blew up my engine today
Discussion in 'Gen 3 Prius Main Forum' started by tankyuong, Jul 10, 2016.
  1. tankyuong
    tankyuong Senior Member
    1,555
    662
    Central MO
    at first it was leaking coolant very slowly,then making the rattling engine noise at low rpm then a part flew off while on the highway gushing out oil.Time for a new used engine.Planning on diy if all else fails off the junker.230,000 miles on odo.
  2. xliderider
    xliderider Senior Member
    8,140
    3,280
    Honolulu, HI
    Wow, sorry to hear that. From your description, it was probably a head gasket failure. Once coolant/water entered the combustion chamber/cylinders, the engine threw a rod, that's when the oil started leaking out of the engine.
    Former Member 68813 likes this.
  3. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
  4. tankyuong
    1,555
    662
    Central MO
  5. BigBear2010
    BigBear2010 Member
    156
    65
    Failure at 230k miles!? It rarely happens to prius. First time i see it. Sr for your loss
    tankyuong likes this.
  6. Redpoint5
    Redpoint5 Senior Member
    1,026
    509
    Portland, OR
    Doesn't Japan have some silly law about only allowing engines to be used until 100,000 kilometers? I've heard this is why used replacement engines are relatively affordable on Japanese vehicles.
    Strange that the Prius would just detonate like that. It's common for a Subaru to loose a head gasket, but haven't heard of it on the Prius before.
  7. BZzap!
    BZzap! Senior Member
    1,607
    878
    I would be curious to see the service history on the car.
  8. ALS
    ALS Active Member
    590
    294
    Pittsburgh
    Car-part.com is your friend in these situations. It's a salvage yard search engine.
  9. Former Member 68813
    3,524
    983
    US
    I guess it was the warning. either a bearing was shot or low oil.
  10. ETC(SS)
    7,554
    It would make for an interesting DIY thread.....
    (EDIT: no....not grenading an engine, but replacing it with a used motor.) :D
  11. tankyuong
    1,555
    662
    Central MO
    found a place that would do it for 1200 labor
  12. ETC(SS)
    7,554
    For a 2010?
    That's reasonable...
  13. Redpoint5
    1,026
    509
    Portland, OR
    How much for the motor, and where did you find it?
  14. tankyuong
    1,555
    662
    Central MO
    1000 with 100000 miles, the repair place found it only ne somewhere
  15. ozmatt
    ozmatt Active Member
    637
    263
    Australia
    Hi all, earlier this week I was talking with the local hybrid taxi mechanic in my area who is responsible for around 100 vehicles, he mentioned the 30 series prius do sometimes pop head gaskets, he also mentioned their fleet of 30 series cabs have been killing traction batteries way faster than the 20's ever did.. I recall there was a 30 series on ebay about a month ago with a blown hg, I think this is going to end up common for 30's as they get older.
    cheers ..
    tankyuong and Redpoint5 like this.
  16. Mendel Leisk
    42,345
    Is it completely cost prohibitive to replace the head gasket? Would that be due to warping, need to machine the head? The engines that are available, are some of them refurbs that went through a head gasket replacement? Or mostly salvage?
  17. MrMischief
    MrMischief Active Member
    426
    443
    Denver CO
    $1,274 - $1,620
    Head Gasket Replacement Cost for Toyota Prius - RepairPal Estimate
    Robert Holt likes this.
  18. CR94
    CR94 Senior Member
    2,830
    1,242
    Northwestern S.C.
    I thought it was because the engine is tucked so far under the cowl that it must be removed in order to remove the head. True?
  19. Former Member 68813
    3,524
    983
    US
    interesting. according to: Why Head Gaskets Fail
    HG can fail when there is preignition due to EGR system not working. Well, the 2nd gen didn't have EGR and the 3rd gen has EGR valve/cooler that plugs up often. One more reason to take the EGR valve/cooler apart every 100,000 miles to clean it up.
  20. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,528
    Bay Area, California
    2019 Prius Prime
    Pairing the egr cooler cleaning with the coolant flush would save a step in the process. But a great catch and suggestion.
