Blind Spot Monitor Fault BSM
Discussion in 'Gen 4 Prius Main Forum' started by chamkila, Jun 16, 2018.
  1. chamkila
    chamkila Junior Member
    NYC
    Guys where are the sensors located, Mine just got a fault. Maybe the sensors need a cleaning before I go to toyota so they can take it look at it. Its still under warranty.
    Thanks again.
  2. Elektroingenieur
    2,515
    3,232
    Three Touring
    The ultrasonic sensors are on the left and right sides of the rear bumper, shown as item ⑥ in parts catalog Figure 84-17, Clearance & Back Sonar, and in the illustration on page 326 of the Owner’s Manual (PDF).
    krmcg likes this.
  3. chamkila
    NYC
    Thank you. Is it underneath the bumper because the bumper is smooth. And I can't see it
  4. The Professor
    The Professor Senior Member
    591
    791
    UK
    Excel
    Ultrasonics are highly unreliable in high wind speeds (e.g. travelling at speed), and probably don't have the range to cover the distance required. I think the Blind Spot Monitor uses radar modules behind the corners of the rear bumper...
    Supporting source: 2016 Prius - the next generation of Toyota's technology ambassador - Toyota
    Elektroingenieur likes this.
  5. Elektroingenieur
    2,515
    3,232
    Three Touring
    That’s a good point. The radar sensors, at about the same locations on the sides of the rear bumper, are shown with Part Name Code 88172 in the second image for parts catalog Figure 84-01, Switch & Relay & Computer.
  6. Fester
    Fester Active Member
    201
    198
    Ohio
    Yes they are radars located in each side rear quarter panels. I'm pretty sure the radars are sealed well against the panels on the inside surface, so unless the outside surface of the panels is covered with a lot of mud or dust, thats probably not the problem.
  7. RCO
    RCO Senior Member
    3,709
    5,179
    Cornwall
    I believe the handbook advises keeping the rear quarter panels clean at all times for them to work consistently well.
    kithmo likes this.
Loading...
