Blew out a tire and have a question...
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by ssdesigner, Aug 14, 2018.
  1. ssdesigner
    ssdesigner Active Member
    304
    241
    california
    2013 Aqua
    Sidewall puncture on the freeway yesterday on my 2016 Prius 2. The car just hit 10K miles and 75% of that has been driving at 30MPH speeds. Tire was the rear passenger side.
    I'm wondering how picky I need to be about matching this tire? I'm assuming that putting a new one on is just fine?
  2. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    Personally - I wouldn't go out of my way - with 10,000k they're fairly close to new. But, if you're concerned, put the new one on the back as the drive axles are at the front, though I would think the rolling circumference would be similar.
    While touring (on a VOLVO) and having a blow-out a long way from home, I replaced just one tyre as the others were almost new - but it was a different brand, same size. Worked fine.
    If you can match the brand, it would be the most ideal situation, though.
    krmcg likes this.
  3. Starship16
    Starship16 Senior Member
    1,348
    1,455
    Beach Christmas
    I would buy the exact same brand of tire,
    with the exact same tread pattern. But that's just me because I'm picky.
    And if you don't mind me asking, how does a person drive a Prius at 30 mph 75% of the time? Do you do that purposely, or is there so much traffic you can't go any faster?
    (And are you related to a man named Kevin in California? :ROFLMAO:)
    Live a little, buddy! Put that Prius in Power Mode! Let 'er rip! High MPG is boring. ;)
    krmcg likes this.
  4. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    I had the same thing happen @ 16k. I replaced it with a matching new and it's been fine since (two years and another 20k). Install on rear as best tires should go on back.
    krmcg likes this.
  5. ssdesigner
    304
    241
    california
    2013 Aqua
    My commute to work at 5:00am is 3 miles and it would be out of my way to get on the freeway.
    Once I add the M3 to my fleet I will absolutely be looking for a freeway to drive on ;)
    alanclarkeau and Starship16 like this.
  6. wjtracy
    wjtracy Senior Member
    11,374
    3,609
    Northern VA (NoVA)
    We had blow out and repalced with same kind of tire (on warranty from TireRack) on rear tires.
  7. Lucifer
    Lucifer Senior Member
    1,014
    486
    Nh
    Why not measure the tread of the others, if it’s an oem tire, it’s easily half way through it’s life, a new set of Michelin defenders would be trouble free for years.
  8. booke02
    booke02 Active Member
    391
    415
    Israel
    I am not an expert on the subject, but I always understood that each axle should have matching tires. If you have different treads on the same axle, I could imagine that each side could behave differently when braking, etc.
    (But maybe that is out-of-date information - I started driving when you indicated a stop or turn by sticking your hand out of the window)
    ITBland, alanclarkeau and Starship16 like this.
  9. ssdesigner
    304
    241
    california
    2013 Aqua
    Looks to be plenty of tread left...
  10. alanclarkeau
    7,045
    7,593
    Yes, that's a good point.
    In the olden days of drum brakes where ABS, Brake Assist, ESC and EBD, didn't exist, braking was very much an approximate situation. It depended on the adjustment of each wheel, the tread of the tyre and the skill of the driver.
    Oh, and in those days, tyres regularly blew out or wore unevenly due to bad brakes on one wheel, money was scarce [not that it's common now] - and it was common to see a Dunlop on one corner, 2 Goodyears diagonally opposite and a retread for the other and for the spare - which was invariably almost bald. We also had to check pressures at least weekly, and invariably have to pump one or other up, meaning that our tyre pressures were all over the place.
    Today, we've got very good tyres in comparison, ABS which (simply put) stops wheels locking under braking, and with EBD as well, distributes the braking forces between each wheel.
    In @ssdesigner 's case, the original tyres wouldn't have had appreciable wear. It's be different if the other 3 had done 40k.
    Ideally, a replacement of the same brand would be best if available.
    krmcg likes this.
  11. Mendel Leisk
    42,347
    What were the tires that were on there?
    Our son had a sidewall bubble on a snow tire that we replace with at least 10K miles, so some difference in tread depth, something like 8/32 vs 10/32, and it was fine.
    It'd be better to check the tread depth with a kosher tread depth gauge. Look what you've pushed me to, lol:
    This is just measuring (on screen, and extrapolating) the width of the coin where it crests the tread, very rough, and the stat that the US penny is 3/4" inch diameter.
  12. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,528
    Bay Area, California
    2019 Prius Prime
    I enjoy it when the autocad comes out:).
    Always good to see the draftsman in action(y).
    RRxing, Mendel Leisk and alanclarkeau like this.
  13. ssdesigner
    304
    241
    california
    2013 Aqua
    @Mendel Leisk - They are the original Toyo NanoEnergy A29's.
  14. Prodigyplace
    12,713
    11,848
    Central Virginia
    Here's a bored, retired draftsman looking for work! ;)
  15. Salamander_King
    Salamander_King Senior Member
    11,024
    8,978
    New England
    Rule of thumb is difference in thread depth greater than 3/32nds of an inch, you should get at least a pair if not a set of tires.
    The Electric Me likes this.
  16. ssdesigner
    304
    241
    california
    2013 Aqua
    No offense, but that sounds like a tire manufacture's rule of thumb. I can't be convinced that 3/32" is a concern of any kind, it's just not logical.
    krmcg likes this.
  17. Salamander_King
    11,024
    8,978
    New England
    Logic is that 3/32" difference in tread depth means 6/32" difference in size of tire diameter if your are using the same brand tires. That means even if you used exactly the same brand, model, size of tire as old one, new tire circumference is 3.14 x 6/32" longer. Any difference greater than that may harm mechanical component of the car and/or affect the safety and comfort of your ride. I am not advocating this to you, that's what I've read somewhere. But if I was in your shoes, I would change a pair rather than just one if the depth difference is greater than 3/32, and keep the one good tire as spare.
    #17 Salamander_King, Aug 15, 2018
  18. Mendel Leisk
    42,347
    New tread depth of those is 9.7/32", according to TireRack. For all practical purposes: 10/32". Having a little more fun with the Lincoln penny tread depth gauge:
    #18 Mendel Leisk, Aug 15, 2018
  19. RRxing
    RRxing Senior Member
    2,563
    1,842
    NEPA
    They'll be in high demand after the poop hits the fan, much like the COBOL programmers who made bank to prevent the "Y2K" bug.
    Raytheeagle and Mendel Leisk like this.
  20. Mendel Leisk
    42,347
    Everybody's doing 3D modelling and automated drawing output now, I''ve become a dinosaur in 25 years. S'okay.
    Raytheeagle likes this.
