1. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,520
    38
    Santa Fe, NM
    Hmmm....well, the voltage drop being 50 mV for the bad module and 30 mV for the good one, across the same load and at the approximate same open circuit voltage, shows that the internal resistance of the bad module is almost twice as high as the other one. Now, some of the other numbers I am not too sure about, since I don't see how to get a 2.23 amp current out of a 10 Ohm load with a 7.5V battery.
    By the way, the upper limit before getting a bad block code is 0.1 Ohm for two modules in series.
    Anyway, academics aside, I'm very glad to hear that the car is running well!
  2. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    512
    63
    7.5V over 10ohms gives less than an ampere of current - seems too small a current to load the module to give good answers. How about loading with 1 ohm 100W resistor (or 10 of the 10 ohms 10W in parallel)?
  3. no trust
    no trust Junior Member
    46
    Powhatan, VA
    Ok bobo .12 ohms
  4. no trust
    46
    Powhatan, VA
    ok, let me try again, bad math! bad module v=7.44v, v@resistor=7.39v , a diff of.05v , in a series circuit we know total voltage=the sum of all the voltage at each resistor,so internal v=.05v, now I@ resistor=2.23A, and we know that in a series circuit current stays the same at each resistor. so internal I=2.23 also. so to find internal resistance we use R=.05v/2.23A R=.02ohms , good module v=7.62v, v@resistor=7.59 a diff of .03v I=2.33A so R=.03/2.33=.01ohms . So bad modules internal R is double ! The resistor read 9.8 ohms with the fluke. It was rated 10ohm 10W max voltage of 350v , i have no idea why i read the amperage i do, but if u use ohms law I=V/R I=350/9.8 I=35.7 then using P=IxV P=35.7x350 P=12495W. So yes i am very confused on that note , but ignoring the resistors rateing and useing what my meter tells me the rest of the math makes sense,once again confirming the bad module ! I hope this cleared some things up. thanks
  5. no trust
    46
    Powhatan, VA
    seilerts, thank u for the (hmmmmm...well) i know what u were thinking! By the way all my testing is done equally to each module in equal time,so i should have some true values for u over time. And to 09 prius, yes i agree , i am starting from the basics,begining back with ohms law,when u dont use it u loose it! In the apprenticeship i was top of my class (doesnt say much does it?) We were taught series , parallel, and combo circuits but never that a battery was not a pure emf, for an electrician that would have gone too far!!!so im learning! and to freydnot ill take the hit. lol
  6. seilerts
    3,326
    1,520
    38
    Santa Fe, NM
    To first order, you can model this as two resistors in series: your 10 ohm load, and the internal resistance of the battery. V=open circuit, i=current, R=10 ohm resistor, Rb=internal resistance, Vb=voltage drop. Maybe JeffD can check my math...
    V = i (R + Rb)
    Vb = i*Rb
    Two equations, two unknowns. Eliminating the current,
    Rb = R*Vb/(V+Vb)
    For the bad one, Rb = 10*.05/(7.55) = 0.066 ohm
    For the less bad one, Rb = 10*0.03/7.55 = .04 ohm.
    Soooooo.... Toyota spec being .1 ohm or less for internal resistance of the block pair, this pair fails with .106 ohms.
  7. khp
    khp Member
    76
    45
    SW Washington
    I have been reading this post and I am very grateful to all who have contributed to this discussion and the "need help hv battery" thread.
    I also have a bad module(P03018) in my 2006 prius and will start working on it this Sunday. I purchased some modules from jdenenberg which should be coming next week sometime. This thread is great because I will be doing the same thing no trust did. I will probably be asking some questions also when I get into mine but this and other postings here answer a lot of the ones I had. Thanks again.
  8. seilerts
    3,326
    1,520
    38
    Santa Fe, NM
    No problem. be sure to pay attention to how the orange hv service plug is installed. Not pushing the handle all the way down is the #1 mistake.
  9. khp
    khp Member
    76
    45
    SW Washington
    I will. I have seen a number of posts about that. Thanks
  10. Angel209
    Angel209 Junior Member
    Stockton
    How do you get the blink codes
