Block heater 2016
Discussion in 'Gen 4 Prius Accessories and Modifications' started by secaturbo, Mar 17, 2016.
  1. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    I interpreted the post as if fitting a block heater it should be done at the factory or dealership.
  2. Mendel Leisk
    42,343
    Dealership install is a hassle too. Assuming it's similar to 3rd gen, likely the wipers, their motor and linkage, and the cowl need to come off for access. Then you fight your way through various wiring harness in vicinity.
    Factory install with engine out of the car is so much easier. It'll take consumer demand, and that's likely slow in coming. There's almost an inverse adoption rate: it's sort of a point of pride: prairie owners saying they don't need a block heater. Or snow tires, lol.
    RCO likes this.
  3. BJFons
    BJFons Junior Member
    23
    Jackson, Wi.
    Just an FYI that the new OEM Toyota part number for the recalled EBH is PU140-00913-1. I have found a dealer to install after two other dealers refused to install, even though I have the EBH. So yes Mendel factory install would be better.
  4. Prodigyplace
    12,712
    11,848
    Central Virginia
    Be sure to check they did not route the EBH cable through the grille shutters. We had a user in Alaska that had issues with that.
