Blinking/beeping traction control light.
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Prius92, Jun 21, 2025.
  1. Prius92
    Prius92 Active Member
    595
    122
    Iowa
    Seems to turn on going over 45mph.
    No codes.
    ONLY the traction control light blinks/beeps. No check engine, abs, brake, etc lights on.
    Goes away when coming to a stop.
  2. ChapmanF
    18,822
    Trouble codes will be set when it thinks it isn't working right. But when it thinks it's just doing its job and controlling traction, that won't set trouble codes.
    A scan tool that shows you the "ABS History" will show what all the sensor readings were the most recent four times the ABS or traction control activated. That information can give you a big hint where the problem is.
  3. Prius92
    595
    122
    Iowa
    Well Toyota recently replaced the axle. I wonder if they put the axle in without removing the ABS sensor. I think on some cars, including the Prius, it will break it if you don't take it out first.
    But generally when I've accidentally done that myself, the ABS light comes on too.
  4. mr_guy_mann
    mr_guy_mann Senior Member
    4,108
    2,008
    NJ-USA
    Could be something like the axle having a damaged tooth on the "tone ring" that triggers the ABS wheel speed sensor. (or the wrong number of teeth).
    Another cause would be having different sized tires on the front vs rear.
    You would look for something that would make the ABS ecu think that the front wheels are "significantly" different speed than the rears.
    This is one situation where having a capable scantool to look at ecu data might be handy.
  5. Tombukt2
    Tombukt2 Senior Member
    13,700
    2,480
    Durham NC
    Look at the wheel sensor and ring 30 min.
  6. pasadena_commut
    pasadena_commut Senior Member
    2,957
    906
    Southern California
    Was the car doing that before?
    Did it start doing it immediately after, like on the drive home?
    If the answers are NO and YES take it back and have them fix what they broke.
  7. Prius92
    595
    122
    Iowa
    So I jumped the pins to get the 3-4 lights to blink.
    All the codes pointed to skid control ecu, and zero-point calibration not being done.
    I went to disconnect the 12v battery to reset the computers, and noticed the terminal was quite loose.
    I'm hoping that loose cable might of been causing interment faults that didn't actually exist.
    I'll report later if it does it again, I will hook up my actual techstream and see what's going on.
    Brian1954 likes this.
  8. Prius92
    595
    122
    Iowa
    No issues so far.
