it seems to reach the 300maps sooner but does not start sooner with bleeding.
    its climbs faster
    but not sure about this.,, testing is a bit difficult
  6. jaso
    jaso Junior Member
    Hi Dutch,
    Testing is easy... I would attached schematics but due to any reason PriusChat doesen't accept my URL.
    Configuration is +12V (battery or PS) - 1kOHM resistor - red bleeding board wire - black bleeding board wire - -12V (battery or PS). Then just measure voltage (DVM) across your bleeding board. Now you can compare pre- and post- mod boards.
    Jacek.
