Block heater 2016
Discussion in 'Gen 4 Prius Accessories and Modifications' started by secaturbo, Mar 17, 2016.
  1. secaturbo
    secaturbo Junior Member
    Is there a block heater option for us in the north?
  2. galownia
    galownia Previous master neon mechanic
    117
    73
    Call the dealer, they can get one. Part is $50.
    Jonathan
    RCO likes this.
  3. Mendel Leisk
    42,173
    Can you be a bit more specific: Alaska, Canada, Finland, Siberia? Assuming Canada: here's the installed price:
    2016 Prius Accessories - Toyota Canada
    $322 is a jump, last year it was around $235, better deal. The part up here is somewhere around $80~90, but install is not trivial. Especially if you're doing this in conjunction with purchase, it'd be easier to get it installed, and maybe you can negotiate the cost as part of the package.
    Two hours usage is good. We use ours year round, right through summer, almost without fail, for the first start up of the day. Run the plug out through the lower grill, double zip-tie it, short enough that it won't drag on the road, and plug into an extension cord that can pull out easily, and is secured so that you don't end up dragging it down the street. Sooner or later you will forget to unplug, lol.
    #3 Mendel Leisk, Mar 21, 2016
    RCO likes this.
  4. HVAC
    HVAC Member
    43
    44
    Seattle Area
    Has anyone used one on a gen 4 yet?
    With the faster ICE warm up they have, is it still worthwhile? I looked for the hole described on older ones and did not find it. I understand it is not visible and must be felt.
    RCO likes this.
  5. galownia
    117
    73
    Sorry - part is $50 in Minnesota. Install is expensive. I usually do these myself, so I don't pay for install.
    RCO likes this.
  6. greenmonster01
    106
    79
    Southeastern MA
    Anyone have a part number for the block heater on a gen 4?
  7. mjoo
    mjoo Senior Member
    1,163
    1,334
    Michigan
    I called a Toyota dealership in Alaska. They gave me a part number but I think it's a Canadian part number. It's C014000913.
    If my local dealership can't get this part I'll call one in Minnesota.
  8. Prodigyplace
    12,708
    11,847
    Central Virginia
    Be careful about the Gen 4 grill shutters, though. You do not want to obstruct their operation.
    See Grille Shutter Inoperative and Check Engine | PriusChat
  9. mjoo
    mjoo Senior Member
    1,163
    1,334
    Michigan
    I could not order the part number that I got from the Alaskan dealership locally so I called all three dealerships in Minnesota. The dealership in Burnsville was the most helpful. They claimed that they called Toyota Corporate and Toyota said the same part number for the 2015 Prius works for the 2016-2017 Prius. The part number is PU140-00913. I'm going to send an email to Toyota Corp myself. I need this information in writing so that I don't void my warranty.
    greenmonster01, RCO and Prodigyplace like this.
  10. mfa-prius
    mfa-prius Old member
    299
    46
    Hansville, WA
    A friend ordered a PU-140-0900 for me for Christmas, which an on-line chart said was correct for my Gen 2 2005. However, I received a p/n PU140-00913. After a couple weeks of trying to get this straightened out, I finally appealed to the ultimate authority (Danny) and he found:
    "Good news: it's the same part. Anything with a number lower than 913 is an obsolete number. Toyota periodically updates the number. 913 is the most current and fits all applications. It is the only style of block heater currently carried by Toyota and is applicable across all of their cars."
    Incidentally, the PriusChat Shop has the best price I've found on this thing.
    RCO and Mendel Leisk like this.
  11. Prodigyplace
    12,708
    11,847
    Central Virginia
  12. mfa-prius
    299
    46
    Hansville, WA
    Right now, the Prius Chat Shop still differentiates the product among several models, but no matter what you order, you get the -00913 part, which Toyota says applies to all Toyota models.
    RCO likes this.
  13. chughes123
    chughes123 Junior Member
    66
    vancouver washington
    Gen 4 heats up really fast with the catalytic converter coolant loop. Are you guys purchasing a block heater because you have sub 0F temps? Should still turn on fine..
  14. Mendel Leisk
    42,173
    I use block heater year 'round, on a third gen.
  15. BJFons
    BJFons Junior Member
    23
    Jackson, Wi.
    Guys, looking for install info for the 4th gen. Our Drive $mart Wisconsin group mechanics have installed over 100 EBH's in all years of the Prius and they have a problem with the 4th gen install. The engine port has several rigid lines near the entry point and the can get the EBH in but cannot snap it in place.
    We get our EBH's from Jesse at Metro out of Cleveland and paid about $40 for our units...we sell them for $50 so our D$W group makes some money for community outreach efforts. We recommend EBH's n any Prius for the above reasons and it should be used year round for max mpg. Without my EBH installed yet, my lifetime at 2500 miles is 91.1 mpg and I don't want to lose the typical 10-15% loss due to cold weather.
    So, anyone install in a 4th gen yet and what is the secret for proper install or anyone know a Canadian dealer that can assist in instructions?
  16. Prodigyplace
    12,708
    11,847
    Central Virginia
    One thing I do know. The Gen 4 has active grill shutters. do not route the cable through the shutters. One poor user in Alaska already has his Gen 4 catch fire, likely due to the dealer routing the cable through the shutters.
    I thought there is a spot on the engine block designed to mount the EBH with a single screw. I have not looked at the place on mine since we do not need them down south.
  17. mfa-prius
    299
    46
    Hansville, WA
    If the dealer can sell these things for $50, Toyota probably pays under $30 for them. They really should be a factory-installed item.
  18. Prodigyplace
    12,708
    11,847
    Central Virginia
    Why would Virginia and south need them?
  19. mfa-prius
    299
    46
    Hansville, WA
    I spent a very unenjoyable few days in the Florida Keys a while back when the temperature dropped into the low 40s.
  20. Mendel Leisk
    42,173
    Why not? Anyway:
    @BJFons is looking for install info, not debate regarding the need for 'em, lol.
